Instrumentation Shutdown and Turnaround Activity Checklist: A Complete Step-by-Step Procedure
Planning and executing a successful shutdown or turnaround requires careful coordination of tasks, resources, and safety measures. This guide provides a step-by-step approach to streamline each phase from pre-shutdown preparations to post-maintenance recommissioning ensuring both efficiency and compliance with industry standards.
Download the checklist in Excel format to simplify tracking and ensure each task is accounted for throughout the process.
  • Start with a structured review of the shutdown plan, detailing each task’s objective and ensuring alignment with overall maintenance goals.
  • This review involves collaboration with department leads to confirm planned activities, timing, and task overlap for better workflow integration.
  • Gather and verify all necessary permits (LOTO, confined space, hot work) well in advance. Secure approvals for each permit type based on location and task risk level to ensure compliance with safety regulations.
  • Clearly define roles for each team member involved, from maintenance and safety to inspection teams.
  • Assigning specific tasks, such as equipment isolation, inspection, or testing, helps minimize confusion and overlaps.
  • Conduct pre-shutdown meetings to clarify each role, especially for cross-functional tasks.
  • Tools and Equipment Verification: Ensure all required tools, spare parts, and consumables are available on-site, in good working condition, and within calibration limits.
  • Test equipment, such as multimeters, loop calibrators, and pressure calibrators, should be pre-checked and certified to avoid on-site calibration delays.
  • Procurement and Major Parts Availability Check: Double-check that all major spare parts (e.g., gaskets, seals, critical control components) are readily available.
  • Plan for any long-lead items, and if necessary, place orders well in advance to avoid delays.
  • Conduct Job Safety Analysis (JSA): Perform a JSA for each high-risk task, identifying potential hazards and specific control measures required.
  • This includes planning safety isolations, monitoring electrical risks, and mitigating chemical or pressure risks in confined spaces.
  • Verify that all teams have the necessary PPE, including specialized items like flame-retardant clothing or respiratory equipment if needed.
  • Prepare emergency response plans specific to each area and task to address risks effectively.
  • Hold a pre-shutdown kick-off meeting with department leads, contract teams, and site supervisors.
  • Discuss all safety protocols, shutdown sequences, and work permit processes. Review planned activities and assign tasks, focusing on cross-functional teams to ensure task flow continuity.
  • Special Manpower and Contractor Requirements: Identify specialized tasks (e.g., calibration of high-accuracy instruments, large control valve maintenance) that may require skilled contractors.
  • Coordinate with central department or procurement for any contract or ad-hoc manpower to be on standby during shutdown.
  • Develop a comprehensive timeline that defines the exact start and end dates for the shutdown or turnaround, ensuring all activities are coordinated to minimize downtime and keep the project on schedule.
  • Assemble a skilled team with expertise in shutdowns and turnarounds, including planners, engineers, safety experts, and technicians, to ensure a seamless operation through collaborative efforts.
  • Identify the critical path of tasks to be completed in sequence to avoid bottlenecks and delays, ensuring efficient workflow and timely completion of high-priority activities.
  • Establish a detailed budget that includes labor, materials, and potential contingency costs to maintain the financial integrity of the project.
  • Control System and Power Isolation: Sequentially power down process control systems, such as DCS, PLCs, and SIS
  • Properly isolate each system according to standard LOTO procedures for electrical, mechanical, and process isolation to ensure personnel safety.
  • Documentation and Drawings for Isolation Points: Use detailed drawings and isolation sheets to confirm each isolation point.
  • Document any temporary changes to ensure clarity in re-commissioning.
  • Gradually depressurize all systems connected to pressure instruments, such as transmitters and gauges, following the specific guidelines for each instrument to avoid pressure buildup or dangerous leaks.
  • Drainage and Venting Lines: Where applicable, drain or vent lines to avoid contamination.
  • Ensure spill-prevention measures are in place to protect both personnel and the environment during this process.
  • Ensure specialized contract manpower arrives on schedule and is briefed on safety protocols and site layout.
  • Oversee coordination to keep high-skill tasks, such as advanced calibrations or critical valve inspections, on track.
  • Ensure full compliance with industry regulations and standards to avoid legal complications and ensure safe operation.
  • As the scheduled shutdown date approaches, mobilize all necessary resources, equipment, and personnel to ensure a smooth start to the operation.
  • Examine each instrument for signs of damage, corrosion, or wear, especially focusing on parts exposed to harsh environments.
  • Inspect junction boxes, instrument trays, and cable glands to ensure they are intact, well-maintained, and capable of withstanding operational stresses.
  • Record findings, documenting any deviations, damage, or needed repairs. Update relevant drawings or schematics to reflect any detected issues or configuration changes.
  • Calibrate control valves, actuators, and positioners to confirm they respond properly to control signals, performing stroke testing as needed.
  • Check that instrument loops, both 4-20mA and digital (HART, Foundation Fieldbus), transmit accurately from the field to the control room. Perform continuity and insulation tests to verify field cable reliability.
