- Project Engineering Stage (Design & Construction Phase)
- Automation Stage (DCS/PLC/SCADA Configuration)
- Maintenance & Commissioning Stage (Operational Support & Troubleshooting)
- SIS & ESD Related Documents (Critical Safety & Lifecycle Management)
- Download link for Instrumentation Documentation Master Table for Instrumentation and Control Engineer
This complete article explores the essential documentation needs for instrumentation and control engineers across the whole industrial process facilities lifetime. Proper documentation is the foundation of safe, efficient, and dependable automation systems from initial design through commissioning and into continuous operations. Whether you are maintaining present processes or managing a new project, knowing these documentation kinds can help to guarantee regulatory compliance, simplify troubleshooting, and facilitate efficient knowledge transfer among engineering teams..
- Process Flow Diagram (PFD)
A simplified process diagram displaying control loops, flow directions, process streams, and important equipment. Not meant for complex control logic or instrumentation configuration, it is utilized for process knowledge, early-stage design, and equipment sizing.
Refer the link : Process Flow Diagram (PFD) - Piping & Instrumentation Diagram (P&ID)
The most important engineering drawing for instrument engineers. Forming the foundation for design, installation, interlock development, and commissioning, it displays all instruments, pipelines, valves, and control schemes.
Refer the link : Piping & Instrumentation Diagram (P&ID) - Instrument Process Data Sheet
Provides process-specific input conditions for each instrument, including range, pressure, temperature, and fluid properties, which are critical for selecting accurate and reliable instruments.
Refer the link : Instrument Process Data Sheet - Instrument Data Sheet / Specification
Often used for vendor submissions and procurement, a thorough form with technical specifications including sensor type, material, electrical needs, mounting style, certifications, and communication protocol.
Refer the link : Instrument Data Sheet / Specification - Instrument Sizing Calculations
Engineering calculations sizing flow elements, control valves, and orifice plates using actual process data, hence guaranteeing appropriate control and reducing process disruptions. - Material Requisition (MR)
A formal document to start procurement via the supply chain, it contains needed instruments, their specifications, amounts, and needed delivery dates. - Technical Bid Evaluations (TBE)
A tabular comparison of several vendor proposals based on technical compliance, hence guiding the choice of the best appropriate product from a technical perspective prior to commercial negotiation. - Vendor Document Review Matrix
A project control sheet tracking all vendor submissions, review cycles, due dates, and approval statuses for documentation including GA drawings, calibration certifications, and IOM manuals. - Instrument Requisition / Purchase Orders
Based on MR and TBE, business documents used to order from suppliers. Includes commercial terms, delivery schedules, part numbers, and quantities. - Hazardous Area Classification Drawings
Ensures proper choice of explosion-proof or intrinsically safe devices by identifying plant areas susceptible to explosive atmospheres and classifying them (Zone 0/1/2 or Class I Div 1/2). - Instrument Location Layout
Drawing of plant layout showing the precise field placement of all instruments, hence facilitating cable, tubing, and access platform routing for maintenance planning.
Refer the link : Instrument Location Layout - Instrument Hook-Up Diagrams
Detailed drawing demonstrating mechanical installation configuration for each kind of instrument (such pressure transmitters or thermowells), including tubing, fittings, brackets, and air lines.
Refer the link : Instrument Hook-Up Diagrams - Instrument Loop Diagrams
Schematic demonstrating signal cabling from a field instrument to control system input/output card via junction boxes and marshalling panels, including power and grounding information.
Refer the link : Instrument Loop Diagrams - Instrument Tray Layout
Shows routing of cable trays for instruments across plant regions, used for cable segregation, space planning, and limiting interference from power cables.
Refer the link : Instrument Tray Layout - Instrument Cable Schedule
Essential for site installation and testing, thorough tabulation of all instrument cables, their specs, routing start/end positions, and terminal references at both ends.
Refer the link : Instrument Cable Schedule - Instrument Junction Box (JB) Schedule
Instrument Junction Box (JB) Schedule Lists all junction boxes, terminal configurations, incoming and outgoing signals, and spare terminals. Utilized to loop checks and field cable terminations.
Refer the link : Instrument Junction Box (JB) Schedule - Instrument Air Header Schedule
Instrument Air Header Schedule Specifies layout and connections for instrument air distribution system, including header diameters, branch take-offs, regulators, and flow capacities to pneumatic equipment..
