Control Valve Authority Calculator: Calculate Valve Authority and Installed Flow Characteristic
Control valve authority is an important design parameter when selecting and evaluating a modulating control valve. A valve may have the correct rated Cv and still provide poor process control if most of the available pressure drop occurs in the piping and equipment rather than across the valve.
html = r”’ Control Valve Authority Calculator | AutomationForum.co
IEC 60534 · ANSI/ISA 75.01.01 · Installed Flow Characteristic
Valve AuthorityInstalled GainLinearEqual PercentagePump Energy
Control Valve Authority System Schematic
UPSTREAM Constant source CONTROL VALVE ΔPv SYSTEM ΔP line N = ΔPv / (ΔPv + ΔPsystem)
1. Valve Specifications
Cv
SG
gpm
The reference calculator uses rated Cv, trim characteristic, specific gravity and maximum design flow as the primary valve inputs. citeturn0search0
2. System and Process Data
psi
psi
gpm
Authority is normally evaluated at the design or fully open condition. If valve pressure drop is unknown, this tool calculates it from Qmax, Cv and SG using the standard liquid Cv relationship.
Quick Load Scenarios
Control Valve Authority Results
Valve Authority N
Valve ΔP—
System ΔP—
Total ΔP—
Pump Power Loss—
Authority Assessment
Inherent Gain vs Installed Gain
Inherent Gain at 50%—
Installed Gain at 50%—
Maximum Installed Gain—
Minimum Installed Gain—
Step by Step Engineering Calculation
ParameterCalculated Value
This calculator is an engineering analysis tool. Final control valve selection, installed characteristic verification, pump sizing and control loop tuning should use project process data, certified valve coefficients, manufacturer data and the applicable edition of IEC 60534 or ANSI/ISA 75.01.01.
Valve Authority Calculation
N = ΔPvalve / (ΔPvalve + ΔPsystem)
ΔPtotal = ΔPvalve + ΔPsystem
ΔPvalve = SG × (Qmax / Cv100)²
ΔPline = ΔPline,max × (Q / Qmax)²
Installed flow: Q = Cv(h) × √(ΔPvalve / SG)
ΔPvalve = ΔPtotal − ΔPline(Q)
The reference page defines authority as the valve pressure drop divided by the total pressure drop and states that installed characteristic distortion is evaluated with system pressure loss increasing approximately with flow squared. citeturn0view0
Engineering Interpretation
Low authority means system friction dominates the available pressure drop. The valve can lose effective control range and installed gain can vary significantly with travel.
A moderate valve pressure drop can provide useful controllability while avoiding excessive energy dissipation across the valve.
Higher authority can improve controllability but increases pressure dissipation through the valve and therefore increases pump head and hydraulic energy requirements.
The reference page explains that equal percentage trim is commonly used to counteract the installed distortion caused by decreasing valve pressure drop as flow increases. citeturn0view0
Governing Engineering Standards
Industrial process control valve flow capacity and sizing equations under installed conditions.
Flow equations for sizing control valves and relating flow coefficient to pressure drop and flow rate.
Control valve seat leakage classification and testing requirements.
Test procedure for evaluating control valve response from step inputs.
These standards are identified on the reference Control Valve Authority analyzer as governing standards for control valve sizing, selection and performance calculations. citeturn0view0
The Control Valve Authority Calculator evaluates the relationship between valve pressure drop and system pressure loss. It calculates valve authority, total pressure drop, estimated hydraulic power loss and the installed flow characteristic. It also compares inherent valve gain with installed gain for linear, equal percentage and quick opening characteristics.
This makes the calculation useful during control valve sizing, detailed engineering, EPC design reviews, commissioning and plant troubleshooting.
What Is Control Valve Authority?
Control valve authority represents the portion of the total pressure drop that occurs across the control valve at the maximum design flow.
The calculator uses:
Here, N is valve authority, ΔPvalve is the pressure drop across the control valve and ΔPsystem is the pressure loss through the rest of the system.
