100+ Online Instrumentation Calculators Collections
Explore 100+ online instrumentation calculators, Excel tools, and third-party resources for precise engineering solutions, simplifying complex calculations across diverse industrial applications.
Instrumentation Calculators 1
Instrumentation Signal Calculators
These signal calculators simplify instrumentation tasks by seamlessly converting between process variables, 4-20mA signals, and 3-15 psi signals, ensuring precision and compatibility in diverse industrial applications.
1. PV to 4-20mA scaling calculator
2.4-20mA to PV scaling calculator
3.Calculator for 3-15 psi signal to 4- 20mA signal conversion
4.Calculator for 4- 20mA signal to 3-15 psi signal conversion
5. 4 to 20 mA Transmitter Output Process Value Calculator
6. Frequency(Hz) to 4 to 20 mA Signal Conversion Calculator
7. Transmitter Calibration Span, LRV and URV Value Calculator from Measured 4 to 20 mA
8. Flowrate to Differential Pressure (DP) Calculator
9. Square Root Extraction Signal to Linear Signal Converter: 4-20mA, 3-15 Psi, 1-5 Volt Signals
10. Linear to Square Root Extraction Signal Converter: 4-20mA, 3-15 Psi, 1-5 Volt Signals
11. 4 – 20 mA to 1 – 5V, 3 -15 Psi and 0.2 – 1.0 Bar Signal Conversion Calculator
PLC Digital Signal Calculators
These PLC digital signal calculators streamline industrial automation by converting between 4-20mA signals, 1-5 Volt outputs, raw counts, and engineering units, enhancing precision and control system efficiency.
1.Calculator for 4-20mA Signal to 1- 5 Volt and PLC 16-bit Raw Count Values
2.Calculator/ Instrumentationtool for Raw Counts value to Engineering Units
3.Extended high and low limit calculator
4.Split Range Calculator – Control system
Level Measurement Calculators
Streamline level measurement processes with this comprehensive suite of calculators. From DP calculations for various tank configurations to interface and density measurements, optimize your instrumentation with precision and ease.
1.DP calculator for open tank level measurements
2.DP calculator for Zero suppression – open tank level measurement
3.DP calculator for Dry leg Level measurement – closed tank
4.DP calculator for Closed tank level measurement – Wet Leg system – Transmitter installed in zero based direct mount application
5.Closed tank level measurement – Wet Leg System – Transmitter installed in non-zero based remote mount application
6.DP calculator for Interface level measurement
7.Interface level calculator from Differential pressure (DP)
8.DP calculator for bubbler method Liquid Level measurement – Transmitter installed with single Bubble Tube
9.DP calculator for bubbler method Interface level measurement – Transmitter installed with Constant Tank Level and single Bubble Tube
10.DP calculator for Density measurement – Transmitter installed With Varying Tank Level and two Bubble Tubes
11.DP calculator for Interface level measurement – Transmitter installed with Varying Tank Level and two Bubble Tubes
12.DP calculator for Density measurement – transmitter installed With Constant Tank Level and single Bubble Tube
13.Displacer type interface level transmitter dry calibration weight calculator
14.Displacer type level transmitter dry calibration weight calculator
15.Ultrasonic Level Transmitter Distance Calculator
16. Capacitance to Level Conversion Calculator for Level Transmitters
17. Radar Level Transmitter Frequency Shift Calculator (Doppler Effect)
Flow Measurement Calculators
Enhance flow measurement accuracy with these calculators. Re-range DP flow transmitters, compute outputs, and determine flow velocities using the Pitot tube, ensuring optimal performance in diverse industrial applications.
  1. DP Flow Transmitter Re-Ranging Calculator
  2. Differential pressure Flow Transmitter Output Calculator
  3. Pitot tube flow velocity calculator
  4. Orifice Plate Flow Rate Calculator
  5. Gas Flow Conversion Calculator
  6. Turbine Flow Meter Coefficient and Scaling Factor Calculator
Pressure Measurement Calculators
Optimize pressure measurement efficiency with this calculator, precisely computing pressure loss in instrument air lines for accurate industrial instrumentation.
