PLC learning series 7: Functional Block Diagram program, symbols
What is Functional Block Diagram (FBD)?
The primary concept behind an FBD is data flow. A Functional block diagram describes a function between input and output through a functional block.
A FBD program is built using function blocks connected together to define the data exchange. The connecting lines will have a compatible information type at both ends.
  • FBDs use data flows through feature blocks from left to right.
  • Inputs and outputs can be inverted
  • Function blocks can have variable argument list sizes
  • When arguments are left off default values are used
A FBD contains..:
  • All major components
  • Interface to the outside world
  • Interface between subsystems
  • Identify power, data and structural interface
  • Should answer how the statement of mission is fulfilled
Basic Functional Blocks:
Example for FBD program:
PLC Learning series:
PLC learning series 2: PLC programming languages