A low authority value means that system resistance dominates the pressure drop. The control valve therefore has less influence over the actual flow response. A higher authority means that the valve takes a larger share of the available pressure drop and has greater influence over the installed flow characteristic.
A control valve does not operate in isolation. Once installed in a process line, the pressure available across the valve changes as flow changes.
At low authority, the system pressure loss can strongly influence the valve response. A valve that appears linear during constant pressure drop testing may therefore behave very differently after installation.
This can affect control loop performance, process stability and usable valve travel.
Low authority can produce a strong distortion between the inherent valve characteristic and the installed characteristic. The result can be excessive sensitivity at part of the valve travel and insufficient sensitivity at another part.
Higher authority gives the valve greater control influence, but it also means greater pressure dissipation across the valve. That pressure loss represents hydraulic energy consumption.
The engineering objective is therefore not simply to maximize authority. The valve must provide suitable controllability while remaining compatible with process pressure conditions, energy requirements and the selected valve design.
Avoid Costly EPC Valve Selection Mistakes Before Design: Why Control Valve Characteristics Matter in EPC Instrumentation and Control Engineering
The calculator begins with the valve specifications and process conditions required for the analysis. The main inputs are rated Cv at full opening, trim characteristic, specific gravity, maximum design flow, system line loss and valve pressure drop.
Rated Cv represents the valve flow coefficient at full valve opening.
The calculator uses this value to estimate the valve pressure drop when a valve pressure drop is not entered manually.
For liquid service, the calculator uses:
The value normally comes from the valve manufacturer or the control valve sizing calculation.
The calculator provides three choices: Linear, Equal Percentage and Quick Opening.
The selected characteristic determines how the valve flow coefficient changes with valve travel.
For the linear characteristic, Cv varies approximately in proportion to valve travel.
For the equal percentage characteristic, the flow coefficient increases exponentially with travel.
For the quick opening characteristic, the calculator represents Cv using a square root relationship.
This selection is important because the inherent characteristic affects the installed flow characteristic after system pressure loss is considered.
Specific gravity represents the liquid density relative to water.
The calculator uses specific gravity when estimating valve pressure drop and calculating flow from the Cv relationship.
The value should be taken from the process design data at the relevant operating condition.
Maximum design flow is the maximum process flow used for the authority calculation.
The calculator uses this value together with rated Cv and specific gravity when estimating valve pressure drop.
Line loss represents pressure loss through the piping and associated system resistance excluding the control valve.
The calculator models this loss as increasing approximately with the square of flow:
This assumption is important because increasing flow increases system resistance and consequently changes the pressure available across the valve.
Valve Pressure Drop
Valve pressure drop can be entered directly.
If the value is left at zero, the calculator estimates it from maximum flow, rated Cv and specific gravity.
This gives the engineer a convenient way to evaluate authority when the valve pressure drop has not already been established.
The calculator provides fields for minimum operating flow and maximum valve travel for analysis.
These values are useful operating information when reviewing a control valve application. However, the current calculation logic evaluates the installed characteristic over the full zero to one hundred percent travel range and does not use the minimum flow or maximum travel fields to change the authority equation.
For detailed design review, engineers should therefore evaluate the actual operating range separately.
Calculate PSV Orifice Requirements Before Finalizing Pressure Protection: Pressure Relief Valve Sizing Calculator for PRV and PSV Orifice Calculation
Control Valve Authority Calculation Formula
The primary calculation is:
The total pressure drop is:
When valve pressure drop is estimated from Cv:
The calculator then evaluates the installed flow using:
The system pressure loss is represented as proportional to the square of flow.
The calculator therefore solves the interaction between valve capacity and system resistance rather than simply plotting the valve manufacturer’s inherent characteristic.
Inherent Versus Installed Control Valve Characteristics
The inherent characteristic represents the valve response when the pressure drop across the valve is held constant.
The installed characteristic represents the actual response after the valve is connected to the process system.
