Template for Troubleshooting check list of load cells in industrial weighing system
A load cell troubleshooting template is a valuable tool for anyone who works with load cells. It can help you quickly and easily identify the source of a problem, and it can also help you document your troubleshooting process so that you can refer to it later.
Benefits of load cell check list:
  • A load cell troubleshooting template can help you quickly identify the source of a problem. This is because the template will walk you through a step-by-step process of troubleshooting the load cell.
  • A load cell troubleshooting template can help you troubleshoot the load cell accurately. This is because the template will help you to identify the most likely cause of the problem.
  • A load cell troubleshooting template can help you document your troubleshooting process. This can be helpful if you need to refer to the process later, or if you need to share the process with someone else.
  • It helps standardize the process and ensures that all necessary steps are performed for each load cell, reducing the chances of overlooking critical maintenance tasks.
  • This load cell troubleshooting template makes it simple to identify problematic load cells in circuits with many of load cells installed.
If you work with load cells, it is  highly recommend using a load cell troubleshooting template. It is a valuable tool that can help you save time, improve accuracy, and document your troubleshooting process.
What is the resistance of a load cell?
  • Strain gauge load cells are the most commonly used and consist of one or more strain gauges arranged in a Wheatstone bridge configuration.
  • The resistance of a strain gauge load cell is typically specified as the nominal resistance or rated resistance. Common nominal resistance values for strain gauges used in load cells are 350 ohms, 700 ohms, or 1000 ohms. The actual resistance of the load cell may vary slightly due to manufacturing tolerances.
  • It’s important to note that the resistance of a load cell alone does not determine its performance characteristics. Load cells are usually connected to measurement circuits that apply an excitation voltage and measure the resulting electrical output, such as voltage or current, which is proportional to the applied force or weight.
  • Therefore, when using a load cell, it’s important to consider its rated capacity, sensitivity, accuracy, and other specifications provided by the manufacturer, in addition to its resistance.
  • Always refer the instrument data sheet or specifications of the installed load cells  for resistance values with tolerances
How do you troubleshoot a load cell?
Here are some of the common problems that can be solved using a load cell troubleshooting template:
  • Low output: The load cell is not producing the expected output.
  • High output: The load cell is producing an output that is higher than the expected output.
  • Erratic output: The load cell output is fluctuating or is not stable.
  • No output: The load cell is not producing any output.
If you are experiencing any of these problems, you can use a load cell troubleshooting template to help you identify the source of the problem and to fix the problem.
Here are some of the steps that you can follow using a load cell troubleshooting template:
  1. Inspect the load cell: Visually inspect the load cell for any damage.
  2. Check the connections: Make sure that all of the connections to the load cell are secure.
  3. Test the load cell: Use a multimeter to test the load cell with help of the template.
  4. Replace the load cell: If the load cell is not working properly, replace it with a new load cell.
Downloadable template for Trouble shooting check list of load cells
What are the reasons for load cell failure?
There are many reasons why a load cell might fail. The most frequent causes include some of the following:
  • Overloading: Load cells are designed to withstand a certain amount of weight. If they are overloaded, they can be damaged and will no longer be accurate.
  • Environmental factors: Load cells can be damaged by extreme temperatures, lightning strikes or heavy electrical surges in general, moisture, and chemicals.
  • Vibration: Vibration can cause the load cell to become inaccurate or even fail.
  • Mishandling: Load cells can be damaged if they are dropped, mishandled, or otherwise subjected to physical abuse.
  • Manufacturing defects: Even with the best quality control, there is always a chance that a load cell will be manufactured with a defect.
