- Importance of Proper Impulse Tube Sizing
- Recommended Impulse Tube Diameters
- General Rule for Impulse Tubing Selection
- Effect of Tube Diameter on System Performance
- Response Time vs. Tube Diameter
- Tube Diameter Selection Formula: Reynolds Number & Pressure Drop
- Practical Tube Diameter Selection Guide
- Special Considerations for Impulse Tubing
- Material Selection
- Best Practices for Impulse Tubing Installation
- Tray Routing for Instrument Tubes
- Selection of Impulse Tubing
- Commonly Used Tubing Materials in Process Industries
- Common Tube Sizes in Process Industries
- Impulse-Line Diameters: ISO 2186:1973 vs. ISO/CD 2186:2004
- Easy Selection Table for Impulse Tubing
- Important Impulse Tubing FAQs
- What is the maximum length of impulse tubing?
- What size is impulse line tubing?
- What is the slope of impulse tubing?
Impulse tubes enable pressure signal transmission to pressure transmitters by linking process taps to measurement and control systems. The selection process for tube diameter stands as a vital factor which determines measurement accuracy together with system response time and reliability.
Key Factors Influencing Tube Selection
- Delayed Response Time: Pressure transmission becomes delayed due to long tubes which have narrow diameters.
- Pressure Loss: The use of narrow tubes results in high resistance that causes pressure readings to become inaccurate.
- Clogging Risk: The usage of small-diameter impulsive tubes results in high clogging susceptibility when monitoring process fluids that are viscous or contain dirt.
The optimization of measurement performance together with system efficiency results from proper balancing of these factors. Selecting an incorrect impulse tubing results in both operational inefficiency and hardware failures while increasing maintenance expenses. The correct choice of tubes contributes to stable measurement readings and makes the transmitter more reliable while addressing operational problems. The selection of appropriate tubing components becomes crucial within corrosive environments because it determines both durability and extended operation time.
Tube OD (mm) | Tube ID (mm) | Application |
6 mm (1/4″) | 4 mm | Short impulse lines, low-pressure applications |
10 mm (3/8″) | 7 mm | Medium-length impulse lines, moderate response time |
12 mm (1/2″) | 9 mm | Long impulse lines, high-viscosity fluids, faster response |
The diameter of longer impulse tubes needs to increase to reduce pressure drop and speed up response time.
The usage of narrow tubes leads to increased blocking risks and pressure instability problems which render them inappropriate for processing high-viscosity materials or contaminated substances.
Organized installation practices which minimize pipe bends and utilize secure fittings advance both impulse line operational excellence and stability.
Don’t Miss This: What are Impulse lines? – Impulse line problems and solutions
Pressure measurement system accuracy and response time together with system reliability depend heavily on the diameter of impulse tubes. The selection of suitable tube dimensions enables systems to work effectively while reducing issues affecting performance like pressure drop as well as clogging and delayed signals.
Advantages of Larger Diameter (10-12 mm)
- The application of larger diameter tubes delivers faster response times because it minimizes pressure resistance which remains essential for monitoring steam pressure in rapidly changing systems.
- The accurate pressure readings are sustained throughout long distances since the minimizing of friction brings about reduced pressure loss.
- The wider tube dimensions prevent blocking from particulate matter and fluid slurries and viscous fluids which decreases maintenance requirements.
- Ideal for long distances & high-viscosity fluids: Ensures smooth fluid movement and stable signal transmission in extended impulse lines.
Disadvantages of Larger Diameter (10-12 mm)
- More expensive: Requires more material, increasing procurement and installation costs.
- Larger diameter pipes become heavier to set up and need more installation support systems due to their greater bulk.
- The installation of larger tubes proves difficult when dealing with restricted installation spaces.
Advantages of Smaller Diameter (6 mm)
- Lower material consumption helps keep costs down which enables budget-friendly operation with affordable hardware.
- Installation in confined areas becomes easier because these pipes are lightweight and flexible.
- Small-diameter tubing provides suitable results for stable pressure requirements and quick responses when used across short distances.
Disadvantages of Smaller Diameter (6 mm)
- The signal transmission speed through pressure signals becomes slower due to higher resistance which creates problems for fast process control systems.
- Narrow tube dimensions create an elevated chance of clogging from material particles that lead to frequent maintenance needs.
- An increase in resistance introduces greater pressure loss which reduces signal accuracy when impulse lines reach extended lengths during operations that experience temperature changes along with condensate buildup.
The response duration between a control system and the fluid depends on both pipe length and diameter together with fluid properties.
Tube ID (mm) | Response Time (sec) for a 5m Line (Water-filled) |
4 mm | 2.5 sec |
7 mm | 1.0 sec |
9 mm | 0.6 sec |
- Fast processes that need to perform accurate control operate better when the system response time remains short. Examples include steam pressure monitoring and differential pressure flow measurement.
- When response times are extended they introduce time delays that render real-time monitoring useless for crucial systems. The usage of larger diameter tubes leads to enhanced response times which enhances the accuracy of dynamic processes.