This difference is critical for control engineers.
As flow increases, system pressure loss increases. This reduces the pressure available across the control valve. Consequently, the actual flow response can become substantially different from the theoretical inherent characteristic.
The calculator displays both characteristics so the engineer can visually assess the amount of installed distortion.
Equal percentage trim is particularly important in this context because its inherent response can compensate for the nonlinear pressure distribution created by system resistance. The correct trim choice nevertheless depends on the complete process application.
Stop Hidden Valve Hysteresis From Destroying Control Performance: Top Common Causes of Hysteresis in Control Valve in Process Plants
Control Valve Inherent Gain and Installed Gain
The calculator also evaluates gain.
Inherent gain represents the change in normalized valve capacity with valve travel under the inherent characteristic.
Installed gain represents the change in normalized flow with valve travel after system resistance is included.
At fifty percent travel, the calculator reports inherent gain and installed gain. It also reports the maximum and minimum installed gain across the evaluated travel range.
This information is useful because a large variation in installed gain indicates that the process does not respond uniformly throughout the valve travel range.
For control loop engineering, this can make tuning more difficult because the effective process response changes as the valve moves.
Detect Dangerous Cavitation Before It Damages Your Control Valve: Control Valve Cavitation Calculator
Consider a liquid process application with the following design data:
ParameterValue
Rated Cv250
Specific Gravity1.0
Maximum Design Flow500 gpm
Line Loss at Maximum Flow20 psi
Entered Valve Pressure Drop0 psi
Trim CharacteristicLinear
Because the valve pressure drop is not entered, the calculator estimates it as:
ΔPvalve = SG × (Qmax / Cv)²
ΔPvalve = 1 × (500 / 250)²
ΔPvalve = 4 psi
The total pressure drop becomes:
ΔPtotal = 4 + 20
ΔPtotal = 24 psi
Valve authority is therefore:
N = 4 / 24
N = 0.167
The valve accounts for approximately 16.7 percent of the total pressure drop.
The calculator classifies this result as low authority because its assessment identifies values below 0.20 as low authority.
The estimated hydraulic power associated with the valve pressure loss is approximately 4.95 hp using the calculator’s internal power relationship.
From an engineering perspective, the result indicates that system resistance is much greater than valve resistance. The engineer should therefore review the selected Cv, available valve pressure drop, process operating range and installed characteristic before finalizing the control valve selection.
What is a Good Control Valve Authority?
A valve authority between 0.30 and 0.50 is classified by this calculator as a good control range. Lower values indicate increasing influence from system resistance, while higher values indicate greater pressure dissipation across the valve.
However, this should not be presented as a universal acceptance criterion for every control valve application. The process operating range, valve sizing, pump characteristics and control objective must also be considered.
Prevent Insufficient Actuator Torque From Causing Valve Failure: Control Valve Actuator Failure Due to Valve Torque
Valve Authority NEngineering Interpretation
Below 0.10Very low authority and strong system influence
0.10 to below 0.20Low authority and significant installed characteristic influence
0.20 to below 0.30Moderate authority requiring installed characteristic review
0.30 to 0.50Good control range according to the calculator
Above 0.50High valve influence with greater pressure dissipation
Fix AUTO Mode Instability Before It Disrupts Process Control: Why Control Valve Hunts in AUTO but Runs Smoothly in MANUAL
Obtain the maximum design flow, liquid specific gravity, piping pressure loss and available control valve data from the process and mechanical design documents.
Enter the rated Cv at full valve opening from the selected valve data.
Select Linear, Equal Percentage or Quick Opening according to the proposed valve trim.
Enter the line pressure loss at maximum design flow excluding the control valve.
Size Your Actuator Correctly Before Torque Problems Appear: Valve Actuator Sizing Calculator – Complete Engineering Guide for Torque, Safety Factor & Gear Ratio Selection
Enter the known valve pressure drop. If it is unknown, leave the value at zero so the calculator estimates it from Cv, flow and specific gravity.
