Guide to Industrial Process Alarms in Control Systems: Types, Classifications, and Management Methods
Process alarms are essential parts of industrial control systems because they provide early alerts to anomalous circumstances that can cause equipment damage, safety risks, or inefficiencies in production.
Process integrity and efficiency are maintained when operators are able to react promptly and suitably to possible problems, which is made possible by effective alarm management.
This article provides the types, classifications, and management strategies of process alarms in control systems.
Understanding the various types of alarms in control systems is essential for effective monitoring and intervention.
Alarms can be categorized based on their functionality and the specific nature of the alerts they provide:
  • Process alarms are set on when normal process parameters, such as pressure, temperature, flow rate, or level, deviate.
  • These alerts are critical to ensuring process stability and avoiding hazardous operating circumstances.
  • A process alarm might activate if the temperature in a chemical reactor exceeds a predefined threshold, indicating a potential risk of overheating.
  • Equipment alarms indicate malfunctions or failures in machinery or electrical components within the system.
  • These alarms are critical for maintaining equipment reliability and preventing mechanical or electrical breakdowns.
  • An equipment alarm might trigger if a pump fails to start, signaling a potential disruption in fluid transport within the process.
  • Administrative alarms indicate procedural or operational difficulties, such as missing maintenance schedules, noncompliance with operational rules, or deviations from standard operating procedures (SOPs).
  • An administrative alarm could alert operators if a scheduled maintenance check is overdue, ensuring that routine inspections are not overlooked.
  • Environmental alarms focus on conditions that potentially result in a breach of environmental standards, such as emissions that exceed allowable levels.
  • These alerts help to ensure that the process meets environmental regulations.
  • An environmental alarm might be triggered if the concentration of a pollutant in the exhaust gas exceeds regulatory limits, prompting immediate corrective action.
  • Safety alarms are intended to protect persons and equipment by warning operators of potentially hazardous conditions such as gas leaks, fires, or system failures.
  • These warnings are among the most urgent because of their potential impact on human safety and plant integrity.
  • A safety alarm could activate in response to a detected gas leak, requiring the immediate evacuation of personnel and shutdown of affected process systems.
  • Event alarms are registered as part of an event management system, which keeps track of major happenings within the control system.
  • These alarms may not always necessitate immediate response, but they are useful for post-event investigation.
  •  An event alarm might be logged during a system startup or shutdown, documenting the occurrence for future reference or troubleshooting.
  • Informational alarms notify operators about the system’s status without needing immediate action. These warnings contribute to situational awareness and decision-making.
  •  An informational alarm might indicate that a process variable is within its normal range but approaching a warning limit, allowing operators to take preemptive measures if necessary.
In control systems, transmitters are crucial for measuring and reporting process variables such as temperature, pressure, and flow.
The Lower Range Value (LRV) and Upper Range Value (URV) are two important concepts in transmitter functioning.
  • The LRV represents the lowest value that a transmitter is calibrated to measure accurately.
  • Any value below the LRV is outside the transmitter’s operational range and may not be reliably detected.
  • For a pressure transmitter calibrated to measure between 0 and 100 psi, the LRV would be 0 psi. If the actual pressure drops below 0 psi, the transmitter would not provide accurate readings.
  • The URV denotes the highest value that a transmitter can accurately measure. Values exceeding the URV fall outside the transmitter’s calibration range and may result in inaccurate or unreliable readings.
  •  If the same pressure transmitter has a URV of 100 psi, it will not provide accurate measurements for pressures above this limit.
  • Refer the below link for the Transmitter Calibration Span, LRV and URV Value Calculator from Measured 4 to 20 mA
  • The calibration of the LRV and URV is critical for ensuring that the transmitter gives correct data within its specified range.
  • This calibration must be reviewed on a regular basis and changed as necessary to account for changes in process conditions or sensor drift..
  • In sensitive applications, the LRV and URV settings must be carefully chosen to accommodate the predicted range of process circumstances.
  • Incorrect settings could result in unnoticed deviations or false alarms, risking safety and efficiency.
  • Alarms in a control system must be prioritised based on the severity of the circumstances they indicate.
  • This prioritisation enables operators to focus their attention on the most important concerns and take necessary action.
Alarm systems can be divided into the following groups based on priority:
  • High priority alarms indicate the most critical circumstances that demand quick attention to avoid catastrophic failures or safety issues.
