Twisted Pair Cable in Industrial Signal Transmission: The Essential Guide for 4-20 mA and RS 485 Systems
The electrical environment in manufacturing facilities is full of noise and interference because motors, drives, and switching devices are always running. These unwanted emissions might mess up important measurements and communication linkages between control systems and field devices.
Importance of Twisted Pair Cables in 4–20 mA and RS 485 Communication
Engineers use twisted pair cables to keep things working in such extreme electrical conditions, especially when sending 4 to 20 mA analog signals and RS 485 digital communication.
This guide tells you how twisted pair cables function, what their benefits are, how to install them correctly, and some examples of how they can be used in process control systems. It also has a short list of things that engineers should think about when choosing parts for remote I/O and communication wiring.
There are a lot of noise sources in industrial automation systems. Electromagnetic interference (EMI) can come from things like variable frequency drives (VFDs), contactors, relays, soft starters, and even fluorescent lamps. This EMI couples into signal cables, especially those that transmit low-level digital or analog signals.
When interference couples into signal wiring, it can result in:
  • Incorrect analog current readings in 4 to 20 mA loops
  • Corrupted data in serial communication lines such as RS 485
  • Spurious alarms and unstable control loops
So, one of the most important things to think about when designing instrumentation and control systems is how to reduce the effect of noise on signal wiring.
How Twisted Pair Cable Cancels Electrical Noise
Two conductors are wrapped around each other along the length of a twisted pair cable. These conductors carry the same signal, but one is positive and the other is negative compared to a reference potential.
When an electromagnetic field from outside the cable affects it, it makes the voltages in both conductors almost the same. The common interference goes away because the receiver measures the difference in voltage between them. This is what is known as common mode noise rejection.
If noise from outside causes both wires to have +1 volt, the difference between them stays the same. The receiver cancels out the interference by subtracting one from the other.
This basic geometric twisting of wires makes the signal much stronger, especially over long distances in places where there is a lot of electrical noise.
The amount of twists per meter affects how well noise suppression works. More twists indicate that electromagnetic interference is less likely to happen.
For industrial signal cables:
  • Cables with 6 to 10 twists per foot are usually used for low-frequency analog signals like 4 to 20 mA loops.
  • To reduce reflection and cross talk, high-speed digital signals like RS 485 or RS 422 often need tighter twisting and controlled impedance.
Manufacturers keep the twist rate the same so that both conductors get the same amount of interference, which keeps the signal balance.
Why Engineers Prefer 4–20 mA Over Voltage Signals: Why 4-20 mA Current Signal is Preferred Over Voltage Signal in Instrumentation?
The 4 to 20 mA current loop is the most common way to send analog process variables including pressure, temperature, and flow. The current signal shows the measured value and is usually supplied from the field transmitter to a PLC or DCS input card.
In current loops, voltage drops caused by cable resistance and noise can make measurements wrong. Using a twisted pair cable lessens these impacts by:
  • Lessening the chance of noise coupling from power wires that are close by
  • Keeping the loop resistance the same and stopping measurement drift
  • impacts by:
  • Making it less likely for noise to come from neighboring electrical wires
Even though voltage signals are more vulnerable to noise than current loops, twisted pair cable makes sure that everything is accurate and stable in even the most severe industrial conditions.
Instantly Calculate Process Value from 4–20 mA Transmitter Output: 4 to 20 mA Transmitter Output Process Value Calculator
In industrial networks like Modbus RTU, Profibus, and BACnet, RS 485 is a common way to communicate differentially. In RS 485, data is sent as a difference in voltage between two wires, which are usually named A and B.
The balance between the two conductors is very important for differential signals. An imbalance can cause signals to bounce off of each other, distort, and make communication mistakes.
Twisted Pair Cable for RS 485 Communication
Twisted pair cable keeps this electrical symmetry, which means:
  • Characteristic impedance that stays the same (usually 120 ohms)
  • Less electromagnetic radiation
  • Data can be sent over great distances, up to 1200 meters, with no problems.
  • Support for more than one node on the same communication bus
So, a twisted pair connection is required for all RS 485 installations to keep data integrity high and error rates low.
Transmitter Span, LRV, and URV Calculator for 4–20 mA Signal: Transmitter Calibration Span, LRV and URV Value Calculator from Measured 4 to 20 mA
Twisting alone makes noise less likely to affect the signal, but adding shielding makes it even less likely to be affected by outside sources. A conductive covering surrounds the twisted wires in Shielded Twisted Pair (STP) cables. This layer keeps high-frequency noise from getting through.
  • Foil Shield (FTP): A thin layer of aluminum foil around the pair that is good for light industrial or building automation.
  • Braided Shield: Copper strands that are woven together to make the shield stronger and better at blocking EMI.
  • Overall Shield: A layer that covers several twisted pairs. It is utilized in multi-pair instrumentation cables.
