PLC Power Supply Calculator – Complete Guide for Accurate PLC Power Sizing
PLC Power Calculator – Excel Export
automationforum.co
📊 PLC Power Supply Calculator
Calculate and export power requirements for industrial automation systems
⚡ Module Configuration
Module Type Number of Modules Current per Module (A) Total Current (A) Action
⚙️ System Parameters
📈 Calculation Results
Modules Total Current
0.000 A
Total System Current
0.000 A
Minimum PSU Power
0.00 W
Recommended PSU Rating
0 W
Backup Battery Requirement
0.00 Wh
⚠️ Important Notes:
  • Always verify module current specifications from manufacturer datasheets
  • Standard PSU ratings typically come in 50W increments (50W, 100W, 150W, etc.)
  • Consider future expansion when selecting power supply rating
  • Ensure proper ventilation and thermal management for power supplies
  • Battery capacity may need adjustment based on battery chemistry and temperature
automationforum.co
Reliable power is the key to consistent control in all industrial automation systems. A properly sized 24VDC power supply keeps PLC modules, I/O cards, and communication devices working without voltage drops or system resets that happen at random times.
But people sometimes forget to size the power or only do it crudely, which might cause problems when the system is put into service.
We made a PLC Power Supply Calculator, a professional-grade, web-based application for precise PLC power sizing and 24VDC load calculation, to make this important design stage easier.
This article demonstrates you how to use the tool, who should use it, and how to read the findings to make strong automation panels.
Stop PLC Downtime Fast: Proactive Maintenance Strategies for PLC I/O Modules: Reduce Downtime & Improve Reliability
The modules in a PLC control system, such as CPUs, I/O cards, backplanes, and external devices, all use power. Using datasheets to do calculations by hand can take a long time and be full of errors.
The PLC Power Supply Calculator takes away this guesswork by automatically calculating the following:
  • Total PLC power use depends on how the modules are set up
  • Power supply efficiency and safety margins for dependable operation
  • Recommended PSU rating (rounded to the normal wattages used in industry)
  • Battery backup capacity for a steady power supply
This helps to make sure that your choice of control panel PSU is technically sound and satisfies the needs of real-world performance.
Top PLCs Revealed: Which PLC is Mostly used in the Automation Industry?
It is important to know how PLC power sizing works before you use the calculator. A typical PLC system gets its power from a 24VDC source and spreads it out among different parts:
ComponentTypical FunctionPower Demand
CPU ModuleControls logic and communication0.4–1.0 A
Digital I/O ModulesField signal interface0.1–0.3 A each
Analog I/O ModulesSensor and actuator control0.15–0.25 A each
Communication CardsEthernet, Profibus, Modbus links0.2–0.4 A
Expansion RacksBus power for extra modules0.1–0.3 A
External DevicesTransmitters, solenoids, relaysVariable
The total current in the system is the sum of all the module currents, the external loads, and the expansion currents.
When you multiply that by 24V and add in safety and efficiency margins, you get the minimum PSU power needed.
The PLC Power Supply Calculator does this calculation automatically, making sure it is accurate and follows industrial design requirements.
Boost PLC Speed Instantly: How to Increase PLC Speed: 7 Optimization Tips + Advanced Programming Guide
PLC Power Supply Calculator - Complete Guide for Accurate PLC Power Sizing 1
This online application was made just for automation and instrumentation specialists that need findings that are accurate and easy to document.
Adding or removing PLC modules like CPUs, digital inputs, digital outputs, analog inputs, or communication modules is easy. The calculator changes the total current and PSU power rating right away.
The tool shows you live results as you make changes to your entries, such as:
  • Module-wise and total current
  • Total system current
  • Minimum PSU power
  • Recommended power supply wattage
  • Estimated battery backup capacity
Why PLCs Use 24V: Why is 24 Volts Mostly used in Industrial PLC Systems?
You can change the safety margin (10–30%) and efficiency (80–90%) settings to make them more realistic for the design and future growth of the system.
When the calculations are done, export a professional Excel report that summarizes all the modules, parameters, and results. This is great for EPC submissions, FAT documentation, or maintenance records.
Designed with a clear interface that works well on mobile devices and is good for usage on-site, in design meetings, or while commissioning projects. You don’t need to download or install anything.
Never Stop Your PLC: Hot Standby in PLC Systems: Architecture, Working, and Benefits
To use the calculator well, follow these steps:
Write down all the PLC modules in your control system, like the CPU, DI, DO, AI, AO, or Communication. To add new rows as needed, click the “Add Module” button.
Look at the manufacturer’s datasheet to find out how many Amperes each module can handle. Fill in the fields with the number of modules and the current per module.
To get an accurate estimation of PLC power usage, please give the following values:
  • Expansion/Backplane current (A)
  • External 24V device current (A)
  • Power supply efficiency (%)
  • Safety margin (%)
  • Required backup time (hours)
  • System voltage (usually 24VDC)
Scale PLC Signals Easily: Scaling Analog Values in Industrial Automation (PLC)
The calculator immediately shows:
  • Total module current
  • Minimum PSU power (Watts)
  • Recommended PSU rating (rounded to standard ratings like 50W, 100W, 150W)
  • Backup battery energy requirement (Wh)
You can download your report with just one click for record-keeping, project documentation, or technical verification.
