Understanding the Difference Between Live Zero and Dead Zero in 4 to 20 mA Signals
Analog signal transmission is essential in the field of industrial automation and instrumentation in transmitting process variable readings from field devices to control systems such as PLCs and DCS. In process technologies, the 4-20 mA current loop is the most often used standard for analog communication. Particularly in relation to signal interpretation, fault detection, and … Continue reading Understanding the Difference Between Live Zero and Dead Zero in 4 to 20 mA Signals
