- What Is a Relay in Industrial Automation? Working Principle and Applications
- What Is an Electrical Contactor? Working Principle and Industrial Applications
- Relay vs Contactor: 13 Major Differences Every Electrical Engineer Should Know
- Relay and Contactor Wiring Diagram: Control Circuit and Power Circuit Explained
- PLC Relay and Contactor Interfacing: Wiring, Output Control and Feedback
- Industrial Applications of Relays and Contactors in Electrical and Automation Systems
- How to Select the Right Relay or Contactor for Industrial Applications
- Relay and Contactor Selection Calculations With Practical Engineering Examples
- Relay and Contactor Troubleshooting: Common Problems, Causes and Solutions
- Relay and Contactor Installation, Wiring and Commissioning Best Practices
- Frequently Asked Questions About Relay vs Contactor
- Conclusion: Choosing the Right Relay or Contactor for Reliable Industrial Automation
A relay is an electrically operated switching device used to control electrical circuits through a separate control signal. In industrial automation, relays are commonly installed inside PLC panels, motor control panels and instrument control systems.
An electromagnetic relay consists of a coil, magnetic core, armature, spring and electrical contacts. When the coil receives its rated voltage, it generates a magnetic field that moves the armature and changes the contact positions.
Relays are particularly useful for PLC signal isolation, interlocking, alarm circuits and switching small electrical loads.
How Does an Electromagnetic Relay Work Step by Step?
The operation of an electromagnetic relay involves four basic steps.
- The control voltage is applied across coil terminals A1 and A2.
- The energized coil produces a magnetic field.
- The magnetic force attracts the armature.
- The normally open contact closes and the normally closed contact opens.
When the coil supply is removed, the spring returns the armature to its original position.
Stop Valve Failures From Disrupting Automatic Process Control: Step-by-Step Procedure to Troubleshooting Solenoid Valves in PLC Digital Output Loops
What Are the Different Types of Industrial Relays?
Electromagnetic relay: Uses a coil and mechanical contacts to switch electrical circuits.
Auxiliary relay: Provides additional contacts for control logic, alarms and electrical interlocking.
Interposing relay: Provides electrical isolation and interfaces between PLC outputs and external equipment.
Time delay relay: Changes contact status after a predefined time interval.
Solid state relay: Uses semiconductor components instead of mechanical contacts. It provides electronic switching without mechanical contact movement.
Master Contact Logic Before Writing Your Next Program: Understanding NO vs NC Contacts is key for Logic Writing in PLC Programming
An electrical contactor is an electromechanical switching device designed to control higher power electrical loads, particularly three phase motors, industrial heaters and other power equipment.
Unlike a conventional control relay, a contactor has a more robust contact arrangement and an arc management system suitable for its specified switching duty.
Contactors are widely used in pump starters, conveyor systems, compressors, cooling tower fans and industrial motor control panels.
How Does an Industrial Contactor Work?
When the contactor coil receives its rated control voltage, the magnetic field attracts the moving armature towards the fixed magnetic core.
This movement closes the main power contacts, allowing electrical power to flow towards the connected load.
When the coil is de energized, the return spring separates the contacts and interrupts the electrical supply. During switching, an electrical arc can develop between the contacts. The arc chamber helps extinguish this arc.
What Are the Main Parts of an Electrical Contactor?
- Coil: Produces the magnetic field required for operation.
- Magnetic core: Provides the magnetic path.
- Armature: Moves when the coil is energized.
- Main contacts: Carry the electrical load current.
- Arc chamber: Controls and extinguishes switching arcs.
- Auxiliary contacts: Support feedback, interlocking and control circuits.
Catch Panel Component Problems Before They Cause Downtime: Running Inspection Checklist of PLC Components in Control Panels
Although both devices use electromagnetic operation in their electromechanical versions, their construction and intended applications are different.
| Comparison | Relay | Contactor |
| Main purpose | Control circuit switching | Power load switching |
| Current capacity | Generally lower | Designed for higher load currents |
| Voltage rating | Depends on contact design | Designed for specified power circuits |
| Contact arrangement | NO and NC contacts | Main and auxiliary contacts |
| Construction | Compact | More robust |
| Arc management | Depends on relay design | Dedicated arc management arrangement |
| Switching frequency | Depends on device rating | Designed for specified switching duty |
| Coil voltage | AC or DC | AC or DC |
| Load application | Signals and smaller loads | Motors and power equipment |
| Mounting | PCB or DIN rail | Panel or DIN rail, depending on model |
| Protection | Requires suitable circuit protection | Requires separate coordinated protection |
| Maintenance | Contact inspection where applicable | Contact and mechanical inspection |
| Installation space | Generally smaller | Generally larger |
| Cost | Generally lower | Generally higher |
Actual current and voltage ratings depend on the manufacturer, device model, load type and switching category. A relay should not automatically be considered unsuitable for every power application, nor should a contactor be selected based on current rating alone.
