PLC Alarm and Trip Documentation Procedure – EPC PLC Automation Engineer Guide
This document outlines a PLC-focused, auditable process for creating, documenting, testing, and transferring PLC alarms and trips in EPC projects. It sets explicit rules for who is responsible for what, how often testing should happen, and what must be delivered to get rid of hidden trips, cut down on annoying alarms, and make sure that PLC and HMI always work the same way. The technique is for PLC automation engineers, HMI engineers, instrument engineers, and commissioning teams, and it helps with FAT, SAT, and commissioning tasks.
NFPA 72 Explained Finally: Method Statement for Addressable Fire Alarm System Installation, Testing and Commissioning as per NFPA 72
The purpose of this document is to establish a standardized PLC alarm and trip documentation procedure that:
  • Eliminates undocumented logic and “hidden trips”
  • Prevents nuisance alarms and spurious trips
  • Ensures consistent PLC-HMI alarm behavior
  • Creates auditable FAT/SAT records
  • Enables smooth EPC handover to operations and maintenance
This procedure is written from a PLC automation engineer’s perspective, focusing on PLC code, tags, logic, testability, and traceability  not plant operations theory.
This procedure applies to:
  • PLC-implemented alarms (process, equipment, diagnostic)
  • PLC-implemented trips and interlocks
  • PLC interface signals to SIS or external protection systems
  • PLC → HMI/DCS alarm mapping and acknowledgement logic
  • FAT, SAT, and commissioning documentation
Explicit exclusions
  • SIS logic design (IEC 61508 / 61511 calculations)
  • DCS alarm management philosophy
  • Operator training manuals
Stop Wrong Detector Placement: Fire Alarm Detector Coverage Calculator – Professional Excel Tool for Accurate Detector Placement
IEC 61508 – Functional safety of electrical, electronic, and programmable electronic systems
IEC 61511 – Functional safety for the process industry sector (SIS)
ISA-18.2 – Management of Alarm Systems for the Process Industries
Company Engineering Document Control and Alarm Philosophy Standards
PLC vendor programming and HMI configuration manuals
Most Engineers Get Alarms Wrong: Guide to Industrial Process Alarms in Control Systems: Types, Classifications, and Management Methods
TermPLC-Specific Meaning
Alarm BitBoolean tag generated inside PLC logic
Trip BitBoolean tag that forces output OFF or blocks operation
Latched TripTrip requiring manual reset after condition clears
Non-Latched TripAuto-reset trip when condition normalizes
Alarm SuppressionPLC logic disabling alarms during maintenance
First-Out AlarmPLC logic identifying first initiating cause
Maintenance BypassControlled PLC bypass with logging
Alarm Checklist Everyone Misses: DCS Alarm Management Checklist
What are alarm, trip point, and alarm priority in DCS & PLC?
Critical: Immediate action required. Failure to respond may cause plant shutdown, equipment damage, or safety risk.
High: Prompt operator action required to prevent process upset or equipment stress.
Low: Informational or advisory alarm for maintenance or monitoring.
HMI Alarms Done Right: Human Machine Interface Alarms (HMI Alarms)
RoleResponsibility
EPC PLC LeadAlarm philosophy, logic architecture, documentation
PLC ProgrammerImplement alarm & trip logic, comments, tag attributes
Instrument EngineerValidate input range, fail states, scaling
HMI EngineerAlarm banner behavior, priority colors, ack logic
FAT TeamExecute test cases, record deviations
Commissioning EngineerSAT validation, final acceptance
Document ControlRevisioning and handover package
Can You Pass This Trip?: Gas Turbine Start Interlock & Trip Test Procedure – Advanced Quiz
Alarm & Trip Identification Workflow
Classify every PLC input:
  • Analog (process)
  • Digital (status/interlock)
  • Communication health
  • Internal PLC diagnostics
QuestionIf YESIf NO
Can operator correct without stopping?AlarmTrip
Equipment damage risk?TripAlarm
Personnel safety risk?SIS or PLC-interfaceAlarm
  • Absolute (High / Low)
  • Deviation
  • Rate-of-Change
  • Bad PV / Sensor failure
  • Watchdog / heartbeat loss
Permissive Logic Most Ignore: Understanding Permissive Logic and Trip Interlocks in Industrial Systems
PLC Alarm and Trip Tagging Convention
No alarm or trip exists without a documented tag.
