Comparison of Top Automated Tools for Instrument Index Generation from P&IDs in EPC Engineering
An instrument index is one of the most important engineering registers in an EPC project. It connects information from P&IDs with instrumentation engineering, control system design, procurement, commissioning, and plant maintenance.
Traditionally, engineers review P&IDs manually, identify instrument tags, determine instrument types, record services and drawing references, and transfer the information into Excel or an engineering database. This approach becomes difficult when a project contains hundreds or thousands of drawings.
Automated instrument index generation from P&IDs uses OCR, computer vision, AI based symbol recognition, contextual analysis, and structured data processing to reduce manual extraction work. The important point is that useful P&ID automation must do more than read text. It should understand the relationship between instrument symbols, tags, process lines, equipment, control loops, and drawing references.
Recent research has also specifically investigated AI based instrument index generation from P&IDs, including text detection, computer vision, and OCR techniques.
An instrument index is a structured register containing information about instruments used within a project.
Typical fields include:
FieldTypical information
Instrument tagPT 101, FT 202, LIC 301
Instrument typePressure transmitter, flow transmitter, level controller
ServiceProcess service or measurement description
P&ID referenceDrawing number and sheet
Loop numberAssociated control loop
Signal typeAI, AO, DI, DO or other project specific classification
LocationField, panel, cabinet or other location
RangeMeasurement range
Engineering unitsbar, degree C, m3/h and similar
Process connectionConnection information where available
Datasheet referenceRelated instrument datasheet
Control system informationDCS, PLC or SIS information where available
Safety classificationSIL information where applicable
RemarksAdditional engineering information
The exact fields depend on the EPC company, client specification, project tagging philosophy and engineering database.
An instrument index should not be confused with an I/O list. Not every instrument shown on a P&ID necessarily has a direct DCS, PLC or SIS I/O signal.
Master P&ID Reading Before Automating Instrument Data Extraction: Piping & Instrumentation Diagram (P&ID)
Large EPC projects can contain extensive P&ID packages. Manual extraction requires engineers to repeatedly inspect drawings, identify tags and enter information into structured registers.
Common problems include missed instruments, duplicate tags, inconsistent descriptions, poor quality scans, unclear symbols, different tagging conventions and revision changes.
Benefits of Automated P&ID Instrument Extraction
Automation can assist with initial extraction, duplicate detection, source traceability and structured output. However, engineering review remains important because P&IDs do not contain every attribute required for a complete instrument index.
For example, manufacturer information, detailed materials, calibration requirements and some control system information may exist only in datasheets, specifications, I/O databases or other engineering documents.
ToolP&ID ExtractionPDF and Scanned DrawingsInstrument Tag ExtractionInstrument IndexOther Engineering RegistersRevision and ValidationSource Traceability
PathnovoYesYesYesYesI/O, valve and equipment workflowsYesYes
TagsightYesYesYesYesI/O, equipment and line listsYesYes
PANDIDYesPDF and image inputsYesStructured dataEquipment and related dataEngineer verificationYes
PIDVision.AIYesYesYesYesRelated engineering extractionReview workflowYes
Novek AIYesYesYesYesLine, equipment and engineering registersYesYes
Connect Instrument Signals With Smarter Engineering Data Management: I/O Database
https://pathnovo.com/solutions/instrument-index-automation
FeaturePathnovo Capability
P&ID extractionYes
Instrument tag extractionYes
Instrument type extractionYes
Service informationYes
Loop informationYes
Instrument index generationYes
Datasheet populationYes
I/O list generationYes
Valve schedulesYes
Revision trackingYes
Structured outputExcel and JSON documented
EPC applicationInstrumentation and engineering document workflows
Build Accurate I/O Records Without Missing Critical Signals: I/0 List
Tagsight describes P&ID extraction for instrument indexes, I/O lists, equipment lists and line lists. Its documentation states that it can process vector and raster PDFs, scanned drawings and image formats, while maintaining traceability to the source drawing. It also describes support for different instrumentation tagging conventions and multi sheet drawing sets.