Run the calculation and review valve authority, valve pressure drop, system pressure drop and total pressure drop.
Compare the inherent and installed curves and review the installed gain values.
Calculate Instrument Air Demand Before Pneumatic System Design: Air Consumption Calculator for Pneumatic Control Valves, Actuators and Instrument Air System Sizing
If the authority is low or the installed characteristic is heavily distorted, review valve sizing, trim selection and available pressure drop before accepting the valve selection.
Identify Hidden Valve Failures Before They Escalate: What Are the Most Common Failure Modes of Control Valves?
Control valve authority analysis is relevant wherever modulating valves regulate liquid flow against significant system resistance.
  • In refineries and petrochemical plants, the calculation can be used when reviewing process control valves on cooling water, process liquid and utility systems.
  • In oil and gas facilities, it can support control valve selection where pumps, piping and process equipment contribute significant pressure loss.
  • In chemical plants, the analysis can help engineers understand why a correctly sized valve may still produce poor installed control.
  • The same approach can support EPC design reviews, control valve procurement evaluations, commissioning investigations and plant troubleshooting.
Find The Real Cause Behind Persistent Valve Hunting: Control Valve Hunting Due to PID Controller: Causes, Effects, Root Analysis and Complete Troubleshooting Guide for Industrial Process Control Systems
A process engineer may encounter a valve that operates smoothly near one portion of its travel but becomes excessively sensitive or ineffective elsewhere.
Valve authority provides one possible engineering explanation.
If system resistance is high compared with valve pressure drop, the installed characteristic can differ significantly from the inherent characteristic.
If a valve appears oversized, the pressure drop across the valve may be relatively small at the required process flow. The resulting low authority should therefore be reviewed together with the selected Cv.
If excessive pressure loss occurs across the valve, the opposite problem can arise. The valve may provide strong control influence but consume more hydraulic energy.
The calculator helps separate these effects by reporting valve pressure drop, system pressure drop, total pressure drop and installed gain.
Restore Valve Response Before Production Control Is Affected: Control Valve Not Responding: Troubleshooting Guide
Plant ObservationPossible Authority Related CauseWhat to Review
Valve has little control influenceLow valve authorityValve pressure drop and system resistance
Valve is very sensitive at part travelInstalled gain variationInstalled characteristic
Valve appears oversizedExcessive CvActual operating flow and valve pressure drop
High pressure loss across valveHigh authorityValve pressure drop and hydraulic energy
Control response changes with valve positionVariable installed gainInherent and installed characteristics
Process control remains poor after tuningValve characteristic distortionAuthority and installed gain
Choose The Right Sizing Software For Better Valve Engineering: Top 10 Control Valve Sizing Software Used in Process Industries
Valve authority should be reviewed using actual process design conditions rather than relying only on nominal valve size.
  • The engineer should verify maximum flow, minimum operating flow, valve Cv, process fluid specific gravity, piping resistance and valve pressure drop.
  • The selected trim characteristic should also be considered because the installed characteristic depends on both valve behavior and system resistance.
  • Pump operating conditions are important when significant pressure loss occurs across the control valve because valve pressure loss directly affects hydraulic energy consumption.
  • For final valve selection, manufacturer Cv data and project process conditions should always take precedence over an online preliminary calculation.
Select Reliable On Off Valves Before EPC Procurement: ON OFF Control Valve Type Selection Procedure for EPC Engineering
  • Use the calculator during conceptual and detailed engineering to compare alternative valve selections.
  • During procurement, verify that the vendor supplied Cv and trim characteristic correspond to the valve being offered.
  • During commissioning, compare calculated expectations with actual measured process behavior where reliable field pressure and flow data are available.
  • During troubleshooting, do not immediately change PID tuning when the installed valve characteristic has not been evaluated. A valve with strongly varying installed gain can create a control problem that cannot be solved by tuning alone.
  • The calculator should be treated as an engineering analysis aid rather than a replacement for certified valve sizing.