Refer the link : Instrument Air Header Schedule - Instrument Installation Details
Drawing or schematic indicating how particular instruments should be installed, including supports, spacing, sensor immersion lengths, and environmental protection policies. - Instrument Earthing Drawing
Specifies grounding needs for shielded signal cables and electronic devices, hence guaranteeing signal integrity and worker safety in high-risk areas.
Refer the link : Instrument Earthing Drawing
- I/O Database
Digital version of the I/O list structured for control system configuration, including addressing, scaling factors, alarm settings, and engineering units for software upload.
Refer the link : I/O Database - Control Narrative / Control Philosophy
Textual description of how each process unit or control loop is supposed to behave under normal and abnormal conditions. Developed to automate logic.
Refer the link : Control Narrative / Control Philosophy - Cause and Effect Drawings / Matrix
Essential for safety, interlock, and ESD system programming, tabular logic displays input situations (such as low pressure) and their consequent actions (such as pump shutdown).
Refer the link : Cause and Effect Drawings / Matrix - SAMA Drawing
Using ISA or SAMA symbols, a thorough control logic diagram depicts process measurement, control methods, and final element interactions.
Refer the link : SAMA Drawing - Instrument Logic Diagrams
Logical schematic depicting how Boolean logic blocks and timers implement digital inputs, outputs, interlocks, and permissives. - System Architecture Diagram
High-level visual of DCS/PLC network exhibiting communication protocols, servers, HMIs, and controllers. Aids in network health, segmentation, and redundancy planning.
Refer the link : System Architecture Diagram - Single Line Diagram
Electrical schematic demonstrating how power is distributed from main switchboards to individual panels and instruments, including UPS distribution and breakers.
Refer the link : Single Line Diagram - Marshalling Cabinet Drawing
Marshalling Cabinet Drawing Diagram displaying cable glands, internal wiring, signal termination locations, and jumpers within the marshalling cabinets for neat signal routing.
Refer the link : Marshalling Cabinet Drawing - Cabinet Layout – GA/IA Drawing
Displays front and internal panel configuration of PLC/DCS cabinets with module, relay, terminal, and wire duct arrangement.
Refer the link : Cabinet Layout – GA/IA Drawing - Rack Room Layout Diagram
Physical layout of cabinet and server rooms illustrating placement of racks, HVAC, cable trays, and access clearances.
Refer the link : Rack Room Layout Diagram - Control Room Layout
Control Room Layout Drawing of control panel configuration for best human-machine interaction, huge screens, printer areas, and operator consoles.
Refer the link : Control Room Layout - IP Address Schedule
Tabulated list designating individual IP addresses for every PLC, HMI, SCADA server, and switch. Applied to diagnostics and system setup.
Refer the link : IP Address Schedule - Network Switch Port Allocation Details
Used for troubleshooting and traffic monitoring, document assigning each device to a certain port on a controlled switch.
Refer the link : Network Switch Port Allocation Details - Network Equipment List
Network Equipment List Inventory of all networking equipment (managed switches, firewalls, routers, gateways), with model numbers and associated functions.
Refer the link : Network Equipment List - Communication Protocol Configuration
Specifies setup criteria for protocols such HART, Profibus, or Modbus addressing, baud rate, parity settings, master/slave configuration. - Controller Logic Diagrams (Ladder, FBD, SFC)
Visual programming representations employed in PLC/DCS logic: ladder for digital control, FBD for analog, and SFC for sequencing. - Alarm Setpoint List
Defines normal operating limits, high/low alerts, and priority classification for each monitored process variable. - Redundancy and Failover Test Plans
Procedures to test control system behavior during controller, power, or network failures and verify switchover to redundant elements. - FAT Procedures (Factory Acceptance Test)
Before site delivery, checklists and step-by-step test plans will confirm instrument control and logic configuration.
Refer the link : FAT Procedures (Factory Acceptance Test) - SAT Procedures (Site Acceptance Test)
On-site procedure confirming control loops, interlocks, and communication are functioning post-installation and in line with design purpose.
Refer the link : SAT Procedures (Site Acceptance Test) - Shutdown Keys and Interlock Logics
Record all vital safety shutdowns and hardwired or soft interlock sequences carried out in the automation logic. - Segment Calculation Sheets
Calculates cable length, node count, and voltage drop to confirm communication health on Profibus or Foundation Fieldbus segments.
