This calculator enables you to easily convert pressure values from Torr to Millimeter of Mercury (mmHg), a unit commonly used in scientific, medical, and laboratory applications requiring precise pressure measurements.
Definition: Torr
The Torr is a unit of pressure named after the Italian physicist Evangelista Torricelli, who pioneered the measurement of atmospheric pressure. One Torr is defined as 1/760? of standard atmospheric pressure, making it approximately equal to 133.322 Pa.
Definition: Millimeter of Mercury (mmHg)
Millimeter of Mercury (mmHg) is a traditional unit of pressure, representing the pressure exerted by a 1-mm column of mercury at 0°C under standard gravity. The mmHg is almost equivalent to the Torr and is frequently used in medicine and chemistry.
Formula for Torr to mmHg Conversion:
Pressure in mmHg=Pressure in Torr×1
Since Torr and mmHg are virtually equivalent, the conversion factor is 1. Thus, 1 Torr is approximately equal to 1 mmHg.
How to Convert Torr to mmHg: Example Calculation
Suppose you have a pressure of 100 Torr. To convert it to mmHg:
100 Torr×1=100 mmHg100
Therefore, 100 Torr is equal to 100 mmHg.
Quick Reference Conversion Table for Torr to mmHg
| Torr | Millimeter of Mercury (mmHg) |
| 1 Torr | 1 mmHg |
| 5 Torr | 5 mmHg |
| 10 Torr | 10 mmHg |
| 50 Torr | 50 mmHg |
| 100 Torr | 100 mmHg |
Uses of Torr to mmHg Conversion Calculator:
- Medical Applications: Widely used in blood pressure measurement and respiratory diagnostics.
- Laboratory and Research: Common in experiments that involve vacuum pressure measurements and studies in chemistry and physics.
- Environmental Sciences: Helpful in atmospheric and meteorological pressure studies where precise measurements are needed.
- Industrial Calibration: Essential for calibrating devices in processes where Torr or mmHg are standard units of measurement.
This Torr to mmHg conversion calculator is a valuable tool for professionals in scientific, medical, and industrial fields where accurate pressure conversions are frequently required.
