This calculator provides a quick and easy way to convert pressure values from Inch of Water (inH2O) to Millibar (mBar), a useful feature in HVAC, fluid mechanics, and various industrial applications that require low-pressure measurements.
Definition: Inch of Water (inH2O)
The Inch of Water (inH2O) is a unit of pressure that represents the pressure exerted by a 1-inch column of water at a specific temperature (usually 4°C or 20°C) under standard gravity. It is commonly used in HVAC, airflow measurements, and fluid flow systems.
Definition: Millibar (mBar)
The Millibar (mBar) is a metric unit of pressure, equal to 100 Pascals. It is widely used in atmospheric pressure measurement, meteorology, and various scientific applications.
Formula for inH2O to mBar Conversion
Pressure in mBar=Pressure in inH2O×2.49089
How to Convert inH2O to mBar: Example Calculation
Suppose you have a pressure of 10 inH2O. To convert it to mBar:
10?inH2O×2.49089=24.9089?mBar10
So, 10 inH2O is approximately equal to 24.91 mBar.
Quick Reference Conversion Table for inH2O to mBar
| Inch of Water (inH2O) | Millibar (mBar) |
| 1 inH2O | 2.49089 mBar |
| 5 inH2O | 12.45445 mBar |
| 10 inH2O | 24.9089 mBar |
| 25 inH2O | 62.27225 mBar |
| 50 inH2O | 124.5445 mBar |
| 100 inH2O | 249.089 mBar |
Uses of inH2O to mBar Conversion Calculator
- HVAC Applications: Helpful for converting airflow and duct pressure readings.
- Fluid Mechanics: Commonly used in fluid pressure calculations and testing.
- Industrial Calibration: Essential for process control systems where inH2O needs to be converted to mBar.
- Environmental Science: Used for atmospheric and environmental pressure conversions.
This inH2O to mBar conversion calculator is a valuable tool for professionals in engineering, environmental science, and industrial applications where accurate pressure conversions are essential.
