- What are NO and NC Contacts?
- Definition of NO and NC Contacts
- What is an NO (Normally Open) Contact?
- Typical uses NO (Normally Open) Contact
- What is an NC (Normally Closed) Contact?
- Typical uses NC (Normally Closed) Contact
- Relay System Example in Automation
- Relay Deactivated
- Relay Activated
- How these Contacts Work in PLC Programming
- Example: Ladder Logic Interpretation using NO and NC Contacts
- Image 1: Programming View – Ladder Logic Design
- Image 2: Simulation View – NO Contact Active (Start Condition)
- Image 3: Simulation View – NC Contact Activated (Stop Condition)
- Application Scenarios NO and NC Contacts
- Key Design Principles in PLC Programming
- Test Your knowledge on PLC (Programmable Logic Controller)
With reference to simulation examples from programming environments, this article clarifies the concepts of NO and NC contacts and analyzes their application in PLC ladder diagrams.
An electrical relay system has two kinds of contacts: Normally Open (NO) and Normally Closed (NC). These are the only two kinds left as, at its essence, a contact can be open (off) or closed (on). Let’s examine each one’s behavior:
- Under typical circumstances, a Normally Open contact is in an open (non-conducting) state.
- It is applied when the input is triggered by the operator or process, therefore requiring action.
- In PLC ladder logic, an NO contact is symbolized as: [ ].
- Activation trigger limit switches
- Pressure or level switches acting on rising conditions
- Under typical circumstances, a Normally Closed contact is in a closed (contact) state.
- When the device is activated, the contact opens, thereby interrupting the circuit.
- Applications where the system must run by default and only stop when an interruption happens employ NC contacts.
- In PLC ladder logic, an NC contact is symbolized as: [ / ].
- Safety interlocks and door switches
- Fail-safe shutdowns
How it Works: Start Button Pressed
How it Works: Emergency Stop Button Pressed
Relay Deactivated
Relay Activated
Master the Basics of Ladder Logic: Understanding Rungs and Rails: The Foundation of PLC Ladder Logic
Controlling devices like motors, lights, and other machinery via a PLC requires both NO and NC contacts in industrial automation. Ladder logic uses particular symbols to show these contacts:
- NO Contact: [ ]
- NC Contact: [/]
Here is an easy ladder logic example of their application:
This below section explains three programming and simulation images that represent the use of NO and NC contacts in a PLC logic setup for a pump motor control application.
Refer the below link for Converting Electrical Diagrams into PLC Programs for Industrial Automation
The above depicted picture displays the programming views of a basic ladder diagram in the PLC development environment.
Get a Solid Foundation in PLC Logic: Understanding Basic Parts of Ladder Diagram (LD) in PLC Programming
Rung 0: Pump Start Logic
- Input %I0.0 represents a limit switch sensor and is configured as a Normally Open contact.
- The output %Q0.0 is labeled PUMP_START_ and is energized when %I0.0 is active (i.e., when the NO contact closes).
Avoid Costly Mistakes!: Top 6 Important Rules for PLC Ladder Diagram Programming
Rung 1: Pump Stop Logic
- Both are represented as Normally Closed contacts.
- When neither %I0.1 nor %I0.2 is actuated, the contacts remain closed, and the output %Q0.1, labeled PUMP_STOP, remains energized.
- If either input is pressed (i.e., contact opens), the rung breaks and the output de-energizes.
Interpretation of Ladder Diagram:
How Reliable is Your PLC?: Understanding PLC Redundancy: Cold, Warm & Hot Redundancy
The above shown picture demonstrates a simulation of the ladder logic under the following conditions:
- %I0.0 (LIMIT_SWITCH_SENSOR) is active. As a Normally Open contact, it is now closed, allowing the signal to pass.
- The output coil %Q0.0 (PUMP_START_) is energized.
- %I0.1 (Emergency Stop) and %I0.2 (Stop PB) are not pressed, meaning their Normally Closed contacts remain closed.
- As a result, %Q0.1 (PUMP_STOP) is also energized.
System Behavior:
- The pump is running, as both the start logic and stop logic conditions are met.
- This reflects a normal operating condition where the process continues without interruption.
Not All Racks Are the Same: Understanding PLC Racks and Chassis: Types, Differences, and Purposes
The above shown picture shows the impact of turning on the stop or emergency devices:
- %I0.0 remains active (limit switch engaged), so the NO contact stays closed.
- However, either %I0.1 (Emergency Stop) or %I0.2 (Stop PB) has been pressed.
- Pressing these inputs causes their NC contacts to open.
- The rung associated with %Q0.1 (PUMP_STOP) is now broken, resulting in a de-energized output.
Logic Made Simple: Logic Gates in PLC Programming: A Guide with Truth Tables and Ladder Logic Diagrams
System Behavior
- The STOP condition overrides the START command.
- The deactivation of the stop output simulates a halt in the pump or process, depending on how %Q0.1 is logically interpreted (e.g., controlling a stop relay or safety interlock).
Device Type | Contact Type | PLC Symbol | Functionality Description |
Start Push Button | NO | [ ] | Closes when pressed to initiate the process |
Emergency Stop PB | NC | [ / ] | Opens when pressed to stop the process immediately (fail-safe) |
Limit Switch | NO | [ ] | Closes when target is reached, triggering an operation |
Safety Door Switch | NC | [ / ] | Opens when door is opened, interrupting operation for safety |
Pressure Switch | NO or NC | Varies | Depending on design, used to start/stop operations based on pressure |
Use NO Contacts for Events and Actions
- Devices that activate on a particular event or condition change.
- Best for typical operations where activity is intentional.
Use NC Contacts for Safety and Fail-Safe Logic
- Devices that, should wiring breaks or is disconnected, must default to a safe condition.
- Guarantees that during hardware failures vital processes cease.
Hands-On Learning!: PLC Programming Example: Using Timers to Control Motors with a Single Switch
Understand Input Type and Device Logic
- Field wiring has to match PLC programming logic.
- Misunderstanding NO vs NC behavior could lead to unintentional actions.
Use Descriptive Tags
- In the ladder logic, always mark inputs and outputs explicitly.
- For instance, EM_STOP, LIMIT_SWITCH_SENSOR, PUMP_START_, etc.
In PLC programming, knowing the distinction between NO and NC contacts is absolutely vital for both functionality and safety. While NC contacts are favored for stopping processes or starting safety logic, NO contacts are usually utilized for starting activities when conditions are satisfied. Correct execution guarantees consistent system performance, improved diagnostics, and safer operation in industrial settings.
Unlock the Secrets of PLC Datasheets: How to Read the PLC Datasheet: Allen-Bradley 1762 Model Step-by-Step Guide
Control engineers, electricians, and automation technicians working on design, programming, or debugging PLC-based systems find this subject to be basic.
Refer the below link to test your knowledge on PLC (Programmable Logic Controller)