The calculator also identifies FCI 70 2 for control valve seat leakage classification and ISA 75.25.01 for control valve response measurement. These standards are relevant to broader valve engineering activities, but they do not change the authority equation used by this calculator.
Get Valve Sizing Right Before Performance Problems Start: How to Properly Size Control Valves for Maximum Efficiency?
  • The calculator uses a simplified liquid flow relationship and models system pressure loss as proportional to the square of flow.
  • It does not replace a complete control valve sizing calculation for complex services.
  • The calculator does not perform a complete compressible flow sizing analysis for gas or steam service. It also does not independently evaluate cavitation, flashing, viscosity correction, piping geometry factors or detailed manufacturer specific valve coefficients.
  • Final engineering verification should therefore use the applicable project process data, certified valve manufacturer information and the appropriate sizing methodology.
  • The calculated authority should also not be treated as a universal acceptance value. Practical authority requirements depend on the process application, valve type, control objective and system design.
Verify Actual Cv Before Making Critical Sizing Decisions: Why Measuring Control Valve Cv is Essential for Proper Valve Sizing ?
Control valve authority is the ratio of valve pressure drop to total pressure drop in the system.
It indicates how strongly the control valve influences the installed flow response.
Calculate valve authority using N = ΔPvalve / (ΔPvalve + ΔPsystem).
The result shows the proportion of total pressure drop occurring across the control valve.
The calculator classifies an authority value from 0.30 to 0.50 as a good control range.
The final selection should also consider process conditions, valve sizing and control requirements.
Calibrate Your Control Valve For Reliable Process Response: Control Valve Calibration Procedure
For a given flow and specific gravity, a higher Cv produces a lower valve pressure drop.
Lower valve pressure drop can reduce valve authority when system pressure loss remains unchanged.
Low authority occurs when system pressure loss is large compared with the pressure drop across the valve.
An oversized valve or high system resistance can therefore contribute to low authority.
Valve authority helps engineers understand how strongly the valve influences the actual installed flow response.
It is useful for control valve sizing, trim selection, commissioning and troubleshooting.
Predict Valve Noise Before It Becomes A Plant Issue: Control Valve Noise Prediction Calculator – IEC 60534 Based Engineering Tool
The inherent characteristic describes valve behavior at a constant pressure drop across the valve.
The installed characteristic includes the effect of changing system pressure loss during actual operation.
The three characteristics used by the calculator are Linear, Equal Percentage and Quick Opening.
They define how the valve flow coefficient changes as the valve moves through its travel range.
For liquid service, Cv can be determined from flow rate, pressure drop and fluid specific gravity.
The calculator uses the relationship ΔPvalve = SG × (Qmax / Cv100)² to estimate valve pressure drop.
The calculator represents equal percentage Cv using Cv(h) = Cv × 50^(h − 1), where h represents normalized travel.
Installed flow is then evaluated using valve capacity, pressure drop and specific gravity while considering system resistance.
Yes, low authority can cause significant distortion between the inherent and installed valve characteristics.
This can produce changing installed gain and make consistent control loop tuning more difficult.
Yes, excessive authority can cause a larger pressure drop across the valve and increase hydraulic energy consumption.
Valve selection should balance controllability, pressure loss, process requirements and system resistance.
Determine Required Valve Travel Before Final Control Selection: Control Valve Stroke Length Calculator
Control valve authority provides a practical way to understand how much influence a control valve has over the process pressure drop.
The Control Valve Authority Calculator goes beyond the basic authority equation by evaluating valve pressure drop, system pressure loss, total pressure drop, estimated hydraulic power, installed flow characteristic and installed gain.
For instrumentation and control engineers, the important point is that a valve should be evaluated as part of the complete process system. Rated Cv alone does not describe how the valve will behave after installation.
Use the authority result together with process conditions, valve manufacturer data, trim characteristics, pump conditions and actual operating requirements. This provides a stronger basis for control valve selection, commissioning investigation and process control troubleshooting.
