IP Address Schedule
What is the IP address?
A unique address that identifies a device on the internet or a local network is known as an IP address. The term “Internet Protocol,” which is abbreviated as “IP,” refers to a collection of rules that determines the format of data that is sent over the internet or a local network.
IP addresses are basically the identifiers that make it possible for information to be sent between devices on a network. They inform devices where they are and make them available for communication.
IP addresses are an essential component of any business network, and today’s businesses, both big and small, are using them in an increasing number of applications and devices at a faster rate than ever before.
What is an IP addressing schedule or IP address scheme?
An IP addressing schedule is a document that is often prepared by network or design engineers to indicate how the IP addresses will be allocated among the devices on a network based on the architecture or topology of the network in a manner that is able to offer the necessary services.
An IP address scheme is a plan or strategy for organizing and managing IP addresses on a network. The scheme typically defines how IP addresses are allocated to devices on the network and how they are divided into subnets.
An IP address scheme usually involves the following components:
Address space: The range of IP addresses that are available for use on the network.
Subnet mask: The subnet mask is used to divide the IP address space into subnets. It specifies the number of bits that are used for the network portion of the IP address and the number of bits that are used for the host portion.
Subnetting: The process of dividing a larger network into smaller sub networks, each with its own IP address range.
Address allocation: The method used to assign IP addresses to devices on the network, such as DHCP or manual assignment.
Naming convention: A naming convention may be used to help identify devices based on their IP address or subnet.
A well-designed IP address scheme can help ensure that IP addresses are used efficiently and that the network is easy to manage and troubleshoot. It can also help prevent IP address conflicts and simplify network administration.
What are the advantages of having an IP address schedule?
An IP address scheme, when properly designed and implemented, can offer several advantages for a network, including:
  • Efficient use of IP addresses: A well-designed IP address scheme can help ensure that IP addresses are used efficiently, reducing the likelihood of IP address exhaustion and the need to obtain additional IP address space.
  • Simplified network administration: A well-designed IP address scheme can make it easier to manage and troubleshoot the network by providing a clear structure for IP address allocation and subnetting.
  • Improved security: An IP address scheme can be used to segment the network into different subnets, each with its own security policies and access controls. This can help improve network security by limiting the spread of malware and other network threats.
  • Scalability: An IP address scheme that is designed with scalability in mind can make it easier to add new devices and expand the network as needed.
  • Better performance: An IP address scheme can be used to optimize network performance by ensuring that devices are located on the appropriate subnets and that network traffic is efficiently routed between subnets.
In summary, a well-designed IP address scheme can help ensure that IP addresses are used efficiently, simplify network administration, improve network security, increase scalability, and optimize network performance.
To prepare the IP schedule, it is necessary to be aware of the following:
To prepare an IP address scheme for a network, you will need to gather the following details:
  • Network topology: A network topology diagram is essential to understand how the devices are connected and the location of each device.
  • Number of devices: Determine the number of devices that will be connected to the network, including servers, workstations, printers, routers, switches, and other devices.
  • IP address range: Determine the range of IP addresses that are available for use on the network, including the subnet mask, gateway IP address, and DNS server IP addresses.
  • Subnet size: Determine the subnet size required for each subnet based on the number of devices that will be connected to each subnet.
  • IP address allocation strategy: Decide on the IP address allocation strategy to be used, such as DHCP or manual assignment.
  • Naming convention: Establish a naming convention for devices on the network based on IP address or subnet.
  • Security policies: Define security policies and access controls for each subnet, including firewalls and other security devices.
  • Future growth: Plan for future growth by leaving room for additional devices, subnets, and IP address ranges.
Once you have gathered this information, you can use an IP address scheme generator or create a custom IP address plan that takes into account the specific requirements of your network. It’s important to regularly review and update the IP address scheme as the network grows and changes to ensure that it continues to meet the needs of the organization.
What are the key distinctions between a public IP address and a private IP address?
A public IP address is an IP address that is unique around the world and can be used to connect to the Internet or offer services over it.
Private IP addresses are those that are set aside for private networks and are usually used for a company’s internal network. Before users can connect to the Internet, these ranges of IP addresses must be changed to public IP addresses with tools like Network Address Translation (NAT).
There are various IP address scheme generators available online that can help you create a custom IP address scheme for your network. Here are a few options you can explore:
SolarWinds IP Address Tracker:
SolarWinds IP Address Tracker is a free tool that can help you plan, track, and manage IP address usage on your network. It includes an IP address scheme generator that can create a custom IP address plan based on your network requirements.
GestióIP IPAM:
GestióIP IP Address Management (IPAM) is a free, open-source tool that can help you manage IP addresses on your network. It includes an IP address scheme generator that can create a custom IP address plan based on your network topology, subnet size, and other parameters.
IPPlan:
IPPlan is an open-source IP address management tool that can help you track and manage IP addresses on your network. It includes an IP address scheme generator that can create a custom IP address plan based on your network requirements.
Tech-FAQ IP Subnet Calculator:
The Tech-FAQ IP Subnet Calculator is a free online tool that can help you generate an IP address scheme based on your network requirements. It includes a subnet calculator that can help you divide your network into subnets and allocate IP addresses accordingly.
Before using any IP address scheme generator, it’s important to have a clear understanding of your network topology, addressing requirements, and IP address allocation strategy. This will ensure that the IP address scheme generated by the tool meets your specific needs.
Sample IP address schedule
An example of the IP address scheduling is shown in the figure below.
IP address schedule template for download
The link to download the IP address schedule creating template is provided below for your reference.
About The Author