1.Calculator for Pressure Loss in instrument Air line
2.PSIG to PSIA Conversion Calculator
  1. pH to Voltage Conversion Calculator
Temperature Measurement Calculators
Maximize temperature measurement precision with RTD calculators. Convert resistance to process temperature and vice versa, ensuring accurate readings in diverse industrial applications.
1.RTD Calculator: Converting Measured Resistance to Process Temperature
2.RTD Calculator: Converting Process Temperature to measured Output Resistance
3. RTD Class A Tolerance Calculator
4. RTD Class B Tolerance Calculator
Use our Control Valve Calculators for accurate Kv to Cv and Cv to Kv conversions to optimize valve performance.
  1. Control Valve Kv to Cv Conversion Calculator
  2. Control valve Cv to Kv Conversion Calculator
  3. Cv to Cg for Gases Conversion Calculator: Control Valve Sizing
  4. Control Valve Opening Percentage Calculator for Precise Flow Control Rate Adjustment for Instrumentation Project Engineers
Weighing Measurement Calculators
Enhance weighing accuracy with this calculator, precisely determining load cell millivolt output for optimal measurements in industrial
1.Load cell millivolt (mV) output calculator
Displacement Measurement Calculators
Improve displacement measurements using this calculator, precisely computing LVDT output voltage for accurate industrial instrumentation in diverse applications.
1.Linear Variable Differential Transformer (LVDT) Output Voltage Calculator
2. Vibration Unit Conversion Calculator
Calibration Activity Calculators
Ensure calibration precision with this calculator, identifying and quantifying errors in instruments for accurate adjustments in calibration activities.
1.Calibration Error Calculator for Instruments
2.Instrument Calibration Verification Calculator
3.Online Calibration Test Points Value Calculator
4.Instrument Accuracy Calculator
Process Measurement Calculators
Optimize efficiency with the Unloaded Steam Cost calculator for precise evaluation in process measurement, ensuring cost-effective operations in steam-related industrial processes.
1.Unloaded Steam Cost calculator
Explore a series of pressure unit conversion calculators, enabling quick and accurate conversions between various pressure units
  1. Millibar (mBar) to Psi Pressure Unit Conversion Calculator
  2. Psi to Millibar (mBar) Pressure Unit Conversion Calculator
  3. Psi to Kg/cm² Pressure Unit Conversion Calculator
  4. Kg/cm² to Psi Pressure Unit Conversion Calculator
  5. Bar to Psi Pressure Unit Conversion Calculator
  6. Psi to KPa Pressure Unit Conversion Calculator
  7. Kpa to Psi Pressure Unit Conversion Calculator
  8. Pascal(Pa) to Bar Conversion Calculator
  9. Millimeter of Mercury (mmHg) to Psi Pressure Unit Conversion Calculator
  10. Psi to Millimeter of Mercury (mmHg) Pressure Unit Conversion Calculator
  11. Bar to Pascal (Pa) Conversion Calculator
  12. Psi to Pascal (Pa) Conversion Calculator
  13. Pascal (Pa) to Psi Conversion Calculator
  14. Psi to Standard Atmospheric Pressure (atm) Conversion Calculator
  15. Standard Atmospheric Pressure (atm) to Psi Conversion Calculator
  16. Torr to Psi Pressure Unit Conversion Calculator
  17. Psi to Torr Pressure Unit Conversion Calculator
  18. Bar to Millimeter of Mercury (mmHg) Pressure Unit Conversion Calculator
  19. Millimeter of Mercury (mmHg) to Bar Pressure Unit Conversion Calculator
  20. Psi to Inch of Water (inH2O) Pressure Unit Conversion Calculator
  21. Inch of Water (inH2O) to Psi Pressure Unit Conversion Calculator
  22. Standard Atmospheric Pressure (atm) to Kilopascal (kPa) Conversion Calculator