  • These warnings are often connected with crucial process variables that, if not addressed, can have serious implications.
  • An alarm caused by a quick and dangerous increase in reactor pressure would be considered high priority, requiring immediate operator involvement to prevent an explosion.
  • Medium priority alerts highlight circumstances that, while not immediately harmful, have the potential to rise to high priority if not addressed swiftly. These alerts frequently provide suggestions for operational changes to ensure process stability.
  • An alarm indicating a progressive rise in temperature within a distillation column may be rated as medium priority, indicating the necessity for operational modifications to avoid overheating.
  • Low priority alarms usually indicate non-critical problems or reminders, such as routine maintenance checks or slight deviations from ideal operating parameters.
  • These warnings enable operators to complete their jobs without immediate pressure, guaranteeing long-term process health.
  •  A low priority alarm may alert operators that a filter needs to be replaced soon, allowing them to plan maintenance activities without disrupting ongoing operations.
In addition to prioritization, alarms can be classified based on the nature of the information they convey.
This classification helps operators understand the context and implications of each alarm:
  • Discrete alarms convey binary information, indicating whether a specific condition is met (on/off, open/closed, etc.). These alarms are straightforward and provide clear indications of specific states or events.
  • A discrete alarm might indicate whether a valve is fully open or closed, providing critical information for process control and safety.
  • Analog alarms provide continuous information about a process variable, such as temperature, pressure, or flow rate. These alarms typically involve thresholds or limits that trigger alerts when the variable exceeds or falls below a defined range.
  • An analog alarm might be configured to trigger if the temperature in a heat exchanger rises above a set limit, indicating a potential risk of equipment damage.
  • Dynamic alarms adjust their thresholds or behavior based on real-time changes in the process.
  • These alarms are particularly useful in systems where process conditions fluctuate frequently, allowing for more responsive and adaptive alarm management.
  • A dynamic alarm might adjust its threshold based on the rate of change of a process variable, triggering an alert if the variable changes too rapidly, even if it remains within normal operating ranges.
An effective alarm management system is built upon several critical components and properties that ensure its reliability, clarity, and effectiveness.
These elements are essential for maintaining a well-functioning alarm system that supports safe and efficient operations.
Click here for What are alarm, trip point, and alarm priority in DCS & PLC?
  • The alarm database is a comprehensive repository that stores all alarm configurations, including descriptions, priorities, and associated procedures.
  • This database is the backbone of the alarm management system, providing a centralized source of information for operators and system administrators.
  • The database allows for easy retrieval and analysis of alarm data, facilitating the identification of patterns, trends, and areas for improvement.
  • The alarm display system is the interface through which operators interact with alarms.
  • It presents alarm messages, visual indicators, and rankings, enabling operators to quickly assess the situation and respond appropriately.
  •  A well-designed alarm display system should prioritize clarity and ease of use, with features such as color-coded alerts, customizable views, and intuitive navigation.
  • Alarm suppression logic defines specific conditions under which alarms can be suppressed or delayed, reducing the occurrence of nuisance alarms.
  • Suppression logic is crucial for preventing alarm fatigue, where operators become desensitized to alarms due to frequent false or unnecessary alerts.
  • Suppression logic can be based on various criteria, such as process state, time of day, or specific operating conditions, ensuring that only relevant alarms are presented to operators.
  • Reporting and review tools are essential for analyzing alarm performance, identifying trends, and making necessary adjustments to improve system effectiveness.
  • These tools enable continuous monitoring and optimization of the alarm management system.
  • Reports can be generated on alarm frequency, response times, and operator actions, providing valuable insights for ongoing improvement and regulatory compliance.
  • Alarm messages should be clear, concise, and unambiguous, ensuring that operators can quickly understand the nature of the issue and take appropriate action. Clarity is essential for preventing confusion and ensuring timely responses.
  • Clarity can be achieved through standardized alarm descriptions, consistent use of terminology, and avoidance of technical jargon that might confuse operators.
  • Effective alarm management systems prioritize alarms based on their urgency and impact on safety and operations. Prioritization helps operators focus on the most critical issues and ensures that resources are allocated efficiently.
  • Prioritization can be achieved through a systematic classification of alarms, as discussed earlier, with clear criteria for determining the relative importance of each alarm.
  • Each alarm should have associated response protocols that outline the steps operators must follow based on the alarm type and priority.
  • These protocols are crucial for ensuring that alarms are addressed consistently and effectively.
