Gas Turbine Start Interlock & Trip Test Procedure – Advanced Quiz
Starting up a gas turbine is the most dangerous part of the operation since the speed, temperature, and fuel energy release change quickly. To keep these hazards in check, turbine control systems use start permissives, interlocks, and safety trip logic that is always on. Before fuel is added, start permissives make sure that important auxiliary systems are ready. Trip logic safeguards the turbine from dangerous operating circumstances during acceleration and operation. If lubrication, fuel handling, speed feedback, or combustion monitoring don’t work right, it could cause serious mechanical damage or safety problems. So, for safe commissioning, dependable startup, and long-term turbine integrity, it is very important to fully grasp starter interlocks and trip test methods.
Instrumentation engineers, commissioning specialists, and turbine starter professionals should take this advanced quiz. The questions are based on real startup sequences, protection philosophies, and trip testing methods utilized in running plants. Taking this quiz will help you get better at checking permissives, figuring out how protection works, and securely starting up turbines and doing trip testing.
Gas Turbine Start Interlock & Trip Logic
The most critical commissioning check before first fire is:
Fuel admission is typically enabled after:
Trip bypass during startup is:
Seal air pressure low during startup can cause:
Loss of speed signal during startup typically results in:
Why are trip tests often done at zero or low speed?
Hardware trip testing is preferred when:
Trip test simulation using software forcing is mainly used to:
During startup, alarms typically:
2oo3 voting logic is mainly used to:
A fail-safe design philosophy means:
Start interlocks differ from trips because interlocks:
Which trip remains active throughout startup and normal operation?
Emergency Stop (ESD) activated during startup will:
Overspeed protection is typically implemented as:
Speed pickup validation during startup is critical because:
Exhaust temperature (TTX) high during startup usually causes:
Failure to detect flame within the ignition window results in:
Flame detection permissive ensures that:
What is the purpose of fuel valve proving logic during startup?
Fuel gas pressure low during startup should result in:
Turning gear must be disengaged before startup primarily to:
Why is lube oil temperature included as a startup interlock?
Low lube oil pressure during startup typically results in:
What is the primary purpose of start permissive logic during gas turbine startup?
The average score is 59%