To avoid ground loops that can increase noise, always ground the shield at one end only, usually at the control room or cabinet side.
In places with a lot of noise, including near VFDs, MCCs, or power distribution panels, using STP cables makes sure that signals stay clear and reduces downtime caused by interference.
Difference Between Twisted Pair, Shielded Pair, and Coaxial Cable
Engineers regularly compare twisted pair, shielded twisted pair (STP), and coaxial cables when they work in factories.
Each type has a different way of being built and protects against noise in a different way.
Cable TypeConstructionNoise ProtectionTypical Use
UTP (Unshielded Twisted Pair)Two insulated conductors twisted togetherGood for low noise environmentsShort 4–20 mA loops or low-speed RS 485 links
STP (Shielded Twisted Pair)Twisted pair with foil or braid shieldExcellent EMI protectionHigh-noise zones, VFD panels, MCC rooms
Coaxial CableCentral conductor with full metallic shieldVery high protection, but single-endedCCTV, RF and instrumentation reference signals
Fiber Optic CableGlass fiber with optical transmissionImmune to EMIHigh-speed communication or hazardous areas
Twisted pair cables are still the best option for sending signals in industry since they reject noise while being flexible and cheap.
Fix Cable Management Issues with Proper Tray Accessories: How to Fix Common Cable Management Issues using Cable Tray Accessories
Proper Cable Routing and Installation Practices - Separation of Signal and Power Cables
If you don’t do a good job installing the greatest cable design, it won’t work.
When routing and terminating twisted pair cables in industrial settings, follow these steps:
  • Cables for Power and Signal: Keep at least 300 mm (12 inches) away from electricity lines.
  • Use trays or conduits: Put communication and analog signal cables in different metal conduits or cable trays.
  • Don’t run in parallel with power lines: When you have to, cross electricity lines at a 90-degree angle.
  • Label and End Correctly: Label both ends clearly and use the right connectors or terminal blocks to reduce resistance.
  • Keep the Shield Going: If you’re utilizing multi-pair cables, be sure that the shield stays connected at the junction boxes.
Following these wiring guidelines makes sure that the twisted pair cable works as it should and is noise-resistant.
Standard Method Statement for Instrumentation Cable Termination: Method Statement for Instrumentation Cable Termination
Imagine a case where a remote location needs more analog I/O channels, but there is only one spare twisted shielded pair between two places.
RS 485 connectivity modules are one way to fix this:
  • One module at the distant site changes eight 4 to 20 mA inputs into digital Modbus data.
  • Another part of the control room turns the Modbus data back into eight 4 to 20 mA outputs.
This setup lets you send data from many analog sensors over one twisted pair cable, which cuts down on the cost and difficulty of wiring.
Why Cable Shields are Grounded Only at Control Panel Side: Why the Cable Shield is Grounded Only at the PLC or Control Panel Side
Companies like ICP DAS, Advantech, and Wago make small I/O modules that work with Modbus RTU via RS 485. Some even have partnering modes, which let one module automatically reflect the inputs of another without necessitating a PLC or SCADA master.
This method works well for situations when adding Ethernet infrastructure is not possible or cost-effective.
Calculate Temperature Transmitter Output using 4–20 mA Equation: How to Calculate Temperature Transmitter 4-20mA Output Using Linear Equation and Percentage Method ?
When choosing a twisted pair cable for RS 485 or 4 to 20 mA communication, keep the following things in mind:
ParameterRecommended Specification
Conductor MaterialTinned Copper
Conductor Size18 to 22 AWG depending on distance
Insulation TypePVC or XLPE for general use, PTFE for high temperature
Shield TypeFoil or Braided Shield (depending on EMI level)
Impedance100 to 120 ohms for RS 485 applications
CapacitanceBelow 60 pF per meter for long-distance analog loops
Temperature RatingTypically -20°C to +80°C
Choosing a cable that meets both the electrical needs and the climatic conditions makes sure that the signal works the same way all around the plant.
Simulate 4–20 mA Signals Accurately with Loop Calibrator: How to simulate 4-20ma signal with Loop Calibrator ?
There are two ways to send signals: balanced and unbalanced.
  • Balanced transmission, which is utilized in RS 485 and 4–20 mA systems, sends the same signal over two wires that are opposite in polarity.
  • The receiver reads the difference in voltage, which gets rid of noise that is common to both channels.
  • Unbalanced transmission (like RS 232) is more likely to get interference since it employs one signal cable and a ground reference.
Each twisted pair in multi-pair instrumentation cables has a variable twist rate, which is the number of twists per meter.
This design cuts down on crosstalk, which is when signals from two pairs mix together.
  • Short lay length (more twists): Better at blocking noise, utilized for fast transmissions.
  • Long lay length (fewer twists): Good for analog transmissions with low frequencies.
Manufacturers carefully control pair lay to make sure that extended runs of multi-pair cables always work the same way.