Refer the below link for the PLC Analog Output Wiring Procedure: 4 to 20 mA and 0 to 10 V in Process Automation
The main wiring difference is that relays are commonly used in control circuits, whereas contactors provide switching in power circuits.
How to Wire a Relay Using A1 and A2 Coil Terminals
A1 and A2 are commonly identified as the coil terminals.
For a typical 24 V DC relay:
- Connect the positive control supply to A1 through the control output.
- Connect A2 to the DC negative terminal.
- Identify the required normally open or normally closed contact terminals.
- Connect the external control circuit through the selected contacts.
Always check the relay wiring diagram because contact numbering and coil arrangements can vary.
For DC coils, verify polarity when a suppression diode is fitted.
Build Safer Mixing Sequences Without Risky Control Gaps: Step-by-Step PLC Ladder Logic for Automatic Liquid Mixing Process with Interlocks
Three Phase Contactor Wiring Diagram Using L1, L2, L3, T1, T2 and T3
A standard three pole contactor has six main power terminals.
| Terminal | Function |
| L1 | Incoming phase 1 |
| L2 | Incoming phase 2 |
| L3 | Incoming phase 3 |
| T1 | Outgoing phase 1 |
| T2 | Outgoing phase 2 |
| T3 | Outgoing phase 3 |
The three phase supply connects to L1, L2 and L3. The outgoing connections from T1, T2 and T3 feed the motor circuit, normally through an appropriately selected overload protection arrangement.
Contactor Auxiliary Contact Wiring Diagram Using 13/14 and 21/22 Terminals
Auxiliary contacts are important for industrial control and monitoring.
13 and 14: Commonly represent a normally open auxiliary contact.
21 and 22: Commonly represent a normally closed auxiliary contact.
What Is the Difference Between Relay Wiring and Contactor Wiring?
These contacts are used for PLC feedback, electrical interlocking and seal in circuits.
For example, a normally open auxiliary contact can provide feedback to a PLC digital input when the contactor operates. However, this confirms the auxiliary contact position and does not independently prove that the motor is rotating.
Restore Lost Rack Communication Before Production Gets Interrupted: PLC Troubleshooting Remote IO Rack Communication Failure Complete Troubleshooting Guide for Industrial Automation Engineers
How to Connect a Contactor to a PLC Digital Output Module
PLC systems commonly operate relays and contactors through digital output modules.
A PLC output energizes an interposing relay or contactor coil according to the control logic. The associated auxiliary contact can then provide status feedback to a PLC digital input.
Before connecting a coil directly to a PLC output, verify:
- Output voltage compatibility.
- Continuous output current rating.
- Coil inrush current.
- Inductive load switching capability.
- Output module sourcing or sinking arrangement.
- Required coil suppression.
PLC Relay Output vs Transistor Output for Contactor Coil Control
A PLC relay output uses mechanical contacts and can switch compatible AC or DC loads within its specified ratings.
A PLC transistor output uses semiconductor switching and is generally intended for DC loads. It is commonly used for faster switching applications.
An interposing relay is useful when the PLC output cannot directly handle the contactor coil load or when additional electrical isolation is required.
Find Out Why Commands Never Reach Field Equipment: PLC Input ON but Output Not Energizing: Complete Troubleshooting Guide
| Industrial application | Recommended device | Engineering purpose |
| PLC output isolation | Interposing relay | Isolates control interfaces |
| Solenoid valve control | Relay or direct PLC output | Depends on coil rating |
| Pump motor control | Contactor | Switches motor power |
| Conveyor motor control | Contactor | Controls motor starting |
| Compressor control | Contactor | Switches motor supply |
| Cooling tower fan | Contactor | Controls fan motor |
| Industrial heater | Contactor | Switches heating loads |
| Forward and reverse control | Two contactors | Provides motor direction control |
| Panel interlocking | Auxiliary relay or contactor contacts | Prevents conflicting operations |
| Alarm annunciation | Relay | Operates external indication circuits |
The final selection must consider the electrical characteristics of the load and the required switching frequency.
Prevent Dangerous Trips With Better Alarm Documentation Practices: PLC Alarm and Trip Documentation Procedure – EPC PLC Automation Engineer Guide
Important Electrical Parameters for Relay and Contactor Selection
Selecting a switching device requires more than checking its current rating.