  23. Kilopascal (kPa) to Standard Atmospheric Pressure (atm) Conversion Calculator
  24. Millibar (mBar) to Standard Atmospheric Pressure (atm) Conversion Calculator
  25. Standard Atmospheric Pressure (atm) to Millibar (mBar) Conversion Calculator
  26. Millibar (mBar) to Torr Pressure Unit Conversion Calculator
  27. Megapascal (MPa) to Bar Pressure Unit Conversion Calculator
  28. Torr to Millibar (mBar) Pressure Unit Conversion Calculator
  29. Bar to Megapascal (MPa) Pressure Unit Conversion Calculator
  30. Torr to Bar Pressure Unit Conversion Calculator
  31. Bar to Torr Pressure Unit Conversion Calculator
  32. Psi to Megapascal (MPa) Pressure Unit Conversion Calculator
  33. Megapascal (MPa) to Psi Pressure Unit Conversion Calculator
  34. Kilopascal (kPa) to Bar Pressure Unit Conversion Calculator
  35. Bar to Kilopascal (kPa) Pressure Unit Conversion Calculator
  36. Millibar to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
  37. Kg/cm² to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
  38. Millimeter of Water Column (mmWC) to Kg/cm² Pressure Unit Conversion Calculator
  39. Psi to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
  40. Millimeter of Water Column (mmWC) to Psi Pressure Unit Conversion Calculator
  41. Millimeter of Water Column (mmWC) to Bar Pressure Unit Conversion Calculator
  42. Bar to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
  43. Standard Atmospheric Pressure (atm) to Kilopascal (kPa) Conversion Calculator
  44. Kilopascal (kPa) to Standard Atmospheric Pressure (atm) Conversion Calculator
  45. Millimeter of Mercury (mmHg) to Torr Pressure Unit Conversion Calculator
  46. Millimeter of Mercury(mmHg) to Millibar(mbar) Pressure Unit Conversion Calculator
  47. Atmospheres (atm) to Millimeter of Mercury (mmHg) Pressure Unit Conversion Calculator
  48. Millibar (mbar) to Millimeter of Mercury (mmHg) Pressure Unit Conversion Calculator
  49. Millimeter of Mercury (mmHg) to Atmospheres (atm) Pressure Unit Conversion Calculator
  50. Pascals (Pa) to Millimeter of Mercury (mmHg) Pressure Unit Conversion Calculator
  51. Millimeter of Mercury (mmHg) to Pascals (Pa) Pressure Unit Conversion Calculator
  52. Millimeter of Water Column (mmWC) to Millimeter of Mercury (mmHg) Pressure Unit Conversion Calculator
  53. Millimeter of Mercury (mmHg) to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
  54. Kilopascal (kPa) to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
  55. Millimeter of Water Column (mmWC) to Kilopascal (kPa) Pressure Unit Conversion Calculator
  56. Millimeter of Water Column (mmWC) to Millibar Pressure Unit Conversion Calculator
  57. Torr to Millimeter of Mercury (mmHg) Pressure Unit Conversion Calculator
  58. Pascal (Pa) to Megapascal (MPa) Pressure Unit Conversion Calculator
  59. Megapascal (MPa) to Pascal (Pa) Pressure Unit Conversion Calculator
  60. Millibar (mBar) to Kilopascal (kPa) Pressure Unit Conversion Calculator
  61. Kilopascal (kPa) to Millibar (mBar) Pressure Unit Conversion Calculator
  62. Pascal (Pa) to Inch of Water (inH₂O) Pressure Unit Conversion Calculator
  63. Pascal (Pa) to Millibar (mbar) Pressure Unit Conversion Calculator
  64. Atmosphere (atm) to Bar Pressure Unit Conversion Calculator
  65. Millibar (mbar) to Pascal (Pa) Pressure Unit Conversion Calculator
  66. Pound per Square Foot (psf) to Pounds per Square Inch (psi) Pressure Unit Conversion Calculator
  67. Inch of Water (inH₂O) to Millimeter of Mercury (mmHg) Pressure Unit Conversion Calculator
  68. Pounds per Square Inch (psi) to Pounds per Square Foot (psf) Pressure Unit Conversion Calculator