- The overall performance of the pressure measurement system depends on correct pipe routing which requires minimal bends along with low elevation changes.
Using an appropriate impulse tube diameter remains essential to achieve both efficient pressure transfer and quick response speed and measurement precision.
Tube selection for impulse systems depends on two major elements which include Reynolds Number (Re) and Pressure Drop.
Reynolds Number Formula
The value of Reynolds number decides between laminar and turbulent flow conditions in tubes thus influencing both response time performance along with measurement accuracy.
Where:
- ρ = Fluid density (kg/m³)
- v = Fluid velocity (m/s)
- D = Tube internal diameter (m)
- μ = Fluid dynamic viscosity (Pa·s)
Flow Classification Based on Re
- Under Re < 2000 the flow remains laminar leading to delayed feedback and increased measurement lag together with reduced speed of response.
- Turbulent Flow occurs at Re > 2000 leading to faster response time and reduced damping effects while providing accurate dynamic control.
- The recommended condition for quick pressure transmission while minimizing lag involves maintaining a Re value greater than 2000.
Must-Have Tool: Reynolds Number Calculator: A Practical Excel Tool
Minimizing Pressure Drop
Any pressure drops that happen in the system will lead to measurement precision reduction alongside incorrect reading results. To minimize it:
- Shortening impulse tubes and widening their diameters leads to reduced resistance inside the tubes.
- Pathways should have smooth curves without additional fittings since smooth routes promote consistent water flow and reduces turbulence.
- When selecting tubing for the inner surface one should choose materials with smooth surfaces to minimize flow interruptions and signal delay formation.
- System efficiency will stay steady when operators conduct regular cleaning procedures as well as maintenance routines that prevent sediment buildup and debris accumulation.
Choosing proper tube dimensions depends on the length of your impulse line in addition to your process fluids’ properties.
Tube Length | Process Type | Recommended Tube ID | Recommended Tube OD |
< 5m | Low-pressure, clean fluids | 4 mm | 6 mm (1/4″) |
5-15m | Medium response needs | 7 mm | 10 mm (3/8″) |
> 15m | Fast response, dirty/viscous fluids | 9 mm | 12 mm (1/2″) |
The rule applies that longer tubes demand bigger diameters for cutting down pressure loss together with decreasing response time.
Example Applications
- For measuring steam pressure use 9 mm (1/2″) tubes which provide fast response and minimal response delay.
- Using 7 mm (3/8″) tubes strikes an ideal balance between responsiveness and installation easiness for gas pressure sensing applications.
- Usage of 4 mm (1/4″) tube diameter suits liquid level transmitters when quick response is not essential for short-range transmissions.
- In chemical processing facilities designers should pick tubing materials such as SS316 or PTFE-lined tubing because these substances stand up against corrosion while fighting off contaminants to deliver dependable service.
Standard pressure transmission and extended system reliability depend on proper implementation of impulse tubing. The performance of pressure instrumentation requires material selection along with proper installation methods and adequate environmental protection against possible failures.
Material Selection
The selection of appropriate tubing materials serves two essential functions: it extends operational life and guards against fluid-induced corrosion while sustaining fluid compatibility.
- Stainless Steel (SS 316/SS 304): Ideal for harsh environments due to excellent corrosion resistance and high strength. SS 316 serves as the preferred choice when operating at hazardous offshore platforms and chemical plants.
- Copper Tubing: Copper tubing finds its place in instrument air systems because it possesses built-in corrosion resistance and provides easy bending capabilities which helps improve installation efficiency in control panels as well as HVAC systems.
- Hastelloy C276: The material Hastelloy C276 functions well in corrosive chemical processes since it maintains its integrity during chlorine exposure and acid solutions yet stainless steel would corrode.
- Monel: The corrosion-resistant nickel-copper alloy Monel proves to be ideal for stopping seawater and chemical damage thus working best for marine and water-based chemical operations.
- PVC or PTFE Tubing: Used for flexible applications and aggressive chemical exposure. The resistance of PTFE-lined tubing includes protection against acids and solvents along with high temperatures thus it is commonly used in chemical processing plants and laboratory environments.
System reliability receives significant benefits from proper installation practices which simultaneously reduce pressure drops and stop mechanical equipment failure. Key best practices include:
- A slope between 70-80 mm/m should be maintained to allow correct water drainage while stopping materials from collecting inside fluid-filled impulse lines.
- The positioning of tubing should remain at a distance from heat sources since steam lines and exhaust manifolds can cause expansion that affects pressure measurements.
- Mechanical support through clamp tubing applications every 3 feet (1 meter) helps minimize vibration-induced failures in the system.
- Proper spacing between impulse tubes should be maintained for accessible operations and smooth maintenance practices while also reducing risks of unnecessary stresses.
- Perforated trays serve as an asset for enhancing tubing durability because they shield the tubing from corrosive waters while blocking harmful materials that reduce longevity.