Refer the below link
https://tagsight.io/pid
FeatureTagsight Capability
P&ID extractionYes
Vector PDFYes
Scanned P&IDYes
Instrument indexYes
I/O listYes
Equipment listYes
Line listYes
Tag convention handlingYes
Multi sheet P&ID processingYes
Source traceabilityYes
Engineering reviewYes
Capture Critical Instrument Details Engineers Need For Design: Instrument Data Sheet /Specification
PANDID focuses on extracting structured information from P&IDs, including engineering objects such as instruments, equipment, lines and tags. Its approach is useful where the requirement extends beyond a basic spreadsheet and involves creating structured engineering relationships from the drawing.
https://www.pandid.io/
FeaturePANDID Capability
P&ID extractionYes
PDF and image inputYes
Instrument detectionYes
Tag extractionYes
Equipment detectionYes
Line detectionYes
Structured engineering dataYes
CSV outputDocumented
Graph based dataDocumented
Data correction workflowYes
Engineering relationship analysisYes
Trace Every Instrument Through Complete Control Loop Documentation: Instrument Loop Diagrams
PIDVision.AI describes AI based P&ID analysis using instrument detection, classification and OCR based extraction. Its workflow is focused on converting information contained in P&ID drawings into structured instrumentation information.
https://pidvision.com/
FeaturePIDVision.AI Capability
P&ID analysisYes
PDF processingYes
Image processingYes
OCR extractionYes
Instrument classificationYes
Line number extractionYes
Service description extractionYes
Instrument index workflowYes
Structured engineering informationYes
Avoid Cable Documentation Errors Across Complex Instrumentation Projects: Instrument Cable Schedule
FeatureNovek AI Capability
P&ID extractionYes
Scanned P&IDYes
PDF processingYes
Raster CAD inputYes
Instrument loop detectionYes
Process topologyYes
Cross drawing connectionsYes
Instrument indexYes
Datasheet extractionYes
Cross document reconciliationYes
Source linked reviewYes
Confidence based reviewYes
Structured engineering outputYes
API integrationDocumented
Engineering database integrationDocumented
Organize Junction Box Connections Before Commissioning Starts: Instrument Junction Box (JB) Schedule
Practical EPC Comparison of P&ID Instrument Index Automation Tools
For an EPC instrumentation team, these feature tables should be used together with the common comparison table. The main evaluation should focus on whether the software can process the company’s actual P&ID formats, understand project specific tagging conventions, maintain source traceability and produce an instrument index that matches the approved engineering template.
The most important test is therefore not simply whether a tool can extract a tag from a drawing. The engineering team should verify how reliably it handles the complete workflow from P&ID extraction to structured instrument data, engineering validation, revision checking and final instrument index preparation.
Understand Systems Architecture Documents EPC Engineers Cannot Ignore: Vendor Document for Project Systems Architecture: Complete Engineering Guide for Instrumentation, Automation and Control
The feature table provides only an initial comparison. A proper EPC evaluation should examine how each system behaves with actual project drawings.
For example, two tools may both support OCR and instrument tag extraction, but their practical workflows can differ significantly when a drawing contains a crowded control loop, an unclear instrument bubble, a scanned revision or a client specific symbol.
Engineers should therefore test several representative drawing conditions, including:
  1. Clean vector based P&IDs
  2. Scanned P&IDs
  3. Low resolution drawings
  4. Drawings containing handwritten markups
  5. Drawings with multiple instrument loops
  6. Drawings using client specific symbols
  7. P&IDs containing repeated or similar instrument tags
  8. Revised drawings containing added or removed instruments
  9. Drawings where instrument information must be reconciled with datasheets
  10. Large drawing packages containing multiple process units
Strengthen Shutdown Engineering With Proper Safety Documentation: Shutdown Philosophy: Engineering Documentation for Process Safety and Emergency Shutdown Systems
The output should then be compared against the approved engineering instrument index template.
Particular attention should be given to source traceability. If an extracted instrument is recorded as PT 101, the engineer should be able to identify the exact P&ID and drawing location from which the information was obtained. This becomes especially important during engineering review, document revisions and commissioning.
Another important consideration is exception handling. A practical automation system should not force every uncertain result into a final engineering record. Unclear tags, questionable instrument classifications and conflicting document information should be visible to the engineering team for review.
Understand Electrical Power Distribution From One Critical Drawing: Single Line Diagram
The comparison should therefore consider the complete workflow from P&ID ingestion to extraction, validation, engineering review, structured instrument index generation and revision management rather than evaluating OCR capability alone.
No single platform should be treated as universally suitable for every EPC project. The appropriate choice depends on the drawing formats, project standards, required engineering outputs, document volumes, integration requirements, security requirements and the level of engineering validation required.
Get Ready To Use Instrumentation Engineering Documentation Templates: Downloadable Engineering Documentation Instrumentation and Control Templates
How Automated Instrument Index Generation From P&IDs Works
A practical automated workflow normally contains several stages.
  1. P&ID Document Collection: The project team gathers approved P&IDs and identifies drawing numbers, revisions and document status.
  2. Drawing Preprocessing: PDF pages or scanned drawings are prepared for analysis. Image quality, orientation and resolution can affect extraction.