Stop PLC Voltage Drops: How to Calculate and Minimize Voltage Drop in PLC Wiring?
This online application is useful for a wide range of specialists in the fields of instrumentation, electrical design, and industrial automation.
To check the load on the control panel and make sure the right PSU is chosen during design.
To write down the correct PLC power sizing in design deliverables and commissioning reports.
They choose the PSU for the control panel and make sure there is enough space, ventilation, and cable gauge sizing.
Maintenance and Reliability Teams for doing PLC cabinet load calculations during audits, fixing problems, and upgrading systems.
As a useful way to learn about PLC energy management and 24VDC power supply architecture.
Master PLC Documentation Now: PLC System Documentation Guide: Essential Records for Industrial Automation Success
This tool can be used in many different fields, including:
  • designing PLC and DCS cabinets in the manufacturing and process industries
  • Retrofit projects when the number of modules or their layout changes
  • Adding new I/O racks or communication cards to the system
  • Maintenance checks for verifying PSU loading and battery health
  • Academic use for teaching automation power calculator concepts
The idea of calculation stays the same, no matter if you use Siemens, Allen-Bradley, Schneider, Mitsubishi, or Delta PLCs.
ParameterDescriptionExample Value
Total PLC ModulesCPU + I/O + Communication6
Total Module CurrentSum of all module currents2.2 A
Expansion/External CurrentTotal additional current0.5 A
Power Supply EfficiencyConversion efficiency85%
Safety MarginRecommended overhead20%
Total System CurrentCombined load2.7 A
Minimum PSU Power24 × 2.7 ÷ 0.85 × 1.291.2 W
Recommended PSURounded up100 W
Battery Backup (2h)Required energy182 Wh
Result: For a power failure that lasts 2 hours, a 100W PSU and a battery backup of at least 182Wh are suggested. This keeps the PLC running smoothly and the voltage steady even when the load changes.
More than simply math is needed to design a PLC power system that works well and is reliable. To make things more reliable, follow these best practices:
  1. Always Use Datasheet Values
    Don’t make assumptions. For exact current values, see the manufacturer’s specs.
  2. Apply Adequate Safety Margin
    Add at least 20 to 25 percent more space for future growth or changes in load.
  3. Consider PSU Efficiency
    High-efficiency PSUs (≥90%) create less heat and work better in closed spaces.
  4. Plan for Voltage Drop
    To lower voltage loss, choose the right wire gauge and keep the cable length as short as possible.
  5. Ensure Proper Heat Management
    To keep DIN-rail-mounted power supply from derating, make sure they have space or airflow.
  6. Size the Backup Battery Wisely
    Take into account the state of the environment, how well the system works, and how long it needs to run.
  7. Recheck During Modifications
    Whenever you add or replace modules, you need to recalculate the load.
These measures make sure that your PLC power sizing stays correct for the whole life of the project.
PLC Hardware Explained Fast: PLC Hardware: Modules,Types, Functions, and Applications
  • Instant and correct estimation of PLC power use
  • Saves engineers time and gets rid of mistakes in spreadsheets.
  • Gives you documentation that you can export for project handover
  • Works with both simple and complicated PLC setups
  • No installation needed; works on any browser and device.
This calculator is a must-have digital engineering tool for professionals that work on more than one project at a time.
In industrial automation, a stable power supply means a reliable system. The PLC Power Supply Calculator makes the complicated task of sizing power into a simple, accurate, and professional process that is ready for documentation.
This program makes sure that any project, from simple panels to complicated control systems, goes smoothly and safely by automating your PLC power usage estimates and making clear Excel reports.
This calculator gives you the clarity and accuracy you need to make confident power design decisions, whether you are a control engineer, panel designer, or maintenance worker.
Most of the time, Programmable Logic Controllers (PLCs) run on 24V DC. Some variants can take in 120V or 240V AC and change it to 24V DC within. Always check the voltage requirements for your individual PLC model.
To find out how many watts your Power Supply Unit (PSU) has:
  • Label Inspection: Look at the PSU label; it generally tells you how many watts it can use at once.
  • Model Number: The wattage is sometimes included in the model number.
  • Online Specifications:  If you can’t get to the label, look up the PSU model to get its specs.
Software tools can’t always tell how many watts a PSU uses.
To figure out how much power a power supply can handle:
  • Nominal Load: Add up the power needs (in watts) of all the gadgets that are connected in.
  • Inrush Load: Take into account the initial starting currents, which can be higher than the operating currents.
To avoid overloads, make sure the power supply can manage both nominal and inrush loads.
To find out how much electricity is being used in kilowatts (kW):
kW = (Volts × Amps × Power Factor) / 1000
Where:
  • Volts = Voltage supplied
  • Amps = Current drawn
  • Power Factor = Efficiency factor of the load (0 to 1)
This formula helps in sizing power supplies and ensuring efficient energy use.
ATX 3.1 is the most recent standard for desktop power supply. It offers:
  • Better Power Delivery: Better support for parts that work well
  • New Connectors: Has a 12V-2×6 connection for newer GPUs
  • Better safety and efficiency: Can handle power spikes and makes the system more stable.
It is especially helpful for systems that need a lot of power, including gaming PCs and workstations.