<SignalType>_<LoopID>_<Condition>_<ALM/TRIP>
  • AI_305_FLOW_LOW_ALM
  • AI_305_FLOW_LOWLOW_TRIP
  • DI_410_MOTOR_TRIP_FB
  • COMM_PLC1_HMI_TIMEOUT_ALM
  • Description
  • Priority
  • Ack Required (Yes/No)
  • Latched (Yes/No)
  • Test Frequency
  • Owner Discipline
  • Bypass Allowed (Yes/No)
Each PLC alarm or trip tag shall include tag name, description, priority, acknowledgement requirement, latching behavior, test frequency, owner discipline, bypass permission, PLC address, data type, fail-safe state, and engineering comments. No alarm or trip shall be accepted without a completed attribute record.
PLC Permissives Fail Here: PLC Permissive Logic Troubleshooting Procedure for Instrumentation Engineers
Alarm & Trip Matrix - Master Configuration and Testing Document
The alarm matrix is the master document for PLC alarm and trip configuration and testing.
TagDescriptionPriorityPLC Condition (Logic)Alarm or TripHMI MessageAcknowledgement RequiredTest Frequency
PB_P101_FLW_ALM_001Pump P101 low flowHighFlow < 10 percent for 15 sAlarmP101 LOW FLOWYesMonthly
PB_P101_TMP_TRP_001Pump P101 high temperatureCriticalTemp > 90 C for 3 sTripP101 OVER TEMP TRIPNoCommissioning Annual
HT101_PRES_ALM_002Heater high pressureMediumPressure > 2.0 bar for 10 sAlarmHT101 HIGH PRESSUREYesQuarterly
V102_POS_ALM_003Control valve position faultHighCmd ≠ feedback for 5 sAlarmV102 POSITION FAULTYesMonthly
C101_LEV_TRP_004Sump high high levelCriticalHH level and pump failTripC101 LEVEL HI HINoMonthly
G01_OC_TRP_005Generator overcurrentCriticalCurrent > 120 percentTripG01 OVERCURRENT TRIPNoAnnual
F101_VIB_ALM_006Filter vibration highLowVibration > limit for 10 sAlarmF101 VIBRATIONYesMonthly
The alarm and trip matrix shall be maintained as the single source of truth for all PLC alarms and trips. Any PLC logic, HMI alarm, or test case without a corresponding entry in the alarm matrix is not permitted.
Dead Zero Can Destroy Loops: Beyond Zero: Understanding the Dead Zero Problem in Industrial Analog Signals
PLC Alarm & Trip Logic Design Rules
Never embed alarm logic directly inside output rung
Always separate:
  • Detection
  • Latching
  • Reset
  • Output action
Use debounce timers for all analog alarms
Use rising-edge detection for first-out logic
Grounding Mistakes Causing Failures: Grounding and Bonding in Instrumentation and Control Systems
Alarm Detection
IF AI_FLOW < FLOW_LOW_SP THEN
  T_FLOW_LOW(IN:=TRUE, PT:=8s)
ELSE
  T_FLOW_LOW(IN:=FALSE)
END_IF
IF T_FLOW_LOW.Q THEN
  FLOW_LOW_ALM := TRUE
END_IF
Trip Logic (Latched)
IF AI_FLOW < FLOW_LL_SP AND NOT BYPASS_FLOW THEN
  FLOW_LL_TRIP := TRUE
END_IF
Trip Reset
IF RESET_CMD AND AI_FLOW > FLOW_LOW_SP THEN
  FLOW_LL_TRIP := FALSE
END_IF
Output Interlock
IF FLOW_LL_TRIP THEN
  MOTOR_RUN_CMD := FALSE
END_IF
PLC Scaling Errors Exposed: PLC Raw Count Calculator: Comparison with PLC Internal Scaling Blocks, Real-World Use Cases and Practical Benefits
  • One-to-one tag mapping (no derived HMI alarms)
  • HMI must not create logic-based alarms
  • PLC controls:
    • Priority
    • Ack requirement
    • Latched state
  • HMI only displays and acknowledges
Alarm messages shall be short, clear, and action-oriented. Messages shall identify the equipment and condition without abbreviations that operators may misinterpret. Alarm logic shall not be implemented in the HMI. The HMI shall only display, acknowledge, and log PLC-generated alarms.