Must Read: Skills Required by Instrumentation Technicians
- Loop Check Sheets
Used during commissioning to confirm every input/output loop from field instrument to control system is properly connected, operational, and corresponds with documentation. Covers tests for continuity, range, polarity, and responsiveness. - Instrument Calibration Reports
 Thorough documentation of instrument “as found” and “as left” calibration data. Includes calibration date, technician name, test equipment used, and any deviations. Needed for planning of maintenance and audits. - Instrument Test Certificates
Vendor-supplied certificates verifying instrument conformity with factory approval criteria. Includes information such as production batch numbers, traceability to international standards, tolerance, and test range. - Pre-Commissioning Checklists
Documents based on tasks used before plant commencement to guarantee correct installation, wiring, air supply, instrument configuration, and tag verification have been completed. - Commissioning Test Procedure (CTP)
Step-by-step process to bring instruments and control systems online comprising energizing loops, controller configuration, logic loading, and alarm/interlock verification. - Cold Loop Check Reports
Confirms wire continuity and signal transmission from instrument terminals to DCS/PLC without process start-up. Simulates signals using loop calibrator or multimeter. - Hot Loop Check Reports
Functional tests done under powered and live plant settings to confirm the actual reaction of instruments and control system logic, hence guaranteeing dynamic performance. - Shutdown Maintenance Logs
Records of instruments tested, serviced, or replaced during planned plant shutdowns. Predictive maintenance planning and regulatory documentation depend on this essential tool. - Instrument Asset Register
Comprehensive database of all installed instrumentation assets including serial number, purchase date, service history, calibration schedule, and spare component references. - Maintenance Procedures for Instruments
OEM-supplied or plant-customized SOPs detailing periodic maintenance activities sensor cleaning, re-calibration, signal drift checks, and diaphragm or seal replacement. - Failure Analysis Reports (FAR)
Reports produced following significant instrument failures to examine underlying reasons, failure modes, and suggest remedial measures are called Failure Analysis Reports (FAR). Aids in reliability engineering and ongoing development. - Instrument Obsolescence Review Reports
Finds obsolete or unsupported equipment and suggests upgrades or replacements. Usually connected to programs for life extension or digitization plans. - Instrument Loop Maintenance Sheets
Field-ready documents compiling loop information tag number, wiring specifics, calibration history for usage during routine maintenance or troubleshooting. - Alarm Rationalization Reports
Post-commissioning study of nuisance or recurring alerts to categorize, mute, or retune control system alarm settings. - Instrument Replacement/Repair Records
Records of reasons for repairs, serial number changes, and part replacements including defective diaphragm, sensor drift, and broken terminal. Good for tracking audits and warranties. - Spare Parts List for Instrumentation
List of key spare inventory items including transmitters, cables, glands, JB terminals, valve positioners, and control cards to guarantee least downtime during breakdowns. - Instrument Interlock Validation Reports
Evidence that interlocks like trips and shutdowns trigger exactly as designed, tested during commissioning and after major revisions. - Preventive Maintenance Schedule for Instrumentation
A time- or use-based plan for calibrations, inspections, and health checks for field devices and panels to avoid unanticipated failures. - Instrumentation Manuals and Drawings (O&M Docs)
Operation and maintenance documents, user guides, and installation drawings supplied by vendors submitted with project handover package for future maintenance reference. - Control System Backup & Restore Logs
Control of version of firmware/software loaded in smart instruments or HART/Fieldbus devices. Aids in tracking illegal modifications, compatibility problems, or defects. - Instrument Firmware & Configuration Logs
Control of version of firmware/software loaded in smart instruments or HART/Fieldbus devices. Aids in tracking illegal modifications, compatibility problems, or defects. - Safety Loop Periodic Test Reports
Records test outcomes for safety instrumented functions (SIFs) for ESD valves or flame detectors, so guaranteeing they satisfy needed SIL dependability throughout time. - Permit-to-Work (PTW) with Instrumentation Checklist
Site safety permit covering instrument-specific risks include pressured air, electrical shock, or process leakage. Guarantees proper performance of maintenance tasks.
