Understanding RTU (Remote Terminal Unit): Key Components, Functions, and Applications in Industrial Automation
The remote terminal unit (RTU) serves as an essential component for industrial automation systems by functioning outdoors where access by people becomes challenging. An RTU operates as a distant control system by extracting information from multiple field devices including sensors and actuators and field instruments while it sends this data to central analysis platforms usually known as SCADA systems.
RTUs provide advanced functionality to receive and save data from field operations then deliver this information through communication channels to central control systems. RTUs function similarly to PLCs (Programmable Logic Controllers) when interfacing with physical devices yet differ in their primary application field due to operating in remote dangerous environments. The transmission methods that RTUs use include wireless and wired networks based on the particular application requirements.
RTUs possess built-in data transmission protocols in addition to offering multiple programming languages that include ladder logic and structured text and higher-level languages like Visual Basic or C++ for user-specific control functions.
The provided visual representation shows how RTU (Remote Terminal Unit) systems function during industrial automation operations. The diagram separates its information into left-side RTU internal components & interfaces and right-side RTU power supply system.
Remote Terminal Unit (RTU) and Its Components
  1. Left Side – RTU Internal Components & Interfaces
  2. Right Side – RTU Power Supply System
The Remote Terminal Unit (RTU) operates as an industrial automation device which enables remote monitoring as well as control of field equipment. The main purpose of SCADA systems is to utilize this technology as the principal data collection point connecting sensors and instruments to central control stations for processing and transmission purposes. The Remote Terminal Unit (RTU) serves applications throughout the power distribution sector as well as oil and gas industries and water treatment systems and acts as a controller in transportation projects.
A CPU serves as the core component of an RTU which performs data processing tasks and executes programmed instructions together with controlling communication operations. The RTU operates as an effective device which obtains data, processes information and establishes reliable connections with the central system. Real-time data storage functions together with time-stamping and error detection take place inside the CPU to enable secure accurate operation.
Remote Terminal Unit (RTU) and Its Components 2
A reliable power supply remains essential for RTUs to operate with optimal performance. The choice of power sources depends on each installation environment because it could use any of the following options:
  • Industrial operations frequently use Direct DC Power Supply as its main source delivering 24V DC power.
  • AC Power Supply with Converter – Converts 110V/230V AC to DC power for RTU operation.
  • Battery Backup – Ensures uninterrupted operation during power failures.
  • Remote locations operate with Solar Panels linked to an Accumulator (Battery Storage) system because standard power access is hard to obtain.
The RTU can acquire device signals through its discrete inputs which function as digital inputs to read signals from binary field devices including:
  • Push buttons
  • Limit switches
  • Digital sensors (motion sensors, smoke detectors, etc.)
  • Alarm systems
System status monitoring depends on these ON/OFF (0 or 1) detecting inputs which also serve to activate alarms.
With analog inputs the RTU can receive and process continuous data signals from field sensors which measure:
  • Temperature sensors
  • Pressure transmitters
  • Manipulation of flow meters enables measurement of both liquid and gaseous materials.
  • Voltage and current levels in electrical grids
  • The RTU converts these signals into digital values before processing and sending information to SCADA systems through transmission.
Control relay outputs provide an interface that enables RTUs to transmit commands for controlling field actuators and motors and field devices. Relay outputs enable the control of the following operations:
  • Opening or closing valves in water or oil pipelines
  • Turning pumps ON/OFF in wastewater treatment plants
  • Starting or stopping motors in industrial applications
  • Triggering alarms and warning systems
Through its relay output functionality an RTU can execute automated logic-based process control which results in heightened operational effectiveness while minimizing human interaction.
The communication interface directly transfers real-time data from the RTU to the central SCADA system. RTUs offer multiple communication protocol options that include:
  • RTU/TCP Modbus functions as one of the main industrial automation communication protocols in modern industry.
  • DNP3 (Distributed Network Protocol) – Used in power utilities and water systems.
  • IEC 60870-5-104 – Used in electrical grid automation.
  • MQTT, OPC-UA – Modern IoT and cloud-based communication protocols.
The communication method selection depends on the specific application between wired and wireless technologies.
  • Ethernet (TCP/IP) and Serial (RS-232/RS-485) serve as the primary standards for local wired communication.
  • Radio (VHF/UHF), GSM, LTE, or Satellite – Used for remote and long-distance communication.
The battery module serves as an emergency power backup system when electric power fails. RTUs in remote locations function with continuous operations through the use of rechargeable battery systems. The power requirements determine which battery type will be used between lead-acid, lithium-ion or nickel-cadmium.
Most RTUs operate on DC power, typically 24V DC. In cases where only AC power is available, a DC power supply unit is used to convert AC voltage to the required DC output. The DC supply ensures stable operation and compatibility with field instruments.