- You should utilize fittings that match each other to stop galvanic corrosion particularly during metal joining processes between stainless steel and copper.
- Excessive bending of tubing along with kinking creates sharp bends which block fluid flow causing pressure drops that potentially lead to long-term structural failures of the system.
Refer the below link for the Method Statement for Pressure Test and leak Test for Instrument Tubing and Impulse line
The routing and protection of impulse tubes must be correct for sustained functionality under harsh industrial conditions.
- The routing and protection of impulse tubes must be correct for sustained functionality under harsh industrial conditions.
- PVC-coated tubing works well where environments show signs of corrosion or undergo chemical exposure or temperature extremes since it increases protection.
- The combination of copper tubes with stainless steel fittings should be avoided since the softer material allows the harder stainless steel components to puncture or damage it.
- Heat tracing systems should be installed to protect process fluids inside impulse tubing from freezing especially in cold locations thereby avoiding blockages that generate inaccurate pressure readings. Heat tracing includes electrical and steam-based systems that depend on the specific use application.
Essential Guide: Best Practices for Impulse Tubing Installation
The selection of impulse tubing affects both measurement precision alongside operational security along with production operational effectiveness. Inadequate selection of materials or dimensions for tubing components has been found to cause industrial incidents according to USCSB findings in their investigation of the DuPont Chemical Accident that involved faulty tubing materials.
Material | Applications |
SS316 | High-pressure, high-temperature, and corrosive fluid applications in chemical and oil & gas industries. |
Copper | Instrument air systems, HVAC, and general low-pressure applications. |
Hastelloy C276 | Chlorine service, acid-handling, and highly corrosive environments. |
Monel | Marine installations along with seawater distribution and water-based chemical manufacturing processes make up its main uses. |
PVC | Temporary connections in low-pressure air or water service. |
- The combination of 1/4-inch SS316 and 1/2-inch SS316 tubes represents the standard in pressure measurement applications.
- The combination of 1/8-inch SS316 with 1/4-inch SS316 represents a popular selection for analytical instruments together with sample transport lines.
- The standard length for tubing stands at 6 meters but custom orders for individual requirements are possible.
ISO 2186:1973, which is still in effect, includes a table specifying very long impulse-line lengths and large diameters, as shown in Table 1. In the updated ISO/CD 2186:2004, the longest impulse-line lengths and largest diameters have been removed, and the new recommended values are shown in Table 2.
The revised standard emphasizes that the shortest possible impulse line lengths should be used. However, if this is not feasible, guidance on the preferred impulse-line diameter can be found in Table D.1 of ISO/CD 2186:2004, which is equivalent to Table 2 below.
Table 1: Impulse-Line Diameters from ISO 2186:1973
Type of Metered Fluid | 0 to 16 m | 16 to 45 m | 45 to 90 m |
Water/Steam and Dry Air/Gas | 7 to 9 mm | 10 mm | 13 mm |
Wet Air/Wet Gas | 13 mm | 13 mm | 13 mm |
Oils of Low to Medium Viscosity | 13 mm | 19 mm | 25 mm |
Very Dirty Fluids | 25 mm | 25 mm | 38 mm |
Table 2: Impulse-Line Diameters from ISO/CD 2186:2004
This table provides a quick and easy reference for selecting impulse tubing based on process type and length.
Process Type | Tube Length | Recommended Tube ID | Recommended Tube OD | Notes |
Clean Fluids (Water, Air, Steam) | < 5m | 4 mm | 6 mm (1/4″) | Suitable for short impulse lines, minimal pressure drop. |
5 – 15m | 7 mm | 10 mm (3/8″) | Balances response time and accuracy. | |
> 15m | 9 mm | 12 mm (1/2″) | Ensures fast response and minimal pressure loss. | |
Wet Air / Wet Gas | < 16m | 13 mm | 19 mm (3/4″) | Prevents condensation buildup and blockages. |
> 16m | 13 mm | 19 mm (3/4″) | Maintains stable pressure transmission. | |
Oils (Low/Medium Viscosity) | < 16m | 13 mm | 19 mm (3/4″) | Reduces pressure loss and improves flow stability. |
> 16m | 19 mm | 25 mm (1″) | Suitable for longer impulse lines, prevents clogging. | |
Very Dirty Fluids / High Viscosity | Any Length | 25 mm | 38 mm (1.5″) | Prevents blockages, ensures smooth flow. |
The maximum recommended length is 16 meters. Longer runs can cause delays and vibration issues, so electrical or pneumatic transmission is preferred for greater distances.
Impulse tubing is available in different sizes:
- Inches: 1/8, 1/4, 3/8, 1/2, 3/4, and 1
- Millimeters: 6, 10, 12, 20, and 25
Impulse tubing should have a minimum slope of 1 in 12:
- For liquids, the slope should go down from the tapping point.
- For gases, the slope should go up from the tapping point, unless venting and draining are provided.