Panels Fail Without This: Running Inspection Checklist of PLC Components in Control Panels
  • Before testing, look over the approved alarm matrix.
  • Check that the instruments are calibrated and that the signals are correct.
  • Use calibrated sources or PLC forcing to make alarm and trip circumstances happen.
  • Check the PLC’s detection time, latch behavior, and interlock logic.
  • Confirm final output actions such as motor stop or valve closure.
  • Verify HMI message text, priority, audible alarm, and acknowledgement behavior.
  • Verify alarm logging, timestamps, and operator identification.
  • Get things back to normal and check to see whether the reset works.
  • Write down the results and get the witness to sign off.
A documented test case that includes the test case ID, tag name, objective, preconditions, test procedures, expected results, actual results, tester name, date, and witness signature must be used to test each alert and trip. Testing without written evidence is not acceptable.
This PLC Rules Industry: Which PLC is Mostly used in the Automation Industry?
Test Phase / ItemAlarm / Trip CategoryPLC Scope CoveredMinimum Test FrequencyTest Method (PLC-Focused)Records / Evidence Required
Commissioning (FAT / SAT)All alarms and all tripsAll PLC alarm bitsAll PLC trip logicHMI alarm mappingAcknowledgement behaviorOutput interlocksMandatory (100%)Simulate inputs / force bitsValidate PLC logic executionVerify HMI banner, priority, and message textVerify trip action and reset logicSigned FAT/SAT test sheetsPLC_Trip_Test_Record_YYYYMMDD.pdfUpdated Alarm Matrix
Monthly TestingOperational alarms & non-critical tripsProcess alarmsEquipment status alarmsNon-latched tripsMonthlyInput simulation or value forcingTimer and debounce verificationHMI alarm acknowledge testMonthly alarm test logAlarm acknowledgment verification record
Quarterly TestingMedium-priority alarms & HMI verificationMedium-priority alarm logicHMI priority color codingAlarm text consistencyQuarterlyCross-check PLC alarm matrix vs HMI configurationSimulate alarm to verify correct banner and priorityHMI-PLC cross-verification reportUpdated alarm matrix (if modified)
Quarterly TestingCritical trips (PLC-implemented)Latched trip logicInterlock logicReset permissivesQuarterlySimulate initiating conditionVerify forced output OFFVerify trip latch and manual resetTrip proof test recordPLC event log snapshot
Annual TestingPLC-implemented safety functions (Interface to SIS)PLC-SIS interface signalsHardwired and soft interlocksFirst-out alarmsAnnuallyCoordinated test with SIS team• PLC signal injection and feedback confirmationJoint PLC-SIS test certificateSafety coordination test report
Diagnostic TestingDiagnostic alarmsSensor failure detectionBad PV / out-of-range logicInternal PLC diagnosticsMonthlySimulate signal fault / disconnect inputVerify alarm generation and HMI indicationDiagnostic alarm test log
Watchdog / Communication TestingPLC-HMI / PLC-PLC communicationsHeartbeat logicCommunication timeout alarmsWeeklyNetwork interruption simulationTimeout value verification• Communication alarm test record
Post-Maintenance TestingAny affected alarm or tripModified logicReplaced instrumentsRewired I/OMandatory (Before Return to Service)Re-execute original test caseVerify no regression in unrelated alarmsPost-maintenance proof test recordChange management approval
Configuration Change TestingAlarm / trip logic changesModified PLC rungs or blocksHMI mapping changesEvery ChangeRegression test of related alarmsVersion comparisonUpdated alarm matrix revisionChange log entry
Missing PLC Documents Cause Failures: PLC System Documentation Guide: Essential Records for Industrial Automation Success
Change Control, Post-Maintenance Validation and Regression Testing
Any maintenance activity affecting PLC logic, field instruments, wiring, or I/O shall require re-testing of affected alarms and trips before returning the equipment to service. Results shall be recorded and approved by commissioning or maintenance engineering.