  69. Millimeter of Mercury (mmHg) to Inch of Water (inH₂O) Pressure Unit Conversion Calculator
  70. Bar to Atmosphere (atm) Pressure Unit Conversion Calculator
  71. Inch of Water (inH₂O) to Pascal (Pa) Pressure Unit Conversion Calculator
  72. Millimeter of Water Column (mmWC) to Pascal (Pa) Pressure Unit Conversion Calculator
  73. Pascal (Pa) to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
  74. Inch of Water (inH2O) to Standard Atmosphere (atm) Pressure Unit Conversion Calculator
  75. Pounds per Square Inch (psi) to Inch of Mercury (inHg) Pressure Unit Conversion Calculator
  76. Millibar (mBar) to Inch of Water (inH2O) Pressure Unit Conversion Calculator
  77. Inch of Water (inH2O) to Millibar (mBar) Pressure Unit Conversion Calculator
  78. Inch of Mercury (inHg) to Pounds per Square Inch (psi) Pressure Unit Conversion Calculator
  79. Standard Atmosphere (atm) to Inch of Water (inH2O) Pressure Unit Conversion Calculator
  80. Inch of Mercury (inHg) to Pascal (Pa) Pressure Unit Conversion Calculator
  81. Bar to Pounds per Square Foot (psf) Pressure Unit Conversion Calculator
  82. Pascal (Pa) to Inch of Mercury (inHg) Pressure Unit Conversion Calculator
Access a suite of powerful Excel tools and applications for instrumentation professionals, from DP level and density calibration to PID loop simulation and unit conversion, ensuring precision in your work.
  1. Excel Tool for DP Type Level and Density Transmitter Calibration Range Calculation
  2. Excel Based PID Loop Simulator
  3. Free PID Loop Simulation Tools
  4. Split Range Calculator – Control System
  5. Free Excel Tool for Liquid Pressure Drop Calculation: Piping Systems and Field Instrumentation
  6. Control Valve Sizing Excel tool Without Iteration: Liquid Application
  7. Unit Conversion Tool for Instrumentation Engineer
  8. Tool for Converting Instrumentation Standard Signals and Process Variables
  9. Android Application to Convert Instrumentation Standard Signals and Process Variables
  10. Control Valve P1 and P2 vs. Flow Excel Designing Tool (Downloadable)
  11. Control Valve Sizing Excel tool Without Iteration: Liquid Application
  12. Reynolds Number Calculator: A Practical Excel Tool
  13. Pressure Safety Valve Sizing Excel Tool for Gas Applications
  14. Control Valve Cv Calculation Excel Tool for Liquid, Gas, and Steam Services
  15. Pressure Safety Relief Valve Basic Sizing Tool – Liquid Applications
  16. Fluid Velocity Excel Calculator for Instrumentation Design Engineers
Third Party InstrumentationTools
Explore a diverse range of third-party instrumentation tools, from thermocouple and Pt100 calculators to flow and pressure sizing tools, ensuring precise measurements and efficient calculations across various industrial applications.
1.Thermocouple Voltage to Temperature Calculator
2.Pt100 Calculator
3.Thermocouple Table Voltage Calculator
4.Pt100 Table Generator
5.Field of View Calculator (Fov)  Accurate Apparent Temperature Calculation
6.Its-90 Reference Function Calculator
7.Gas Flow Calculator
8.Liquid Flow Calculator
9.Steam Flow Calculator
10.Flow Conversion Calculator
11.Multiphase Flow Calculator
12.DP Flow Sizing and Configuration Tool
13.Cv Calculator with Flow and Pressures
14.Scfm(Standard Cubic Feet Per Minute ) Calculator with Cv and Pressures
15.Liquid Delta P Calculator
16.Liquid Flow Calculator
17.Liquid Cv Calculator
18.Cv Calculator for Valve Sizing
19.Power Module Life Estimator
20.Pressure Gauge Cost Savings Calculator
21.Wireless Smart Instrument Cast Saving Estimator
22.Smart Wireless Interface Capacity Estimator
Click here for more 100+online Electrical Calculators collections
