- How do you troubleshoot a radar level transmitter?
- Problem no.1: Power Supply Issues
- Problem no.2: Temperature Issues
- Problem no.3: Communication Equipment Issues
- Problem no.4: Accuracy of Displayed Value
- Problem no.5: Fluctuations in Measured Value
- Problem no.6: System Error Display
- Problem no.7: Diffuse Reflection
- Problem no.8: Antenna Contamination and Crystallization
- Problem no.9: Loss of Wave signal
- Problem no.10: Sensor and Signal Issues
- Problem no.11: Configuration and Control System Integration Issues
- Problem no.12: For Guided Wave Radar Troubleshooting
- Final Troubleshooting Steps
The advanced technology of radar level gauges provides accurate level measurement for industrial liquids and solid materials. Radar devices send microwave signals through a process that allows them to determine surface-to-transmitter distances for material measurements. These devices serve as the industry choice because their exact measurement capabilities provide benefits beyond hydrostatic and capacitive and ultrasonic methods.
Radar level transmitters provide reliable and accurate measurements but operational difficulties might arise when used under high temperature and pressure conditions or in corrosive environments and when foam forms or when the process includes turbulence and steam interference. These environmental factors result in system breakdowns which require more extensive maintenance along with production disruptions.
The identification and timely resolution of routine faults remains key to achieving maximum performance operation.
The following sections describe common problems radar level gauges face with accompanying troubleshooting recommendations to decrease measurement downtime and keep accuracy.
| Symptom | Possible Cause | Action |
| Radar level gauge shows very slow changes or no change at all after liquid level rises | Equipment’s fuse may have burned out | Check if the fuse is burned out and replace it if necessary |
| No current output from the radar level gauge | Power supply issue or instrument malfunction | Verify power supply, check fuse condition, and replace or repair instrument if needed |
| Slow or no change in liquid level measurement | Incorrect power supply connection, polarity reversal, or instrument setup issue | Ensure proper power supply connection, verify polarity of wire connections, and check instrument parameter settings |
| Inconsistent readings or operational failures | Lack of proper maintenance and management | Strengthen installation and commissioning management, conduct regular maintenance and power cycle checks |
| Instrument fails to respond after power-on | Possible internal fault or incorrect installation | Inspect the device, confirm correct setup, check polarity of wire connections, and perform necessary repairs or replacements |
| No power to the level transmitter | No supply voltage, blown fuse in marshalling cabinet | Check supply voltage at terminal; if no voltage, inspect and replace faulty fuse. |
| No power despite a healthy fuse | Faulty barrier/isolator | Inspect the barrier/isolator for damage and replace it whenever it is faulty. |
| Transmitter still does not power on | Faulty transmitter power card | The transmitter power card requires replacement when voltage exists but there is no power output. |
| Radar level gauge malfunctions in high-temperature environments | Internal temperature exceeds 50°C | The system must maintain inner temperatures below 50°C by implementing heat-resistant components. |
| The radar level gauge fails to operate because the temperature increased. | Inadequate cooling method applied | The radar gauge head requires cool air delivery through a copper tube instead of ice water application. |
| Erratic readings or system failure | Electronic components overheating | Periodic temperature checks must be followed by appropriate cooling protocols. |
| Radar level gauges demonstrate failures during operations at elevated temperatures. | Inappropriate transmitter selection | Choose a new transmitter that shows compatibility with high-temperature environments based on the supplier-provided specifications. |
Must-Read: What is a guided wave radar level transmitter?
| Communication failure with radar level gauge | Faulty communication unit | Run the radar debugging software to verify the proper status of configuration data. |
| Incorrect or missing signal transmission | Radar sensor misinterpreting echoes | The sensor requires proper configuration to properly differentiate between original reflections and false echoes. |
| Weak or no signal reception | Low reflected wave intensity | Verify the reflected wave intensity matches the established standard requirements. |
| Persistent communication errors | Faulty electronic components | Perform inspections on damaged communication components followed by replacements when necessary. |
| Unstable connection | Poor maintenance of communication equipment | The radar debugging software enables access to signal lines as well as proper regulator maintenance. |
Explained: Level measurement using Radar technique
| Displayed value is incorrect | Improper initial settings or incorrect connections | Review and fix both initial settings procedures and display module wiring connections. |
| Display is unreadable | The initial settings for contrast ratio function improperly. | Users should adjust display contrast settings to make the screen more visible. |
| Incorrect display despite correct settings | Faulty display module | Test the display output current and replace the display module when the current reading exceeds 22mA. |
| Output current less than 3.5mA | Faulty electronic module | The replacement of the radar level gauge’s electronic module is necessary. |
| Fluctuating or unstable readings | External interference or sensor calibration issue | Take the necessary steps to protect the sensor from external interference then perform a calibration check if needed. |
Essential Guide: What is a radar level transmitter and how can it be used to do the level measurement?
