Millimeter of Mercury (mmHg) to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
This calculator enables you to convert pressure values from Millimeter of Mercury (mmHg) to Millimeter of Water Column (mmWC), commonly used in low-pressure applications across industries like HVAC, water distribution, medical devices, and meteorology.
The Millimeter of Mercury (mmHg) is a pressure unit that reflects the pressure exerted by a column of mercury exactly 1 millimeter high at 0°C under standard gravity. It is commonly used in medical applications (e.g., blood pressure monitoring), barometry, and vacuum measurement.
The Millimeter of Water Column (mmWC) is a unit of pressure that represents the force exerted by a 1-millimeter column of water. It is frequently used in measuring pressure in low-pressure applications such as ventilation, HVAC systems, and fluid distribution networks.
Suppose you have a pressure of 5 mmHg.
To convert it to mmWC:
5×13.5951=67.9755?mmWC
So, 5 mmHg is equal to 67.98 mmWC.
Millimeter of Mercury (mmHg)Millimeter of Water Column (mmWC)
1 mmHg13.60 mmWC
5 mmHg67.98 mmWC
10 mmHg135.95 mmWC
20 mmHg271.90 mmWC
50 mmHg679.76 mmWC
  • Medical Devices: Convert pressure readings from mmHg to mmWC for respiratory equipment, fluid pressure monitoring, and other devices.
  • HVAC Systems: Useful for converting pressure values in HVAC and fluid distribution systems where low-pressure measurement is critical.
  • Industrial Applications: Frequently used for converting vacuum pressure and other low-pressure readings in calibration and process control.
This mmHg to mmWC conversion calculator is a convenient tool for professionals needing quick, precise conversions in medical, scientific, and industrial settings.
