What is a Guided Wave Radar (GWR) Level Transmitter?
A Guided Wave Radar (GWR) level transmitter is a contact radar sensor that measures level using Time Domain Reflectometry (TDR). A low power nanosecond electromagnetic pulse is launched and guided along a probe rod, cable or coaxial tube. When the pulse encounters a change in dielectric such as air to liquid or liquid to liquid interface, part of the energy is reflected back to the transmitter.
The instrument measures the round trip time of the reflected signal and converts it into distance and level. Because the pulse is guided along the probe, the measurement is highly reliable even in vapor, pressure, turbulence and temperature variations.
GWR level measurement is widely used in refineries, chemical plants, separators, boiler drums, reactor vessels and storage tanks.
A guided wave radar sensor is a type of radar level sensor there are two types of radar level sensors they are through the air and guided type. This device can be used to measure the liquid level and it can also be used to do the liquid-liquid interface level measurement and this can be done for both process and ESD applications. GWR working is based on the principle of time-domain reflectometry.
The guided wave radar working principle is based on Time Domain Reflectometry.
Step by step explanation:
  • The level is calculated from the time of flight.
  • A short electromagnetic pulse is generated inside the transmitter electronics.
  • The pulse travels down the probe at nearly the speed of light.
  • When the pulse reaches a surface with a different dielectric constant, part of the signal is reflected.
  • The reflected pulse travels back to the electronics.
  • The transmitter measures the time difference between transmitted and received pulses.
A typical GWR level transmitter consists of:
  • Transmitter housing with electronics
  • Process connection flange or threaded connection
  • Probe assembly
  • Sealing arrangement
  • Terminal block and communication module
The electronics generate and receive microwave pulses while the probe guides the signal inside the tank.
Proper probe selection is critical for accurate GWR level measurement.
  • Used in small and medium height tanks
  • Mechanically strong
  • Suitable for clean liquids
  • Preferred in chamber mounting
  • Used for tall tanks
  • Suitable for storage tanks
  • Allows longer measurement ranges
  • Slightly more signal attenuation compared to rigid rod
  • Improved performance in low dielectric liquids
  • Good for interface measurement
  • Suitable for non metallic tanks
  • Best option for very low dielectric liquids
  • Excellent signal strength
  • Suitable for small nozzles and turbulent applications
The measuring signal and reflection are concentrated around the waveguide or inside the waveguide. There won’t be any impact of stray signals because of the narrow path of the signal propagation. The signal concentration on the waveguide would result in a cleaner stronger signal of the echo reflection.
GWR is widely used for liquid liquid interface level measurement in separators and desalters.
When measuring interface:
  • The first reflection occurs at the upper liquid surface.
  • A second reflection occurs at the interface between two liquids.
  • The transmitter distinguishes between total level and interface level.
For reliable interface measurement:
  • There must be sufficient difference in dielectric constant between upper and lower liquids.
  • The upper layer thickness must be adequate.
  • Stable process conditions improve accuracy.
Example: In a refinery desalter, GWR can measure oil water interface without impulse lines or frequent maintenance.
The dielectric constant directly affects reflection strength.
  • Water: 70 to 80
  • Alcohol: 20 to 30
  • Crude oil: 2 to 4
  • LPG vapor: around 1.1
  • High dielectric liquids produce strong reflections.
  • Low dielectric liquids require coaxial or twin rod probes.
  • If dielectric is extremely low, signal detection becomes difficult.
Example: Measuring gasoline with dielectric around 2 requires careful probe selection and proper configuration.
ParameterGuided Wave RadarNon Contact Radar
Contact with processYesNo
Performance in foamVery goodModerate
Low dielectric handlingGood with correct probeMay require higher dielectric
Installation complexityModerateSimple
Turbulence resistanceHighGood
GWR is preferred in difficult process conditions while non contact radar is preferred in corrosive or hygienic applications where probe contact is not desired.
FeatureGWRDifferential PressureUltrasonic
Density dependencyNoYesNo
Affected by vaporNoNoYes
Interface measurementYesYesNo
MaintenanceLowMedium to highMedium
Accuracy stabilityHighDepends on impulse linesModerate
  • Ignoring dielectric constant limits
  • Selecting wrong probe type
  • Not accounting for inactive zone
  • Installing near turbulence zone
  • Not grounding properly
  • Skipping echo curve verification
These mistakes often lead to unstable readings and frequent troubleshooting.
Guided wave radar is virtually not affected by the following process conditions
  • Conductivity
  • Temperature
  • Pressure and vacuum
  • Dielectric constant
  • Specific gravity
  • Vapor, steam, or dust
  • It can’t be used to measure the interface of two liquids
  • The ability of the detection is limited for the GWR in the case of foam
  • During the water sand interface, the transmitter can only detect the water
  • Chances of corrosion are high
  • The movement of the product in the tank could bend the waveguide
  • It is used in accumulators
  • Separators
  • Distillation and rectification towers
  • Reactor tanks and scrubbers
  • Liquefied gas containers
  • Boiler and feed-water systems