Consider the following engineering factors:
- Rated operating voltage and current.
- AC or DC load characteristics.
- Motor starting current.
- Coil voltage and power consumption.
- Switching frequency and electrical endurance.
- Ambient temperature and enclosure conditions.
- Short circuit protection and coordination.
- Required auxiliary contacts.
- PLC output compatibility.
- Manufacturer selection tables and datasheets.
Understanding AC 1, AC 3 and AC 4 Contactor Utilization Categories
IEC 60947 utilization categories help engineers select contactors according to the type of load and switching duty.
AC 1: Used for non inductive or slightly inductive AC loads, such as resistance heating.
AC 3: Used for squirrel cage motor starting and switching off motors during normal running.
AC 4: Used for demanding motor operations such as plugging, inching and frequent reversing.
A contactor suitable for an AC 1 resistive load may not be suitable for the same current in an AC 3 motor application.
Refer the below link for the PLC Relay Output vs Transistor Output: Differences, Selection Guide and Applications
Three Phase Motor Full Load Current Calculation for Contactor Selection
Before selecting a contactor for an industrial motor, engineers need to determine the motor’s full load current. This helps identify a suitable contactor based on its rated operational current and applicable utilization category.
Consider a three phase induction motor with the following assumed specifications.
| Parameter | Value |
| Motor power | 5.5 kW |
| Supply voltage | 415 V |
| Power factor | 0.85 |
| Motor efficiency | 90% or 0.90 |
Step 1: Apply the three phase motor current formula
Motor current is calculated using the following formula:
Motor Current (A) = Motor Power (W) / (1.732 × Supply Voltage × Power Factor × Efficiency)
Step 2: Substitute the given values
Convert the motor power from kilowatts to watts:
5.5 × 1000 = 5500 W
Now substitute the values into the formula:
Motor Current = 5500 / (1.732 × 415 × 0.85 × 0.90)
Step 3: Calculate the motor current
Motor Current = 5500 / 548.9
Motor Current = 10.02 A
Calculated motor current = 10.02 A
This means the estimated full load current of the motor is approximately 10.02 A under the assumed operating conditions.
Engineering consideration: Use this calculated value as an initial reference when selecting the contactor. The final selection must be based on the actual motor nameplate current, AC 3 utilization category, starting conditions and manufacturer’s contactor selection tables. A suitable overload relay and short circuit protective device must also be selected separately.
Avoid Costly Logic Errors With Smarter Data Handling: PLC Data Types Every Automation Engineer Must Know to Avoid Costly Programming Errors
PLC Output Current and Contactor Coil Power Calculation
When a PLC controls a contactor, engineers must verify whether the PLC output channel can safely operate the contactor coil. The coil current and power consumption are important selection parameters.
Consider a contactor with an assumed 24 V DC coil and an operating current of 150 mA.
| Parameter | Value |
| Contactor coil voltage | 24 V DC |
| Coil operating current | 150 mA |
| Current in amperes | 0.15 A |
Step 1: Convert coil current into amperes
Coil current = 150 / 1000
Coil current = 0.15 A
Step 2: Apply the electrical power formula
The DC coil power consumption is calculated using:
Power (W) = Supply Voltage (V) × Coil Current (A)
Step 3: Substitute the given values
Power = 24 × 0.15
Step 4: Calculate the coil power
Power = 3.6 W
Calculated contactor coil power = 3.6 W
This means the contactor coil consumes approximately 3.6 W under the assumed operating conditions.
Engineering consideration: Before connecting the contactor coil directly to a PLC transistor output, verify the output module’s rated voltage, continuous current capacity, switching capability and inductive load compatibility. Also check the contactor manufacturer’s pickup current and holding current because the initial coil current may differ from its steady operating current.
If the PLC output cannot safely handle the coil load, use a suitable interposing relay or an external driver. Provide appropriate coil suppression to protect the PLC output from inductive switching transients. For DC coils fitted with suppression diodes, observe the specified polarity.
Discover Why Industrial Controls Depend On Stable Voltage: Why is 24 Volts Mostly used in Industrial PLC Systems?
| Problem | Possible cause | Recommended inspection |
| Relay not energizing | Missing supply or damaged coil | Measure coil voltage and resistance |
| Contactor not picking up | Incorrect coil voltage | Verify A1 and A2 supply |
| Contactor chattering | Voltage fluctuation or mechanical problem | Check control supply and armature |
| Main contacts overheating | Loose terminals or excessive load | Inspect connections and load current |
| Welded contacts | Excessive switching duty | Check load category and contact rating |
| PLC output failure | Coil inrush or inductive voltage spike | Check output rating and suppression |
| Incorrect coil operation | Wrong AC or DC coil | Verify nameplate |
| Auxiliary feedback failure | Damaged contact or wiring | Perform continuity testing |
| Overload relay tripping | Motor overload or incorrect setting | Check motor current and overload setting |
| Electrical noise | Unsuppressed inductive coil | Install suitable suppression |
Troubleshooting should always begin with electrical isolation and verification of the actual circuit conditions.
