PSI to mmWC Conversion Calculator
This calculator allows you to convert pressure values from pounds per square inch (psi) to millimeters of water column (mmWC), which is essential for various industrial, HVAC, and process control applications.
Pounds per square inch (symbol: psi) is a unit of pressure used in the imperial and US customary systems. It represents the pressure resulting from one pound-force applied to an area of one square inch and is commonly used in hydraulics, pneumatics, and various industrial applications.
A millimeter of water column (symbol: mmWC or mmH?O) is a unit of pressure that represents the pressure exerted by a 1 mm high column of water at 4°C under standard gravity. It is frequently used in low-pressure systems, including HVAC and water treatment applications.
Suppose you have a pressure of 1 psi.
To convert it to mmWC:
1?psi×703.07=703.07?mmWC
So, 1 psi is equal to 703.07 mmWC.
PSImmWC
0.01 PSI7.03 mmWC
0.05 PSI35.15 mmWC
0.1 PSI70.31 mmWC
0.2 PSI140.61 mmWC
0.5 PSI351.54 mmWC
1 PSI703.07 mmWC
2 PSI1406.14 mmWC
3 PSI2109.21 mmWC
5 PSI3515.35 mmWC
10 PSI7030.70 mmWC
20 PSI14061.40 mmWC
50 PSI35153.50 mmWC
100 PSI70307.00 mmWC
Pressure values are often expressed using different units depending on the equipment manufacturer, industry, region, and application.
Pressure UnitEquivalent to 1 PSI
mmWC703.07 mmWC
Pa6894.76 Pa
kPa6.89476 kPa
bar0.06895 bar
mbar68.9476 mbar
inH2Oapproximately 27.68 inH2O
This comparison is useful when checking pressure values from instruments, vendor documents, process datasheets, and control system specifications that use different pressure units.
You may also need to perform the reverse conversion when pressure values are specified in millimeters of water column but an instrument range or datasheet uses PSI.
Use the following formula:
PSI = mmWC ÷ 703.07
For example, to convert 1000 mmWC to PSI:
1000 ÷ 703.07 = 1.422 PSI
Therefore:
1000 mmWC = approximately 1.422 PSI
This reverse conversion is useful when comparing instrument ranges, calibration values, pressure switch settings, and equipment specifications that use different pressure units.
  • HVAC Systems: Convert psi to mmWC for accurate pressure readings in air-conditioning and ventilation systems.
  • Process Instrumentation: Essential for converting pressure measurements in low-pressure control and monitoring systems.
  • Pneumatics and Hydraulics: Useful for fluid pressure conversions between psi and mmWC in various applications.
  • Water Treatment Plants: Ensures precise conversions when pressure measurements in water column units are needed.
This tool is perfect for professionals in engineering, HVAC, and process control industries who need accurate pressure unit conversions.
Pressure unit conversion is straightforward, but engineers should verify several factors before using the converted value for design, calibration, commissioning, or troubleshooting.
PSIG and PSIA do not use the same pressure reference.
PSIG is measured relative to atmospheric pressure, while PSIA is measured relative to absolute vacuum.
Converting a numerical value from PSI to mmWC does not change its pressure reference. A value expressed as PSIG remains gauge pressure after conversion, and a value expressed as PSIA remains absolute pressure.
Do not directly compare absolute pressure and gauge pressure values without first accounting for their different reference points.
When converting an instrument range, convert both the lower and upper range values.
For example, an instrument range of 0 to 1 PSI is approximately equal to 0 to 703.07 mmWC.
For a range containing negative pressure, such as minus 1 to plus 1 PSI, both values must be converted correctly.
This is important when checking pressure transmitter ranges, differential pressure instruments, pressure switches, and calibration requirements.
Early rounding can introduce errors, particularly when converting low pressure or differential pressure values.
Keep sufficient decimal places during engineering calculations and round the final result according to the accuracy required by the application.
The standard conversion factor is suitable for normal engineering calculations. However, highly accurate laboratory or specialized measurements may require consideration of reference conditions, water density, local gravity, and the conventions specified by the applicable standard or project specification.
One of the most common mistakes is using the conversion factor for inches of water column instead of millimeters of water column.
Remember that:
1 PSI = approximately 27.68 inches of water column
1 PSI = approximately 703.07 mmWC
Using the wrong water column unit can create a significant error in the final pressure value.
Millimeters of water column and millimeters of mercury are different pressure units.
Because mercury has a much higher density than water, the conversion values are significantly different.
Always verify whether the engineering document specifies mmWC, mmH2O, or mmHg before performing the conversion.
A correct mathematical conversion can still lead to an incorrect engineering decision if the pressure reference is ignored.
Always check whether the original pressure value is expressed as PSIG or PSIA before comparing it with another measurement.
Avoid rounding intermediate values when the converted pressure will be used for calibration, instrument sizing, or critical engineering calculations.
Perform the calculation using sufficient precision and round only the final result when required.
1 PSI is approximately equal to 703.07 mmWC.
Multiply the pressure value in PSI by 703.07.
mmWC = PSI × 703.07
Divide the pressure value in mmWC by 703.07.
PSI = mmWC ÷ 703.07
For standard engineering calculations, mmWC and mmH2O are commonly treated as equivalent because both represent millimeters of water.
For highly accurate measurements, always check the applicable specification and reference conditions.
0.5 PSI is approximately equal to 351.54 mmWC.
2 PSI is approximately equal to 1406.14 mmWC.
Yes. PSI and mmWC are different units used to express pressure. The same physical pressure can be represented in either unit by applying the correct conversion factor.
mmWC provides a convenient way to express relatively low pressures and small pressure differences. It is commonly used in HVAC systems, ventilation systems, gas applications, burner systems, cleanrooms, and differential pressure measurements.
