What are the High Tension and Low Tension line and how are they different from each other?
A transmission line is used to transfer electric power over a long distance, transmission lines can connect generating stations and substations. The transmission lines are classified according to their operating voltage. The word ‘tension’ stands for voltage.
Low Tension Line
A low tension line can be considered as the line that has an operating voltage till 1000 volt which is 1Kv. This is the 230V and 440V in our household so it is the local distribution line. Through the low tension or low voltage line we are receiving power to our home. Low tension lines are more susceptible to faults because it is connected to the loads.
An LT line refers to a Low Tension line, which is a type of power line used for distributing electrical energy at low voltages. These lines are primarily used for the final delivery of electricity to residential, commercial, and small-scale industrial consumers.
  1. Typically, LT lines operate at voltages below 1 kV, such as:
    • 230 V for single-phase systems.
    • 415 V for three-phase systems.
  2. LT lines are used for the last-mile distribution of electricity to end-users from distribution transformers.
  3. LT lines are often made with insulated cables and mounted on poles or underground systems to ensure safety and efficiency.
  4. Since the voltages are lower compared to HT lines, the safety risks are comparatively reduced, but proper insulation and earthing are still critical.
  • Supplying electricity to households and small businesses.
  • Powering small-scale machinery in workshops or small industries.
  • Street lighting and other public utilities.
An HT line refers to a High Tension line, which is a type of power line used for transmitting electrical energy at high voltages. High tension lines are part of the electrical distribution and transmission system, primarily used to deliver electricity over long distances with minimal energy loss.
  1. Typically, HT lines carry voltages ranging from 11 kV to 220 kV (or even higher in some cases). These voltages are higher than those used for domestic or industrial consumption.
  2. They are used for bulk power transmission between power plants, substations, and industrial facilities.
  3. HT lines are constructed with insulated or bare conductors, supported by towers or poles, and designed to withstand environmental stresses.
  4. Due to the high voltages, HT lines require strict safety measures, including appropriate clearances and protective devices, to ensure human safety and reliable operation.
  • Electricity transmission between generating stations and substations.
  • Power supply to large industrial plants.
  • Interconnection of regional power grids.
HT line
The high voltage transmission is done by using several transformers, cascade arrangement of the transformer is done. The low voltage winding will be connected to the transformer’s primary and this will be connected to the transformer tank, the above figure shows how cascade-connected transformers can generate high voltage by using the low voltage.
The operating voltage could influence the leakage distance, other factors are switching surge and lightning overvoltage and they would influence the required insulator chain length and striking distance.
We need high voltage transmission lines to transport energy over a long distance, power transmission is done in high voltage because while transmitting the power in high voltages less current is used. So because of the less amount of current we only need small conductors.
  • HT Lines: High Tension, used for voltages above 1 kV.
  • LT Lines: Low Tension, used for voltages below 1 kV (e.g., household electricity).
Understanding the distinction between HT and LT lines is crucial in the context of electrical power systems.
The major difference between these lines are their operating voltage, we can see lots of faults in the low voltage transmission side while comparing to the high voltage transmission and it is because the LT sides are connected to the load. So on the LT side, we can see a lot of variations and lots of trouble, while in the high tension line we won’t able to see this much fault and it is because that the HT lines are not directly connected to the load.
The insulators that are used in low tension lines are small pin type insulators and shackle type insulators, while for underground transmission this will be different. The insulators that are used in high tension lines will be pin type insulators and disc type insulators, the cables that are used in HT lines up to 11KV will be rabbit ACSR cables and these cables are capable to hold 157-ampere current. In the case of HT lines, it is more than 11KV which could be up to 33KV then dog-type cables are used. The cables that are used on the low tension side will be a squirrel type. In low tension power transmission, we would use four wires which would be R, Y, B, and neutral, and the low tension wires will always be star connected. In the case of high tension line, there will be only three wires and we can’t see neutral in this section and these lines will be delta connected.
The transmission line from the substation to the pole-mounted substation will be a high tension line and from the pole mounted substation our house or office is a low tension line and mostly there won’t be any transformers between low tension lines but we can see transformers in high tension lines. So basically we can say that a high tension line and low tension line is for power transmission but to do the operation of our equipment we need low voltage.