Eliminate Wiring Losses Before They Trigger Unstable Signals: How to Calculate and Minimize Voltage Drop in PLC Wiring?
Before commissioning, verify the following:
- Confirm coil voltage against the control circuit drawing.
- Check terminal identification and wiring connections.
- Tighten terminals according to manufacturer specifications.
- Use suitable wire ferrules and cable identification.
- Separate power and control wiring appropriately.
- Install suitable coil suppression.
- Verify overload relay settings against motor nameplate requirements.
- Test electrical and mechanical interlocking.
- Verify PLC output operation and auxiliary feedback.
- Complete functional testing before handing over the equipment.
For maintenance or wiring changes, isolate the supply, apply the required lockout and tagout procedure, and verify absence of voltage using an appropriate tester.
Wire PLC Inputs Correctly And Avoid Costly Mistakes: Sinking and Sourcing: Which Connection is Best for Your PLC?
What is the main difference between a relay and a contactor?
A relay is mainly used for control circuits, signal switching and smaller electrical loads, while a contactor is designed for switching higher power loads such as industrial motors. The correct choice depends on the load current, switching duty and manufacturer’s ratings.
Can a relay be replaced with a contactor?
Yes, a contactor can perform many switching functions handled by a relay, provided its coil and contact arrangements are suitable for the application. However, using a contactor for a small control signal may increase panel space and cost unnecessarily.
Recover Failed Measurement Channels Without Unnecessary Plant Disruption: Replacing a Faulty Analog Input Card in a PLC Rack in Continuous Process Industries: Step by Step Procedure
Can a contactor be used instead of a relay in PLC applications?
A contactor can be controlled by a PLC when its coil voltage and electrical requirements match the PLC output capabilities. For smaller control signals and isolation requirements, an interposing relay is often a more practical choice.
What are the four common types of industrial relays?
Common industrial relay types include electromagnetic relays, solid state relays, time delay relays and latching relays. Each type serves different switching and control requirements in industrial automation.
Prevent Unexpected Controller Downtime With Essential Battery Care: Step-by-Step PLC Battery Replacement and Maintenance Procedure
What is a contactor relay and why is it used?
A contactor is an electrically operated switching device used to control power circuits, particularly motors, heaters and industrial equipment. Its robust contacts and arc management arrangement make it suitable for applications involving higher switching loads.
What are A1 and A2 terminals in a relay or contactor?
A1 and A2 are the coil terminals where the specified AC or DC control voltage is connected to operate the device. Always check the manufacturer’s wiring diagram, particularly when using DC coils with polarity sensitive suppression diodes.
Avoid Miswiring Problems That Can Damage Control Inputs: Understanding Wet Contacts in PLC Wiring
Is a contactor AC or DC?
Contactors are available with both AC and DC coils, depending on the control supply requirements. Their main contacts can also be designed for AC or DC switching, but the applicable voltage and current ratings must always be verified.
What are L1, L2 and L3 terminals in a contactor?
L1, L2 and L3 are the incoming three phase power terminals, while T1, T2 and T3 provide the outgoing connections to the load. These terminals are commonly used in industrial motor control circuits.
Expand Control Coverage Without Complicating Your PLC Architecture: Understanding Remote I/O in PLC Control Systems
Does a contactor provide motor overload protection?
No, a contactor only switches the motor power supply and does not independently protect the motor against overload. A properly selected overload relay and short circuit protective device are required for motor protection.
What is the difference between AC 1 and AC 3 contactor ratings?
AC 1 is intended mainly for resistive or slightly inductive loads, such as industrial heating elements. AC 3 is intended for squirrel cage motor starting and switching off motors during normal running conditions.
Control Motor Sequences Precisely With Smarter Timing Logic: Understanding ON Delay and OFF Delay Timers in PLC Programming
Relays and contactors perform important switching functions in industrial automation, but they are designed for different electrical applications.
Relays are suitable for control signals, PLC interfaces, alarms and interlocking circuits. Contactors are preferred for switching motors and other power loads where appropriate switching capacity and arc management are required.