Step-by-Step Guide for 4–20 mA Loop Troubleshooting: How to do troubleshooting of a 4-20mA loop?
When engineers want to use twisted pair cables for remote I/O or signal transmission, they can look to the following reliable suppliers and parts:
SupplierProduct Description
ICP DAS8 Channel Analog Input and Output Modules for RS 485
Phoenix ContactShielded Twisted Pair Industrial Cables
AdvantechModbus RTU to Analog Converter Modules
WagoField I/O and Termination Systems
MoxaIndustrial Serial Communication Devices
Before making a purchase, make sure that the I/O modules, communication protocols, and power supply ratings all work together. Also, make sure that the cable you choose can handle the noise and distance requirements of your application.
Compare Twisted Pair, Fiber Optic, and Coaxial Cables: Difference between Twisted Pair,Fiber Optic and Coaxial cables
For safety and signal integrity, it is very important to keep capacitance and inductance in cables as low as possible in intrinsically safe (IS) circuits.
Twisted pair cables meet the standards of IEC 60079-14 and the FISCO model for Fieldbus systems by lowering loop area and energy storage.
When using twisted pair cables in IS areas:
  • Keep shields away from systems that aren’t IS.
  • Keep IS and non-IS trays apart from each other.
  • Common Protocols for Industry Using Twisted Pair
A lot of automation networks use twisted pair transmission in addition to RS 485 and 4–20 mA:
ProtocolMediumMax DistanceNotes
Modbus RTURS 485 Twisted Pair1200 mMost common industrial serial network
Profibus DPShielded Twisted Pair1200 mRequires 150 Ω impedance cable
CANopen / DeviceNetTwisted Pair500–1000 mUsed in machine-level automation
Foundation Fieldbus H1Twisted Pair (31.25 kbps)1900 mSupports power and data on same pair
This range of field protocols shows how important twisted pair architecture is for any current automation.
To make sure that signal transmission systems work reliably and need little maintenance:
  1. In places with a lot of noise, use twisted and shielded cable for all digital and analog signals.
  2. Connect the shield to the ground at only one end, and don’t make more than one ground connection.
  3. When you can, keep cable runs short and straight.
  4. Check the resistance of the cable insulation on a regular basis.
  5. For easy troubleshooting, make sure to follow the right color coding and labeling rules.
Accurate process control and safe plant operation depend on reliable wiring for instrumentation.
One of the biggest problems in industrial automation is electrical noise, and twisted pair cables are a simple but effective way to deal with it.
They are necessary for both analog 4 to 20 mA signals and digital RS 485 transmission because they can cancel out common mode interference and keep differential balance. Twisted pair cables make sure that signals are clear, reliable, and free of interference, even in the toughest industrial settings, when used with the right shielding, grounding, and routing.
If you want your modern plants to be very reliable and keep your data safe, you have to get good shielded twisted pair cables.
Best Practices for Grounding Instrumentation Systems to Reduce Noise: How to properly ground an Instrumentation System to reduce noise?
When designing or upgrading process control networks,
  • Always plan for extra twisted pairs in case you need to add more in the future.
  • Write down the cable routes and the places where the shield is grounded.
  • When utilizing RS 485, put a 120 ohm resistor on both ends to match the impedance and stop reflections.
  • If you have both analog and digital cabling, you might want to use separate multi-pair cables for each kind to reduce interference.
These best practices can help you save a lot of time when you have to troubleshoot and make sure your control system is stable for a long period.
Make sure that the twisted pair cables you choose or install for industrial systems meet certain international standards:
  • IEC 61158: Fieldbus physical layer (Foundation Fieldbus, Profibus)
  • TIA/EIA-485-A: The electrical properties of the RS 485 interface
  • IEC 60332 / IEC 60754: Requirements for cables that are flame-resistant and free of halogens
  • UL 13 and UL 2919 are ratings for communication and instrumentation cables.
  • IEC 60079-14: Choosing and putting in cables in dangerous places
Twisted pair cable is still the most dependable way to send industrial signals, whether it’s from chemical facilities to HVAC control panels, PLC cabinets to field junction boxes.
It shows the idea of making things simple but effective: a minor change that makes a tremendous difference in how well they work.
Always make sure that twisted pair and correct shielding are part of your wiring plan, whether you are building a new control system or upgrading an old one.
Twisted pair cable cuts down on noise that comes from outside sources and makes ensuring that analog current is sent accurately over lengthy industrial loops.
A 120-ohm shielded twisted pair cable is the best choice for RS 485 networks since it cuts down on EMI and keeps the impedance balance.
Twisted pair cuts down on noise by changing the shape of the wires, while shielded twisted pair adds an extra layer of foil or braid for places with a lot of EMI.
Yes, as long as they meet the specifications of IEC 60079-14 and the FISCO model, which usually means they have a blue outer sheath for IS circuits.
With the right 120-ohm impedance cable and end termination, it can go up to 1200 meters.
