This calculator provides a quick and accurate conversion from Torr to Bar, ideal for various scientific, engineering, and industrial applications.
Definition: Torr
The Torr is a unit of pressure defined as 1/760th of standard atmospheric pressure, equivalent to approximately 133.322 Pascals (Pa). It is commonly used in vacuum systems and scientific measurements.
Definition: Bar
A Bar is a metric unit of pressure, equivalent to 100,000 Pascals (Pa). It is widely applied in fields such as meteorology, engineering, and process control to represent large-scale pressure values.
Formula for Torr to Bar Conversion:
Pressure in Bar = Pressure in Torr × 0.00133322
How to Convert Torr to Bar: Example Calculation
If you have a pressure of 500 Torr and want to convert it to Bar:
500×0.00133322=0.66661?Bar
So, a pressure of 500 Torr is approximately equal to 0.66661 Bar.
Quick Reference Conversion Table for Torr to Bar
| Torr | Bar |
| 100 Torr | 0.133322 Bar |
| 250 Torr | 0.333305 Bar |
| 500 Torr | 0.666610 Bar |
| 760 Torr | 1.01325 Bar |
| 1,000 Torr | 1.33322 Bar |
| 1,500 Torr | 2.00000 Bar |
| 2,000 Torr | 2.66644 Bar |
Use of Torr to Bar Conversion Calculator:
- Vacuum Systems: Convert Torr measurements for high-precision vacuum applications in labs and industries.
- Scientific Research: Ideal for converting Torr to Bar in scientific studies, atmospheric pressure measurements, and experimental setups.
- Industrial Applications: Use in converting vacuum and pressure gauge readings for accurate control and monitoring in industrial processes.
This Torr to Bar conversion calculator is a useful tool for engineers, scientists, and professionals needing exact pressure conversions across a variety of fields.
