Advanced Quiz on Practical Troubleshooting of DO Signals in PLC for Process Industries
Digital Output (DO) signals are the backbone of PLC-based automation, controlling actuators, valves, motors, and safety devices in process industries. Troubleshooting DO failures is often complex, involving wiring, field devices, I/O modules, grounding, and power supply integrity. This advanced quiz is designed for experienced engineers and technicians who want to sharpen diagnostic skills in solving DO-related issues. Covering realistic faults, program logic, timing effects, and advanced troubleshooting approaches, the quiz challenges practical knowledge. Attempting these questions will deepen your understanding of isolating faults, improving reliability, and ensuring safe plant operation through effective DO signal troubleshooting.
Welcome to the advanced DO signal troubleshooting quiz! Each question reflects real-world challenges engineers face when diagnosing field issues in PLCs. Think critically about wiring, module faults, logic interlocks, actuator performance, and power integrity. Use your experience to analyze symptoms, identify root causes, and test your ability to troubleshoot DO failures effectively in complex process automation systems.
Symptom: DMM shows DC, oscilloscope shows pulses.
Symptom: DO transistors fail repeatedly despite flyback diode installed.
Symptom: Triac outputs fail to drive solenoids; occasional voltage spikes.
Symptom: DO toggles, device lags; “channel stuck” logged.
Symptom: DO fails above 55°C but works fine otherwise.
Symptom: DO behaves erratically when multiple supplies present.
Symptom: Voltage drops under load at device, LED OK.
Symptom: Mechanical relay output toggles rapidly under PLC control.
Symptom: DO LED blinks in a code pattern, load inactive.
Symptom: Remote DO works locally but fails at remote rack.
Symptom: Output energizes but safety valve doesn’t move; safety input active.
Symptom: Sinking DO fails to energize sourcing device.
Symptom: Output works at room temperature, fails under vibration.
Symptom: DO LED ON, device fails, and forcing works.
Symptom: DO fuse blows only when actuator moves.
Symptom: PLC shows DO ON, but heater slowly warms; SSR LED ON.
Symptom: DO pulses as seen on oscilloscope but DMM reads steady DC.
Symptom: Multiple DOs fail on same module; others OK.
Symptom: DO bit OFF in software but LED blinks; load occasionally energizes.
Symptom: DO LED ON, voltage at module, but actuator moves slowly.
Symptom: DO works during testing but fails above 50°C.
Symptom: SSR outputs fail driving inductive solenoids with flyback diodes; occasional voltage spikes present.
Symptom: Remote I/O DO shows ON, LED flashes, device doesn’t operate, network reports intermittent connection.
Symptom: DO bit toggles in PLC, but a contactor chatter occurs despite steady ON in logic.
Symptom: PLC DO bit = ON, module LED is ON, but a 24 V solenoid intermittently activates.
The average score is 65%
Access 1000+ MCQs tailored for instrumentation engineers: Instrumentation and Process Control Quiz Hub – 1000+ MCQs for Engineers