  • All test results must be recorded no verbal acceptance.
  • Store records in document control / EDMS with revision control.
  • Each record must include:
    • Date & time
    • PLC program version
    • Tester name & signature
    • Pass / fail status
    • Observations & corrective actions
  • Typical filenames:
    • PLC_Alarm_Matrix_vX.xlsx
    • PLC_Trip_Test_Record_YYYYMMDD.pdf
    • PLC_Post_Maintenance_Test_YYYYMMDD.pdf
Any modification to alarm or trip logic shall follow formal change management. The change record shall include reason for change, affected tags, impact assessment, updated test results, revised alarm matrix, and approval from the EPC PLC lead. Version numbers shall be incremented for every approved change.
Hot Standby Saves Shutdowns: Hot Standby in PLC Systems: Architecture, Working, and Benefits
  • Alarm not displayed on HMI: Verify PLC tag mapping, communication status, and alarm enable bits.
  • Spurious alarms or trips: Check signal noise, grounding, debounce timers, and filtering.
  • Alarm goes off without being acknowledged: Check the latch logic and how it handles acknowledgments.
  • Intermittent alarms: Turn on event logging and get raw process information when an alert goes off.
Analog Scaling Mistakes Engineers Make: Scaling Analog Values in Industrial Automation (PLC)
Mandatory EPC handover bundle:
  • Send the signed test records and the approved alarm matrix.
  • Use version control on every document.
  • Keep a record of any changes to alarms or trips.
  • Get engineering’s okay before making any changes to tags or logic.
  • Keep old versions for reference for auditing and maintaining.
NO vs NC – Costly Mistake: Understanding NO vs NC Contacts is key for Logic Writing in PLC Programming
Download: PLC Alarm & Trip Test Checklist and Templates
This Excel checklist gives EPC projects a disciplined and verifiable way to record, test, and hand over PLC alarms and trips. It makes sure that the PLC and HMI always work the same way, gets rid of undocumented logic, and helps with FAT, SAT, and commissioning tasks. It was made for PLC automation engineers and helps make sure that everything works right and that the EPC handover is clean.
Includes:
  • Alarm identification checklist
  • FAT/SAT test sheets
  • Bypass & suppression log
  • Revision control sheet
Download the PLC Alarm & Trip Test Checklist (automationforum.co) and join our professional forum at automationforum.co to access EPC-grade PLC templates, alarm matrices, and peer-reviewed practices.
Why 24V Prevents Failures: Why is 24 Volts Mostly used in Industrial PLC Systems?
PLC alarm and trip logic changes shall be restricted to authorized personnel only. Forcing of alarm or trip tags shall be logged with user name, date, time, and reason. Remote access to PLC systems shall comply with company cybersecurity policies.
PLC alarms and trips should never be used instead of SIS protections. All PLC logic that has to deal with safety must be explicitly marked, written down, tested, and included into the SIS design. For safe and reliable plant operation, paperwork and testing must be done on a regular basis.
Ladder Rules You Must Follow: Top 6 Important Rules for PLC Ladder Diagram Programming
A PLC alarm is a programmed condition that finds an abnormal state of equipment or process. It tells the operator to take action through HMI or DCS. Alarms can be latched or not latched, and you normally have to recognize them.
An alarm and trip schedule is a documented list of all PLC alarms and trips with conditions priorities actions and test frequency. It is commonly maintained as an alarm or trip matrix. It is used during design testing commissioning and maintenance.
A PLC reads inputs from field devices executes the control logic and updates outputs. It communicates status to HMI or DCS and repeats this scan continuously. The entire scan cycle runs in milliseconds.
Use proper grounding shielding and surge protection for PLC systems. Apply access control backups and change management for programs. Always follow lockout tagout procedures during testing and maintenance.
Ensure proper earthing and power protection. Apply lockout tagout before panel work. Restrict PLC program access with passwords. Verify wiring and I O before energizing. Maintain updated backups and documentation.
The PLC performs an input scan to read signals. It executes the control program logic. It updates output signals to field devices. Communication and diagnostics complete the scan cycle.
PLC Algorithms Most Misuse: Implementation of Control Algorithms in PLC Programming