| Symptoms | Causes | Actions |
| Measured value fluctuates significantly | Measurements fluctuate greatly when stirrers create surface turbulence. | The system requires improved application parameters that can eliminate rapid changes in measurements. |
| Temporary interference in readings | An interfering echo effect occurs when the sensor picks up signals from the feeding process. | Enabled usage of near-field suppression prevents the reception of unnecessary signals. |
| Unstable level measurement | Insufficient signal due to improper installation | Verify that the installation position is suitable and optimal |
| Weak or unstable signal reception | A small antenna leads to inadequate signal reception. | The installation of a larger antenna will lead to improved signal reception strength. |
| Measurement variations despite stable process | Low output damping settings | Raising output damping levels will help reduce measurement variations. |
| Symptoms | Possible Causes | Recommended Actions |
| System displays an error message | The interruption of power supply occurred before the system finished saving data points. | Thoroughly check power stability while making sure there are no interruptions during power supply. |
| Frequent error messages appear | The system shows errors because it needs calibration or the parameters are incorrect. | Begin by resetting the system then calibrate it and check all application parameters. |
| Alarm persists after reset | Faulty or damaged electronic module | Install a new electronic module inside the radar level gauge system. |
| Inconsistent error messages | External interference or wiring issues | Verify that all electrical connections are secure while checking for electromagnetic interference. |
| The liquid measurement shows an empty or low level. | Reflection occurs from brackets or pipes installed at the container bottom. | Check and readjust the installation process to reduce interference. |
| Liquid level measurement failure | Radar waves experience diffusion because of steam formation within the measured system. | Allow steam to vaporize until the system reaches normal temperature. |
| Unstable or fluctuating readings | Radar waves change direction after reflecting from rough surfaces and blockage obstacles | Maintain a clear measurement path through proper adjustment of mounting position. |
| Measurement does not recover immediately | System error due to previous reflections | Wait for the liquid level to stabilize then start the system to allow automatic recovery functions |
| Measurement failure or inaccuracy | Antenna contamination due to oil or residue | Users should first switch off power before they slowly remove the radar and wipe down the antenna with a cleaning rag. |
| Weak or unstable signal | Crystallization on the antenna | Use a downward tilt position to remove crystals by lightly wiping the antenna surface with a soft cloth. |
| Persistent measurement errors | Damage or scratches found on the antenna surface | Pay attention to antenna handling while you should not use metal tools during cleaning procedures. |
| Antenna performance degradation | Accumulated dirt affecting signal transmission | The system requires periodic maintenance together with inspections to stop accumulation from forming. |
| A “Wave Loss” error may occur together with system crashes. | Low dielectric constant liquid with weak reflection | Set applications to optimal values by analyzing vessel process characteristics. |
| Weak or no return wave | A combination of vortex motion turbulence with thick foam material results in wave diffusion and absorption. | Users should modify measurement parameters while possibly switching antenna placement or dimensions. |
| Frequent wave loss | Poor signal due to installation position | The antenna should be moved to a different position or a larger antenna must be used to enhance signal return quality. |
| The signal continuously disappears in difficult environmental conditions. | The usage of extreme process conditions such as scarring slurry creates problems. | Those conditions suitable for waveguides or bypass tubes may implement their use. |
| Inconsistent readings | External interference or improper installation | Choose the best positions during installation while ensuring the removal of all possible interference elements. |
| The level sensor maintains steady reading either at 0% or 100% status. | Sensor error or power issue | Execute a power reboot procedure on the transmitter device. |
| After a transmitter reboot value remains either at 0% or 100% value. | Moisture, vapor, or dirt on sensor | Use a soft cloth to clean the sensor before inspecting physical wear and tear. |
| Inconsistent or stuck readings | The sensor path encounters blockages stemming from spider webs and rust or bulging structure elements. | Check the wave path along with the sensor cone and the flange to ensure cleanliness. |
Must-Have: 15+ Collection of Level Measurement Calculators for Industrial Instrumentation
| There is a difference in value measurements between the field equipment and the PLC/DCS system | Configuration mismatch | Check all transmitter ranges by comparing them to the Level Coordination Diagram (LCD) and approved design documentation. |
| Fluctuating readings or operational failures | Excessive turbulence or air bubbles | Relocate the level transmitter to a more stable position if possible. |
| Rapid fluctuations in level values | Low damping value | Increase the damping (time constant) by a few seconds for better signal stability. |
| Guided wave radar not responding | Valves should be opened for extended pipe connections. | Check and open the valves to validate their functionality. |
| The radar system remains unresponsive despite checking all valves. | Contaminated probe | After cleaning the probe tip you should reinstall the transmitter. |
| Probe contamination persists | Material buildup on probe | The probe must undergo complete cleaning before reinstalling to its original spot. |
| Transmitter stuck at a fixed level reading | Severe probe contamination | Combine either hydro jetting or steam jetting to clean away accumulated material from the equipment. |
| Scenario | Action |
| The issue remains unresolved after all previous steps fail | Check the transmitter’s circuit cards for internal failures then replace them if needed. |
| If intermittent failures persist | Read the OEM (Original Equipment Manufacturer) manual according to the instructions provided for additional troubleshooting assistance. |
| The transmitter’s operation remains nonfunctional. | Contact an experienced field instrumentation expert or a member of the manufacturer support team for help. |
Click here to access 50+ Instrumentation and Control System Troubleshooting Procedure