  • Record and review all loop test results, maintaining data for final reporting and compliance checks.
Click here for Method Statement for Loop Checking of Pressure Transmitter Loop
  • Complete calibration checks for each instrument, noting both as-found and as-left readings to verify conformance to ISO or NIST standards. Log calibration data to maintain traceability for quality audits.
  • Follow documented calibration procedures to ensure consistency across all equipment types.
  • Inspect control valves, focusing on seals, gaskets, and packings for signs of wear. Replace as necessary, and confirm that all adjustments comply with manufacturer standards.
  • Conduct stroke tests to ensure each valve responds fully within the control signal range, recording any anomalies for follow-up maintenance.
  • Clean and inspect field instruments, especially those exposed to dust, chemicals, or other contaminants, to ensure reliable readings.
  • Check that purge and impulse lines are clear and functioning, as clogged lines can affect differential pressure transmitter readings.
  • Ensure each maintenance task is documented, noting inspections, repairs, or calibrations performed. Maintain these records for final reporting.
Step 5. Post-Maintenance and Recommissioning
  • Verify each loop’s functionality, checking settings, ranges, and alarm configurations.
  • Ensure AI, AO, DI, and DO loops work accurately, transmitting correct data to control systems.
  • Carefully reconnect instruments, applying the appropriate torque to electrical and mechanical connections.
  • Confirm correct cable labeling, updating documentation where necessary.
  • Gradually restore power to control panels and instrumentation systems, removing LOTO tags only after verifying safe conditions. Proceed with system initialization, ensuring all devices undergo a controlled warm-up.
  • Re-test control loops and safety functions (ESD, F&G, SIS), performing simulated tests to validate accurate system response.
  • PID Controller and Control Valve Testing: Conduct performance tests on PID controllers and control valves, observing response under controlled conditions to confirm reliable performance.
  • Compile all calibration records, ensuring each instrument’s as-found and as-left results are logged in line with audit standards.
  • Document all inspection findings, repairs, and adjustments.
  • Include photographs, test results, and detailed notes on instrument tag data to provide a complete record.
  • Submit final reports to the operations or asset management team, ensuring all parties are informed of completed tasks.
  • Obtain sign-off from maintenance, safety, and operations departments, confirming system readiness for startup.
  • After startup, hold a follow-up meeting with all team leads to review performance, address any initial operational issues, and finalize outstanding actions.
Instrumentation Shutdown and Turnaround Activity Checklist: A Complete Step-by-Step Procedure 2
For effective and streamlined shutdowns or turnarounds in process plants, this downloadable checklist covers each essential step from preparation to recommissioning. Use this guide to verify task completion, maintain safety protocols, and track progress efficiently.
Click here for 50+Collection of Essential Instrumentation and Automation Control System Checklists
In industrial operations, particularly in oil and gas, effective maintenance is essential for safety and efficiency. Two common practices are shutdowns and turnarounds. While both involve halting production for maintenance, they differ in scope and duration.
The table below summarizes the key differences between shutdowns and turnarounds.
AspectShutdownTurnaround
DefinitionA planned, temporary halt in operations for maintenance, repair, or replacement of equipment.A comprehensive and extensive halt of the entire facility or a significant part for thorough maintenance, inspection, and upgrade activities.
PurposeTo address specific maintenance needs or issues on critical equipment.To conduct thorough maintenance, inspections, repairs, and upgrades of the facility or major systems.
DurationTypically shorter than turnarounds; duration varies based on the task.Generally longer, often spanning days to weeks, depending on the scope of work.
ScopeFocused on specific equipment or systems.Involves multiple systems, equipment, and often includes significant upgrades and modifications.
ExamplesRepairing a pump, replacing piping, or calibrating instruments.Overhauling a processing unit, conducting major inspections, and implementing system upgrades.
FrequencyMay occur multiple times a year based on equipment needs.Generally scheduled every few years, based on industry standards and regulatory requirements.
PlanningRequires planning but is often less complex than a turnaround.Involves extensive planning, coordination, and resource allocation, often with detailed schedules.
Teams InvolvedTypically involves maintenance teams focused on specific tasks.Engages multiple teams across various disciplines (maintenance, operations, safety, etc.).
Shutdowns and turnarounds are essential to maintain the efficiency and safety of industrial facilities. They provide opportunities for essential maintenance, repairs, and system upgrades to enhance overall performance.
The frequency of turnarounds varies based on the specific needs of the facility. Typically, they occur every few years to address accumulated wear and tear and ensure continued optimal performance.
Major challenges include managing resources and time efficiently, ensuring safety protocols, and meeting all regulatory compliance requirements.
A skilled and experienced team is critical for successful shutdowns and turnarounds. The expertise and coordinated efforts of trained professionals are essential to executing these complex processes smoothly.
Risk assessment plays a crucial role in identifying potential hazards and implementing safety measures, protecting both personnel and the environment during the process.