  • Response protocols should be clearly documented and easily accessible to operators, with regular training provided to ensure familiarity and compliance.
  • All aspects of the alarm management system, including configurations, procedures, and performance data, should be thoroughly documented.
  •  Documentation is essential for regulatory compliance, auditing, and continuous improvement.
  • Documentation should be maintained in a central repository, with regular updates to reflect changes in the system or operational practices.
Implementing an effective alarm management system requires a structured and methodical approach.
The following steps outline the key points of the implementation process:
  • Conduct a thorough analysis of existing alarm systems to identify issues, inefficiencies, and areas for improvement.
  • This assessment should include feedback from operators, engineers, and system administrators.
  • Analyse alarm data, interview stakeholders, and compare current system performance to industry benchmarks and best practices.
  • Alarms should be classified based on their type, priority, and nature to ensure that they are all in line with operational goals and safety standards. This classification serves to streamline the alarm system and decreases the likelihood of alert overload.
  • Create a classification framework, categorise existing alarms, and set criteria for adding new alarms or changing current ones.
  • Create a thorough alarm design framework that includes clarity, prioritization, and appropriate response processes. This framework should be in line with industry standards and regulatory regulations.
  • Create alarm messages, set prioritization criteria, and response methods for each alert type and priority level.
  • Install and configure the alarm management system, ensuring that it is properly integrated with the existing control system and that all alarms are correctly set up.
  • Configure the alarm database, set up display systems, add suppression logic, and test the system to ensure it works properly.
  • Continuously monitor alarm performance, evaluating data to identify false alerts, trends, and opportunities for improvement. Regular monitoring is required to ensure that the alarm management system remains functional.
  • Use reporting tools to generate performance measurements, conduct regular reviews, and make system adjustments in response to operational changes or performance insights.
  • Regularly review the alarm management system to make any necessary changes in response to changes in operating situations, technological developments, or performance statistics. Continuous improvement is essential for preserving system efficacy.
  • Schedule periodic assessments, update documentation, and make system modifications based on operator feedback and performance statistics.
  • Document all procedures, changes, and performance data to ensure regulatory compliance and facilitate audits. Comprehensive documentation is critical for establishing due diligence and ensuring regulatory compliance.
  • Maintain a current documentation repository, conduct frequent audits, and ensure that any system modifications are adequately documented and justified.
A process alarm is a notification or alert generated by a process control system when a monitored variable, such as temperature, pressure, level, or flow, deviates from a predefined setpoint or acceptable range. The purpose of the alarm is to inform operators or control systems of an abnormal condition that may require intervention to ensure the safety, reliability, and efficiency of the process.
The three main types of alarms in process control are:
  • These alarms are triggered when a process variable exceeds or falls below a certain threshold.
  • Example: A “High Temperature” alarm activates if the temperature rises above the setpoint, and a “Low Pressure” alarm activates if the pressure drops below the setpoint.
  • These alarms are triggered when the difference between the actual value and the setpoint exceeds a certain limit.
  • Example: If a temperature is set to 100°C and a deviation alarm is set at ±5°C, the alarm will activate if the temperature deviates beyond 95°C or 105°C.
  • These alarms are triggered when a process variable changes at a rate that exceeds a predefined limit.
  • Example: If the pressure in a system increases too rapidly, a rate of change alarm can alert operators to a potentially dangerous situation.
Alarm indication in process control refers to how the system alerts operators to an abnormal condition. This can include:
  • Alarms are often displayed on a control panel or Human-Machine Interface (HMI) with flashing lights, color changes, or icons.
  • Sirens, buzzers, or other sound alarms may be used to draw immediate attention to a critical situation.
  • A message or description of the alarm condition may appear on the display, providing details about the nature of the issue.
A control alarm system is an integrated part of a process control system designed to monitor and alert operators of abnormal conditions or deviations in the process. The system typically includes:
  • The system continuously monitors process variables and compares them against predefined thresholds or conditions.
  • The system categorizes, prioritizes, and manages alarms based on their severity and importance. This ensures that operators focus on the most critical issues first.
  • The system provides detailed information about the alarms, including time of occurrence, the process variable involved, and the nature of the deviation.
  • Operators may be required to acknowledge alarms, indicating that they are aware of the situation and will take appropriate action.
  • The system records alarm events for historical analysis, troubleshooting, and regulatory compliance.
Refer the below link for the DCS Alarm Management Checklist