  3. OCR and Text Detection: The technology detects text such as instrument tags, line numbers and service descriptions.
  4. Instrument Symbol Detection: Computer vision detects engineering items and instrument symbols.
  5. Tag Recognition: The system associates a detected instrument symbol with its tag.
  6. Instrument Classification: The extracted tag and symbol are interpreted to determine the likely instrument type.
  7. Contextual Relationship Analysis: The system attempts to understand relationships between instruments, process lines, equipment, valves and control functions.
  8. Data Normalization: Extracted information is converted into consistent fields for the project instrument index.
  9. Engineering Validation: Rules can be applied to identify missing tags, duplicates, inconsistent information or unusual relationships.
  10. Source Traceability: Each extracted record should remain traceable to its original drawing and location.
  11. Human Engineering Review: Engineers review uncertain records and correct exceptions before the index becomes an approved engineering deliverable.
Practical EPC Example of Automated Instrument Index Generation
Consider a process unit containing several hundred instruments distributed across multiple P&IDs.
In a manual workflow, engineers open each drawing, identify instruments, record tags, enter services and references into Excel, check duplicates and compare the resulting index with other documents.
An automated workflow can first process the drawing package, detect symbols and tags, structure the extracted information and identify potential duplicates. Engineers can then focus their time on exceptions, unclear drawings and validation.
The major difference is therefore not that engineering review disappears. The workflow changes from repeated transcription toward verification and reconciliation.
Discover Which Engineering Documents Drive Instrumentation Design: Types of Engineering Drawings and Documents used in Instrumentation
What Should EPC Engineers Check Before Selecting Instrument Index Generation Software?
Before adopting an instrument index automation system, engineers should evaluate:
  1. Recognition performance on actual project drawings
  2. Support for scanned and low quality P&IDs
  3. Instrument symbol recognition
  4. Project specific tag convention handling
  5. Client specific field mapping
  6. Traceability to drawing and source location
  7. Revision comparison capability
  8. Excel and engineering database compatibility
  9. Human correction and validation workflow
  10. Data security and confidential project handling
  11. API and integration capability
  12. Audit trail and exception handling
A controlled pilot using representative project drawings is more meaningful than relying only on demonstrations using clean sample drawings.
AI based P&ID extraction still has practical limitations.
  1. Poor quality scans can affect OCR. Handwritten markups can be difficult to interpret. Overlapping symbols can create detection problems. Legacy P&IDs may use symbols and tag conventions that differ from current project standards.
  2. Another important limitation is missing information. A P&ID may identify a pressure transmitter and its service but not contain the manufacturer, model, complete calibration range or all datasheet information.
  3. False instrument detection and missed instrument detection are also possible. For this reason, engineering validation should remain part of the workflow.
ISA 5.1 provides standardized approaches for depicting and identifying instrumentation and control functions, but individual EPC companies and clients can have additional conventions. The current ANSI ISA 5.1 edition is the 2024 revision.
Define Control System Behavior Before Automation Engineering Begins: Control Narrative
Manual Instrument Index Generation vs Automated P&ID Extraction
AreaManual workflowAutomated workflow
TimeRepeated drawing review and data entryInitial extraction followed by review
ScalabilityBecomes difficult with large drawing packagesDesigned for larger document volumes
ConsistencyDepends heavily on individual engineersStructured extraction can improve consistency
TraceabilityOften manually maintainedCan be linked directly to source drawings
Revision managementRequires repeated comparisonSome tools provide automated comparison
Error detectionEngineering QA checksAutomated checks plus engineering review
Initial setupLow technology requirementRequires configuration and validation
CustomizationDirect spreadsheet controlDepends on tool capability
Brownfield projectsOften difficult for large archivesUseful where scanned drawing support exists
Map Trips And Interlocks Before Final Safety Validation: Cause and Effect Drawings
A reliable instrument index can become a useful source for downstream engineering activities.
These can include I/O lists, instrument datasheets, control valve schedules, shutdown valve schedules, DCS engineering, PLC engineering, SIS engineering, marshalling information, junction box schedules, cable schedules, loop diagrams, procurement records and commissioning databases.
The value increases when extracted records remain traceable to the original P&ID and can be reconciled with datasheets, cause and effect documents and other engineering registers.
See How Process Engineers Map Complete Plant Processes: Process Flow Diagram
  • ISA 5.1 Instrumentation Symbols and Identification: ISA 5.1 is important when interpreting instrumentation symbols and identification methods.
  • ISA 20 Instrument Specification Forms: ISA also maintains ISA 20 specifications covering forms for process measurement and control instruments.
  • IEC 61511 and IEC 61508 for Safety Instrumentation: IEC 61511 and IEC 61508 can become relevant when safety instrumentation and SIL information are involved.
