This calculator enables you to convert pressure values from Inch of Mercury (inHg) to Pascal (Pa), a key metric unit in scientific, engineering, and industrial applications requiring precise pressure measurements.
Definition: Inch of Mercury (inHg)
The Inch of Mercury (inHg) is a unit of pressure based on the pressure exerted by a 1-inch column of mercury at 0°C under standard gravity. It is commonly used in weather forecasting, aviation, and industrial processes.
Definition: Pascal (Pa)
The Pascal (Pa) is the SI unit of pressure defined as one Newton per square meter. It is widely used in scientific research and industrial applications for standardizing pressure measurements.
Formula for inHg to Pa Conversion
Pressure in Pa=Pressure in inHg×3386.39
How to Convert inHg to Pa: Example Calculation
Suppose you have a pressure of 5 inHg. To convert it to Pa:
5?inHg×3386.39=16,931.95?Pa
So, 5 inHg is equal to 16,931.95 Pa.
Quick Reference Conversion Table for inHg to Pa
| Inch of Mercury (inHg) | Pascal (Pa) |
| 1 inHg | 3386.39 Pa |
| 5 inHg | 16,931.95 Pa |
| 10 inHg | 33,863.90 Pa |
| 20 inHg | 67,727.80 Pa |
| 50 inHg | 169,319.50 Pa |
Uses of inHg to Pa Conversion Calculator
- Weather and Barometric Studies: Convert atmospheric pressure from inHg to Pa for standardized reporting.
- Aviation: Useful for pressure adjustments in altimeters and cabin pressurization systems.
- Industrial Calibration: Assists in converting inHg readings to Pa for consistent process control.
- Scientific Research: Facilitates accurate pressure measurement conversions in experiments.
This inHg to Pa conversion calculator is an indispensable tool for professionals in meteorology, aviation, industrial operations, and research requiring precise pressure unit conversions.