Refer to understand the Essential Networking skills required for an Instrument engineer
- Safety Requirement Specification (SRS)
A basic SIS document specifying the functional requirements, safety integrity level (SIL), trip settings, reaction times, and diagnostic coverage for every Safety Instrumented Function (SIF). It directs validation, implementation, and design of SIS. - SIL Determination Report
Recorded results of SIL assessment techniques such LOPA (Layer of Protection Analysis), Risk Graphs, or Fault Tree Analysis. Based on process hazard analysis and risk reduction requirements, it indicates the needed SIL level for every SIF. - SIL Verification Calculation Sheets
Quantitative evidence that a planned safety loop satisfies its needed SIL goal. Includes hardware fault tolerance, test intervals, diagnostic coverage, and PFDavg (Probability of Failure on Demand) estimates. - Cause & Effect Matrix (SIS Specific)
focusing on safety functions, this matrix reveals which action is triggered under particular fault or process situations by connecting safety instrument initiators (such high-pressure transmitters) to final elements (ESD valves). - ESD System Logic Diagram / Shutdown Logic
Graphical or logical depiction of how emergency shutdown sequences operate. Covers actuator responses, permissive checks, logical solver reaction, and hardwired tripping. Essential for commissioning and logic testing. - SIS Architecture Diagram
Displays SIS system architecture with logical solvers (e.g., Triconex, HIMA), redundant routes, voting methods (1oo2, 2oo3), and isolation from BPCS. Guarantees ISA 84 or IEC 61511 compliance. - Safety Instrument Loop Diagrams
Like conventional loop diagrams but with extra focus on fail-safe wiring, signal integrity, and voting logic. Comprises diagnostic signals, power isolation, and approved barriers. - Safety Lifecycle Management Plan
Document describing how the whole SIS lifespan from danger detection to decommissioning is managed according to IEC 61511. Covers change management, proof testing, audits, and functional safety evaluations. - Proof Test Procedures for SIFs
Standardized method to periodically test safety functions e.g., shutdown valve closing to guarantee operation. Includes test interval, anticipated outcomes, and safe bypassing of safety logic procedures. - SIF Validation Report
Last recorded evidence that the installed SIF works according SRS. Contains logical validation processes, reaction time data, commissioning logs, and functional test records. - Logic Solver Configuration & Security Log
Protect configuration files and change logs for SIS logic solvers. Ensures traceability and cybersecurity compliance by tracking who changed what, when, and why. - Functional Safety Assessment (FSA) Reports
Independent assessment reports FSA-1 to FSA-5 carried out at critical SIS lifecycle stages. Confirms that IEC 61511 standards are met by safety criteria, design, testing, and maintenance.
Click here for Skills required for Instrumentation Engineer
The table below classifies 82 essential documents and drawings used by instrumentation experts into appropriate areas including Project Engineering, Automation, Maintenance, and SIS/ESD (Safety Instrumented Systems). Every entry offers its goal, responsible discipline, and relevant stage in the project lifecycle.
| S.No | Document Name | Category | Purpose / Use | Owner / Responsibility | Stage |
| 1 | Process Flow Diagram (PFD) | Project | High-level representation of process steps and utilities | Process Engineer | Design |
| 2 | Piping & Instrumentation Diagram (P&ID) | Project | Shows instruments, valves, piping, and control loops | Process / Instrument Engineer | Design |
| 3 | Instrument Index | Project | Master list of all tagged field instruments | Instrument Engineer | Design |
| 4 | I/O List | Automation | Summarizes all input/output signals connected to PLC/DCS | Automation Engineer | Design |
| 5 | I/O Database | Automation | Detailed parameters and descriptions of each I/O point | DCS Engineer | Design |
| 6 | Instrument Data Sheet / Specification | Project | Technical and environmental specs for each instrument | Instrument Engineer | Design |
| 7 | Instrument Loop Diagrams | Automation | Shows field-to-control room connections per tag | Instrument / CAD Engineer | Design |
| 8 | Instrument Hook-Up Diagrams | Project | Installation detail drawings with fittings and supports | Instrument Engineer | Design |
| 9 | Instrument Location Layout | Project | Instrument physical locations in plant plot plan | Instrument Designer | Design |
| 10 | Instrument Tray Layout | Project | Routing of trays/conduits for instrument cables | Instrument Designer | Design |
