Pneumatic Control SystemÂ
What is pneumatic ?
Pneumatic is the technology that makes use of gas or pressurized air.
Components of Pneumatic control system
In one position IN and OUT ports are connected
What is pneumatic ?
1.Connect the DP transmitter (Rosemount) to a power supply
2.Connect the HART
3.Connect test pressure gauge
4.Calibrate zero and span of transmitter
In order for you to be able to communicate with the DP transmitter you have to install a resistor in series with your power supply.
HART recommends a 250 ohm resistor After you have the resistor in series and the power supplyconnected,connect your HART 475 noting polarity.
The HART 475 leads have to be inserted into the HART side of your communicator.
When dealing with a DP transmitter you always want to connect to the “High side” with your pump to apply pressure (PSI).
Make sure low side is vented to atmosphere .
When you are all powered up turn on your HART 475 on the first screen select HART.Next you want to press right arrow when the HART 475 sees your instruments Use right arrow key to select your next option or OK button on touch screen.
Go to the following menu.
Service tools>Maintenance >Pressure Calibration>
Now start with your zero calibration.Make sure you are vented on low side and the high side is vented on the test pump.
Now its time to span the meter.
Make sure your test pump meter is reading zero when open then close the vent on your test pump.
Select Upper using one on the the keypad or while selected the right arrow and follow the prompts on screen.
Now its time to apply the upper range input.
Start slow with the pump up to see how fast the pressure rises.Over ranging will cause damage.
Apply the correct pressure
Select “OK” and follow prompts on the screen.
After you select OK when the pressure is stable the next screen will allow you to tell exactly what it is reading.
Enter in the text box the exact reading on your test pump the moment you pressed ok for the pressure being stable.
Select “ENTER” Â and follow the prompts on screen
Go to “Home” .Then go to “Overview” Â and verify the calibration
The latest updates includes a calibration tool too.
Send your feedback : forumautomation [at] gmail.com
| Calibration range to 25%, 50%, 75% |
| Search for Units |
| Conversion History |
| Settings |
PID Loop tuning is one of the important activity carried out by instrumentation or process engineers  during plant startup and day to day instrumentation maintenance activities.
Several PID loop tuning spread sheets are available in the internet.We are discussing about some of the best PID loop tuning spreadsheet.
PID Loop Tuning Spreadsheet by Engineers-Excel .comÂ
This spreadsheet simulates a control loop consist of a first order process with deadtime and a PID controller.
How to use tune PID controller with the help of PID simulator spreadsheet?
Step 1: Do a step test in manual mode and collect test data.
Step 2: Identify process model parameter
Step 3: Tune offline
Step 4: Implement in controller and fine tune if required .
You can find more documentation and spreadsheet for download from following link : Download link
Free PID simulator by Carnegie Mellon University
This PID simulator spreadsheet is absolutely free . You can download it from Automationforum
Related topics :
Instaconvert – Instrumentation signal converterÂ
Unit Conversion
PID Tuning rules
PID Tuning
https://play.google.com/store/apps/details?id=com.infohe.simplyconvert&hl=en
Following parameters can be converted with InstaConvert
Instrumentation Standard Signals
4-20 ma to Percentage
3-15 psi to Percentage
0-20 ma to Percentage
0-25 ma to Percentage
Process Variables (Unit Converter)
Temperature
Pressure
Other Parameters
Length
Mass
Speed
Volume
Area
Fuel Consumption
Time
Digital Storage
Energy
Power
Force
Electric Current
More updates are coming soon .Waiting for you feed back.
InstaConvert unit converter is designed for Instrumentation and electrical engineers.
Download it from Google Play store : InstaConvert
Keywords – Unit Converter ,Instrumentation Signal Converter , Process Variable Unit Converter .
Working Principle Of Bourdon GaugeÂ
If a tube having oval cross section is subjected to pressure its cross section tends to change from oval to circular.
Construction of a Bordon GaugeÂ
Bourdon tube gauges consist of a circular tube.
One end of the tube is fixed while the other end is free to undergo elastic deformation under the effect of pressure.
Fixed end is open and pressure which is to be measured is applied at the fixed end.
Free end is closed and undergoes deformation under the effect of pressure.
Due to applied pressure the circular tube tends to uncoil and become straight along the dotted line.
Working of Bourdon GaugeÂ
As the pressure is applied at the fixed end free end undergoes deformation.
The free end is attached with sector which further meshes with the pinion on which pointer is mounted.
Deformation of the pointer is transferred to pointer via this mechanism.
As a result point undergoes deflection and shows the pressure reading on calibrated dial.
Advantages of Bourdon GaugesÂ
1.Inexpensive
2.Simple Design
3.Good accuracy except at low pressure.
4.High-pressure range.
5.It can be easily used with electrical devices like LVDT.
Disadvantages of Bourdon Gauges.
1.Susceptible to shock and vibration
2.Gauges are subjected to hysteresis
Related Topics
Basics of Pressure MeasurementÂ
Pressure Measurement – ManometerÂ
Classify Pressure Measuring InstrumentsÂ
Â
Flow measurements are essential to  run a plant efficiently and safely.There are no real flow measurement technologies available including differential pressure flow also known as DP flow which utilizes a variety of measurement instruments.
DP flow is measured with the combination a primary element and a secondary elements.
The primary element is placed in the pipe to create a differential pressure and connecting
the secondary element to the process.
Variable Area Flow MetersÂ
Variable area flow meters are used to measure the volume flows of liquid and gases.
Application of Variable Area Flow Meter – Volume flow measurements of Liquids and Gases
Components – Â Vertical Conical Measuring Tube
Mobile Float
It consist of vertical conical measuring tube which widens upwards and a specially formed float which can move up and down freely in the measuring tube.
Working Principle –Â
Â
The reference of position of the float to the measuring tube creates a variable ring orifice.The higher the position of the float the larger the ring orifice and therefore the cross sectional area through which the medium come pass through the float.This is the origin of the English designation of the device.
When there is no flow, gravity keeps the float at the bottom end of the measuring tube.
As soon as the medium flows through the tube from bottom to top the float rises again until the acting forces are in balance.
Three main forces act on the movable float.
1. Graviatation force (W = Weight) – Operates downwards as a reset force.
2. Buoyancy force (B)
3. Flow force (D=Drag)
Weight = Drag + Bouyancy
W and B = Constant
The position of the float is a flow indicator.
The physical operating mode shows that the position of the float is a flow indicator.
With glass cones flow rate can be read on a scale on the measuring chip itself.
With the metal cones the float is not visible so they have a magnetic transfer onto the pointer.For this purpose a magnet is built into the float.Through a magnetic coupling installed on the point of axis the linear movement of the float float is converted into the rotary movement of the pointer which displays the flow on a scale.No auxiliary power supply is required.
Advantages of Variable area flow meter – Purely mechanical.No auxiliary power is requires.
Related posts –Â
Flow transmitter calibrationÂ
Type of Valves
The most common DC motors types are
1.The basic brushed DC motors
2.Brushless motor
3.Permanent Magnet motor
Ultrasonic Level Detectors
Ultrasonic sound waves with frequencies of 1 to 5 megahertz can be used to detect liquid or solid levels.
Ultrasonic are sound waves but are at higher frequencies that cannot be detected by the human ear.
The most common kind of ultrasonic transducer consist of a piezoelectric crystal.When a voltage is applied to the plates the piezoelectric crystal expands or contracts.If the voltage is alternating at an ultrasonic frequency,the crystal expands and contracts at same the same ultrasonic frequency.The crystal vibrates and these vibrations can be transferred to a diaphragm to produce ultrasonic sound waves.