    Client P&ID Standards and Project Tagging Philosophy: Client engineering specifications and the project tagging philosophy remain equally important.
An automated tool should not be assumed to guarantee compliance with any engineering standard simply because it recognizes standard symbols.
Document PLC Alarms And Trips Before Plant Commissioning: PLC Alarm and Trip Documentation Procedure – EPC PLC Automation Engineer Guide
A practical EPC evaluation can use:
Manual engineering cost =
Number of P&IDs × average instruments per P&ID × average review and entry time per instrument × engineering hourly cost
Then compare this with:
Automation software cost + implementation cost + validation hours + revision processing effort
Potential rework avoided can also be considered.
The actual business case depends on project size, drawing quality, automation capability, engineering review requirements and integration depth.
Build Complete PLC Records For Reliable Automation Projects: PLC System Documentation Guide: Essential Records for Industrial Automation
  1. Can the system process scanned P&IDs?
  2. Can every extracted tag be traced to the source drawing?
  3. How are duplicate tags identified?
  4. How are uncertain results presented?
  5. Can engineers manually correct extracted information?
  6. Can the output match our existing instrument index template?
  7. Can the system compare P&ID revisions?
  8. Can it recognize our client specific symbols and tag conventions?
  9. How is confidential project information protected?
  10. Can extracted data be integrated with our existing engineering systems?
Compare Powerful P&ID Platforms Used For Process Engineering: 11 Best P&ID Software Tools for Process Design Engineers in 2025
An instrument index is an engineering register containing instrument tags, types, services, P&ID references, loop information and other project data.
It provides a structured reference for instrumentation design, procurement, commissioning and maintenance activities.
In process engineering, most people call P&ID Piping and Instrumentation Diagram and PID Process Identification or other project specific terms. A P&ID shows process equipment, piping, valves, instruments and control relationships used for plant design and operation.
The choice of P & I D software should be based on project standards, symbol libraries, interface with engineering databases, and collaboration and document management needs.
Common engineering platforms include AutoCAD Plant 3D and AVEVA and Hexagon solutions, however appropriateness depends on the EPC project.
ISO 10628 is an international standard for diagrams for the chemical and petrochemical sector comprising the graphical representation of process plants.
Additional ISA standards and client specific P&ID conventions may be defined as per project requirements.
EPC businesses develop and maintain P&IDs by using specialist engineering platforms like AutoCAD Plant 3D, AVEVA and Hexagon tools.
The choice of software is usually dictated by client standards, project database and engineering workflow.
You can utilize specialized P&ID engineering tools like AutoCAD Plant 3D or other plant design platforms used by EPC businesses.
For professional projects, check symbol standards, data management, collaboration and compatibility with the client’s engineering system.
Free P&ID tools can be useful for learning, basic diagrams and small engineering exercises.
For EPC projects, engineers generally need controlled symbols, engineering data management, revision control and project specific standards.
The final choice should be based on the client’s necessary software platform and engineering requirements for an EPC project.
Automated instrument index generation uses OCR, computer vision, AI and engineering rules to extract instrument information from P&IDs.
The extracted information can then be structured into an instrument index for engineering review and validation.
Yes, there are specialized AI tools that can extract instrument tags and associated information from PDF P&IDs.
The index extracted has still to be validated by an instrumentation engineer before being entered into an approved engineering registry.
AI is able to pull out instrument tags, instrument types, services, line numbers, equipment linkages and drawing references depending on the software.
Additional information may require datasheets, I/O lists or other engineering documents.
OCR mainly converts text in a drawing into machine readable information.
P&ID understanding also interprets symbols, relationships, process lines, equipment and engineering context.
Some automated engineering platforms provide I/O extraction or I/O list generation workflows from P&IDs.
However, a complete approved I/O list may require information from control system engineering and other project documents.
Some specialized P&ID analysis tools support scanned drawings and image based documents.
Extraction quality can still depend on resolution, drawing condition, OCR quality and project specific symbols.
Accuracy depends on the software, P&ID quality, drawing complexity, tagging conventions and engineering configuration.
Vendor accuracy claims should be validated using representative project drawings before production use.
Yes, engineering review remains important for unclear tags, missing information, unusual symbols and conflicting documents.
Automation should support engineering verification rather than replace the responsible instrumentation engineer.
Learn Exactly What A Complete Instrument Register Contains: Instrument Index: Definition, Example, Template and How to Create One
Automated instrument index generation from P&IDs can change an EPC workflow from extensive manual transcription toward structured extraction, validation and reconciliation.
The appropriate solution depends on project size, P&ID quality, engineering standards, required output, integration requirements, data security, validation workflow and revision management.