| 11 | Instrument Cable Schedule | Project | Cable ID, type, from/to, termination details | Instrument Engineer | Design |
| 12 | Instrument JB Schedule | Project | Terminal arrangement and tag assignments in JBs | Instrument Engineer | Design |
| 13 | Instrument Air Header Schedule | Project | Details air header routes and take-offs for pneumatic instruments | Instrument Engineer | Design |
| 14 | Instrument Logic Diagrams | Automation | Logic sequence for interlocks or control actions | Automation / Control Engineer | Design |
| 15 | Control Narrative | Automation | Describes control philosophy and sequences in words | Control Engineer | Design |
| 16 | Cause and Effect Drawings | SIS | Maps initiators to actions for safety & ESD logic | Safety / Control Engineer | Design |
| 17 | SAMA Drawing | Automation | Detailed control system function block representation | Control Engineer | Design |
| 18 | Rack Room Layout Diagram | Automation | Layout of equipment racks, panels, servers | DCS Engineer | Design |
| 19 | Control Room Layout | Automation | Operator console, screen, and cabinet locations | Control Engineer | Design |
| 20 | Cabinet Layout – GA/IA | Project | General arrangement and internal wiring of panels | Panel Vendor / Engineer | Design |
| 21 | Single Line Diagram | Project | Electrical power distribution overview | Electrical Engineer | Design |
| 22 | IP Address Schedule | Automation | Allocates static IPs to devices in control network | DCS / IT Engineer | Design |
| 23 | Network Switch Port Allocation | Automation | Assigns each device port on switches with details | Network Engineer | Design |
| 24 | Network Equipment List | Automation | List of routers, switches, access points | Network Engineer | Design |
| 25 | Marshalling Cabinet Drawing | Automation | Terminal mapping from field to system side | Instrument Engineer | Design |
| 26 | I/O Database (Duplicated Ref.) | Automation | Included above (#5), skip or merge | DCS Engineer | Design |
| 27 | System Architecture | Automation | Overview of PLC/DCS, HMI, historian, remote IOs | System Integrator | Design |
| 28 | Earthing Drawing | Project | Grounding scheme for panels, JBs, shields | Electrical / Instrument Engineer | Design |
| 29 | Instrument Process Data Sheet | Project | Defines process conditions for sizing sensors | Process Engineer | Design |
| 30 | Loop Check Sheets | Maintenance | Used to verify signal continuity and wiring | Maintenance Engineer | Commissioning |
| 31 | Instrument Calibration Reports | Maintenance | Calibration before and after results | Calibration Technician | Commissioning / Operation |
| 32 | Instrument Test Certificates | Project | Manufacturer’s QA compliance proof | Vendor / Inspector | Design / Delivery |
| 33 | Pre-Commissioning Checklists | Maintenance | Ensures installations and wiring are complete | Commissioning Engineer | Commissioning |
| 34 | Commissioning Test Procedure | Maintenance | Steps to energize and test control systems | Commissioning Lead | Commissioning |
| 35 | Cold Loop Check Reports | Maintenance | Signal check from field to DCS (no power on process) | Instrument Engineer | Commissioning |
| 36 | Hot Loop Check Reports | Maintenance | Signal and logic test under live conditions | Commissioning / Control Engineer | Commissioning |
| 37 | Shutdown Maintenance Logs | Maintenance | Records of instruments worked during turnaround | Maintenance Engineer | Operation |
| 38 | Instrument Asset Register | Maintenance | Master list of installed instruments with specs | Instrument Supervisor | Operation |
| 39 | Maintenance Procedures | Maintenance | Standard tasks like cleaning, calibration, seal check | Maintenance Planner | Operation |
| 40 | Failure Analysis Reports | Maintenance | Root cause analysis for failed instruments | Reliability Engineer | Operation |
| 41 | Instrument Obsolescence Report | Maintenance | Reviews aging or discontinued instruments | I&C Lead | Operation |
| 42 | Instrument Loop Maintenance Sheet | Maintenance | Loop-wise maintenance history and test info | Instrument Tech | Operation |
| 43 | Alarm Rationalization Report | Automation | Optimize nuisance or repetitive alarms | Control Engineer | Operation |
| 44 | Instrument Replacement Record | Maintenance | Logs changes in tags, spares, replacements | Instrument Tech | Operation |
| 45 | Spare Parts List | Maintenance | Tracks critical spares for downtime readiness | Maintenance Engineer | Operation |
| 46 | Instrument Interlock Validation Report | SIS | Functional check of safety interlocks | SIS Engineer | Commissioning |
| 47 | Preventive Maintenance Schedule | Maintenance | Periodic plan for routine checks and calibration | Maintenance Planner | Operation |
| 48 | O&M Manuals for Instruments | Maintenance | Operation, maintenance, troubleshooting guides | Vendor / Owner | Operation |