Solar panels work with accumulator batteries stored as a power source when conventional power is inaccessible. The solar controller acts as the central controller which controls both charging and discharging operations to provide steady 24V DC output power to the RTU. This is common in:
  • Oil and gas pipelines in deserts and offshore platforms.
  • Remote power substations for grid monitoring.
  • Water level monitoring stations in rivers and reservoirs.
Many RTUs come with wireless transceiver (antenna) devices which allow them to communicate through extended ranges across:
  • VHF/UHF radio frequencies – Used for industrial remote control.
  • The GSM/4G/5G cellular networks alongside other cellular networks operate for cloud-based monitoring purposes.
  • Satellite communication – Used in offshore oil rigs and remote infrastructure.
Real-time data transmission through the antenna allows central operators to receive updates and execute control methods on remote equipment.
  • RTUs oversee and operate pumps together with valves at offshore platforms and through pipelines in the Oil and Gas sector.
  • RTUs serve water and wastewater facilities by gathering operational data from water treatment facility pumps in addition to chemical feeders along with other measurement systems.
  • RTUs are installed in power substations and electricity grids to track equipment health conditions and receive information from sensing devices.
  • The robust structure of RTUs makes them suitable for areas where personnel rarely work because of extreme conditions.
The main benefit of Real Time Units (RTUs) is their capability to develop specialized solutions for distinct operational needs. The system needs determine which additional components like I/O modules, communication interfaces and data storage allocate to RTUs. The devices offer adjustable functionality based on wireless voltage requirements and support wide operating parameters.
  • The power consumption of RTUs remains lower than PLCs because of their suitability for locations with scarce electricity resources. RTUs work effectively by utilizing either solar power or battery battery resources as their energy supply.
  • RTUs function directly from the field thus requiring no space inside central control rooms and taking up minimal floor area.
  • The installation and maintenance of RTUs becomes simpler since manufacturers perform factory pre-configuration before delivery. RTUs allow deployment in challenging remote areas and dangerous environmental zones which make it impossible to install traditional systems.
  • RTUs provide data storage capabilities alongside history logging features which enable critical information storage using timestamped data even if communication services become interrupted.
The functionality of RTUs differs from PLCs even though both devices serve to automate processes and control field devices through their distinct features.
  • RTUs provide a larger interface and better capability to handle remote data acquisitions because of their bigger scale design.
  • The primary function of PLCs remains local facility automation and control purposes.
  • RTUs possess remote communication capabilities through wireless protocols together with extended wired systems for far-reach communication.
  • Industrial environments make best use of PLCs to connect different devices on their premises.
Three major companies at the forefront of RTU manufacturing operations are ABB followed by Schneider Electric and GE Grid Solutions.These are among the main manufacturers that produce RTUs:
  • ABB
  • Schneider Electric
  • GE Grid Solutions
  • Honeywell
  • Siemens Energy
  • Yokogawa
The companies in this list give RTU solutions to various industrial sectors for reliable remote data collection and control operations.
The following table compares RTUs and PLCs in more detail to assist in selecting the best device for industrial applications.
FeatureRTU (Remote Terminal Unit)PLC (Programmable Logic Controller)
Primary UseRemote monitoring and controlIndustrial automation and control
EnvironmentHarsh, remote locations (e.g., oil rigs)Controlled industrial settings
CommunicationWireless (radio, satellite, cellular) or wiredWired (Ethernet, serial communication)
Power SupplySolar, batteries, low-power sourcesStandard AC/DC power sources
Data StorageBuilt-in historical data storageLimited or no historical data storage
I/O CapacityHigher I/O capacity for remote applicationsLower I/O capacity
ProgrammingPreprogrammed or web-based interfaceRequires specialized programming (Ladder Logic, Structured Text)
FunctionalityMonitors and controls multiple processes remotelyAutomates local processes using I/O signals
DisplayNo built-in display; requires SCADA systemOften includes a built-in display for local control
ConnectivityInterfaces with SCADA, DCS, and other systemsPrimarily interfaces with SCADA systems
CostHigher due to ruggedness and remote capabilitiesLower since it is simpler and locally operated
ReliabilityCan operate autonomously for long periodsRequires continuous power and stable communication
Use CaseRemote sites like oil fields, power grids, and pipelinesLocal automation like manufacturing plants and industrial machinery
Remote telemetry units function as data collectors for field readings while they check equipment performance before they send collected information to remote monitoring SCADA systems.
Control rooms of SCADA systems contain graphical user interfaces (GUIs) which enable monitoring of plant-wide data. The main role of remote terminal units (RTUs) involves physical distribution through remote locations to acquire sensor information then transmit it to SCADA systems for analysis.
This comparison between PLCs and RTUs reveals their main distinction as RTUs function best in distant sites apart from their intended purpose of PLCs which control equipment locally. The cost efficiency of RTUs makes them an ideal option for distant operations because they can acquire data without requiring a complete PLC system.
Click here for Training on PLC Hardware and Software