| 49 | Control System Backup Logs | Automation | Backup logs of logic, configurations | DCS Engineer | Operation |
| 50 | Firmware & Configuration Logs | Automation | Firmware version, config change history | Instrument / System Engineer | Operation |
| 51 | Safety Loop Test Reports | SIS | Proof test records for SIFs per interval | SIS / QA Engineer | Operation |
| 52 | Permit-to-Work with Instrument Checklist | Maintenance | PTW form with instrument safety precautions | Safety Officer / Instrument Tech | Operation |
| 53 | Safety Requirement Specification (SRS) | SIS | Defines each SIF, SIL, logic, and actions | Safety Engineer | Design |
| 54 | SIL Determination Report | SIS | Determines required SIL via LOPA or Risk Graph | Safety Consultant / Engineer | Design |
| 55 | SIL Verification Sheet | SIS | Verifies PFDavg, architecture matches SIL target | SIS Engineer | Design |
| 56 | Cause & Effect Matrix (SIS Specific) | SIS | Maps safety sensor to action logic | SIS / Control Engineer | Design |
| 57 | ESD Shutdown Logic Diagram | SIS | Describes emergency trip sequence in logic form | SIS / DCS Engineer | Design |
| 58 | SIS Architecture Diagram | SIS | Structure and logic solver arrangement for SIFs | SIS System Integrator | Design |
| 59 | Safety Instrument Loop Diagrams | SIS | Loop diagram with safety wiring and logic | SIS Engineer | Design |
| 60 | SIS Lifecycle Plan | SIS | Plan for managing SIS throughout its lifecycle | Functional Safety Manager | Design |
| 61 | Proof Test Procedures | SIS | Steps for verifying safety devices work correctly | Maintenance / Safety Engineer | Operation |
| 62 | SIF Validation Report | SIS | Final commissioning validation of each SIF | SIS Engineer | Commissioning |
| 63 | Logic Solver Config & Security Log | SIS | Tracks logic changes in SIS controllers | DCS / SIS Admin | Operation |
| 64 | SIS Alarm & Bypass Register | SIS | Tracks temporary overrides and safety bypasses | Shift Supervisor | Operation |
| 65 | FSA (Functional Safety Assessment) Report | SIS | Independent check at key SIS lifecycle stages | Independent Assessor | All |
| 66 | Instrument Functional Specifications | Automation | Defines functional roles of each instrument in control loops | Instrumentation Engineer | Design |
| 67 | Instrument Block Diagram | Automation | Shows the block-level arrangement of control system components | System Integrator | Design |
| 68 | PLC/DCS Configuration Files | Automation | Configuration files for control systems including I/O mapping and logic | Control System Engineer | Design |
| 69 | Instrument Alarm List | Automation | Detailed list of configured alarms including setpoints and priorities | Control Engineer | Design |
| 70 | Network Topology Diagram | Automation | Shows layout of control network including firewalls, switches, servers | IT / Automation Engineer | Design |
| 71 | Redundancy and Failover Plan | Automation | Defines system redundancy strategy for critical control functions | Automation Engineer | Design |
| 72 | Field Wiring Layout | Project | Shows routing of instrument cables from field devices to junction boxes | Instrument Designer | Design |
| 73 | Instrument DCS Tag Mapping | Automation | Links physical instrument tags to DCS internal database tags | DCS Engineer | Design |
| 74 | Control Panel Wiring Diagram | Project | Detailed terminal-to-terminal wiring inside control panels | Panel Vendor / Electrical Engineer | Design |
| 75 | Instrument Grounding Layout | Project | Shows grounding for instrument panels, cable shields, and field devices | Instrument / Electrical Engineer | Design |
| 76 | Power Distribution to Panels | Project | Provides power supply routing and load information for each control panel | Electrical Engineer | Design |
| 77 | Hazardous Area Classification Drawing | Project | Identifies classified zones (Zone 0, 1, 2) for explosion-proof installations | HSE / Electrical Engineer | Design |
| 78 | Instrument Heat Trace Layout | Project | Shows heating cable layout to prevent freezing of impulse and sample lines | Instrument Engineer | Design |
| 79 | Instrument Impulse Line Routing | Project | Details routing and support of pressure and DP impulse lines | Instrument Engineer | Design |
| 80 | Instrument Tap Location Drawing | Project | Shows take-off points for pressure, flow, and level measurements | Process / Instrument Engineer | Design |
| 81 | Instrument Vendor GA Drawing | Project | General arrangement of vendor-supplied instruments or skid packages | Vendor / Instrument Engineer | Design |
| 82 | Instrument FAT and SAT Reports | Project | Factory and site acceptance test records for panels and systems | QA / System Integrator | Commissioning |
