- Programmable Controllers and Industrial Logic
- Industrial Communication and Data Integration
- Functional Safety and Risk Management
- Cybersecurity and Industrial Information Security
- Alarm Management and Operator Interface
- Device Management and Smart Instrumentation
- Electrical Cables and Installation Standards
- Control Center Infrastructure
- Additional Highly Recommended Standards
- Why this International Standards for Control System are Important?
- Frequently Asked Questions on Control System Standards
- What is the IEC standard for control panels?
- What does IEC 62443 cover in control systems?
- What is the ISO standard for control system safety?
- Which IEC standard applies to access control systems?
- What are the key requirements of IEC 61439?
- What is NFPA 79 and why is it important?
In modern industrial environments ranging from oil & gas, pharmaceuticals, and power plants to discrete manufacturing adherence to international standards for control systems is not just recommended; it is essential. These standards set up structured frameworks that make sure that all hardware, software, and operational levels are safe, function together, are secure, and are reliable.
This guide presents more than 30+ important international standards that are utilized in projects linked to control systems, organized by category. Professionals may make sure that industrial systems follow the rules, lower risks, and make sure they will work in the future by knowing and following these standards.
IEC 61131 – Programmable Controllers
The backbone of PLC standardization. This standard lists the hardware and software needs for programmable controllers. Part 3 talks about programming languages like:
- Ladder Diagram (LD)
- Function Block Diagram (FBD)
- Structured Text (ST)
- Instruction List (IL)
- Sequential Function Chart (SFC)
Many vendors, including Siemens, Rockwell, Schneider, and Mitsubishi, agree on this.
IEC 61499 – Function Blocks for Distributed Control Systems
Sets up a framework for distributed automation that allows you control events and change the system’s setup easily. It makes IEC 61131 better by adding support for modular, Industry 4.0-based architectures that can work with other systems and move around.
IEC 61499 is becoming more and more significant in decentralized architectures based on the IIoT, especially in systems that combine edge and cloud computing.
IEC 62541 – OPC Unified Architecture (OPC UA)
OPC UA is a communication framework that works with any vendor, is secure, and works on any platform. It connects the shop floor to systems at the business level and is an important part of smart factories that use IIoT.
It has features like:
- Data modeling
- Built-in security (encryption, authentication)
- Cross-platform access (Windows, Linux, embedded systems)
IEC 62714 – Automation Markup Language (AML)
AML backs up the idea of a “single source of truth,” which cuts down on mistakes in documentation, makes change management faster, and encourages interoperability in big projects.
IEC 60870 – Telecontrol Protocol
Mainly used for SCADA communication in systems that generate, transmit, and distribute power. 60870-5-101 and 60870-5-104 are examples of variants that handle the serial and TCP/IP communication protocols, respectively.
IEC 61158 and IEC 61784 – Fieldbus & Ethernet Communication
- IEC 61158 sets the rules for protocol stacks for fieldbus systems such as PROFIBUS, FOUNDATION Fieldbus, and Modbus.
- Ethernet-based systems, like PROFINET, EtherCAT, and Ethernet/IP, are covered by IEC 61784.
Fieldbus and industrial Ethernet protocols cut down on cabling, make things more reliable, and let you operate things in real time across factory floors.
Discover the Most Used Industrial Communication Protocols: Industrial communication protocols
IEC 61850 – Substation Automation
Sets up the rules for how electrical substations talk to one other by using object-oriented data models and fast messaging (GOOSE).
It also works with Process Bus and Sampled Values to support digital substations that send current and voltage data over fiber instead of copper.
IEEE/IEC 802 Series – IT/OT Network Standards
Covers Ethernet (IEEE 802.3), Wi-Fi (802.11), VLANs (802.1Q), and others that form the basis of industrial networking in modern control systems.
Refer the below link Must-Know IEC Standards Chart for Instrumentation and Control
IEC 61508 – Functional Safety of Electrical/Electronic/Programmable Systems
A foundational safety standard defining lifecycle and reliability requirements for electrical safety systems. It introduces SIL (Safety Integrity Levels) from SIL 1 to SIL 4.
IEC 61511 / ISA 61511 – SIS in Process Industries
Tailored for the process sector (oil & gas, petrochemicals), IEC 61511 builds on IEC 61508 to cover Safety Instrumented Systems (SIS) in real-world industrial environments.
This standard governs:
- Safety lifecycle phases
- Performance-based SIL verification
- Validation testing and functional checks
Understand the Key Differences Between IEC 61508 and IEC 61511: Difference between IEC 61508 & IEC 61511 SLC Version
ISA 84.91.01 – Mechanical Integrity of Safety Systems
Guides the identification and testing of safety-critical alarms, interlocks, and systems to ensure ongoing mechanical integrity.
It helps ensure that safety functions maintain performance through periodic inspection and integrity assessments, as part of safety management systems.
IEC 61882 – HAZOP Studies
It gives a way to undertake Hazard and Operability (HAZOP) studies, which are an important aspect of risk assessment for process design and system upgrade projects.
HAZOP is very important when adding new chemicals, procedures, or digital control systems since it helps you see how they could interact or change the process in ways you didn’t expect.
ISO/IEC 27001 – Information Security Management Systems (ISMS)
A worldwide standard for handling private information and IT systems that can be used in industrial situations where OT and IT work together.
Many process plants that employ MES, ERP, or cloud platforms to control their operations use this standard.
ISO/IEC 27002 – Implementation of Security Controls
Includes access control, incident response, system acquisition, and encryption as examples of best-practice control mechanisms.
ISA/IEC 62443 – Cybersecurity for Industrial Automation and Control Systems
One of the most complete sets of rules for keeping SCADA, DCS, and IIoT systems safe. It includes:
- Asset Owner responsibilities (62443-2-1)
- System-level security capabilities (62443-3-3)
- Product development lifecycle for suppliers (62443-4-1)
Implementing 62443 enhances resilience against cyber-attacks, which is especially critical in energy, chemicals, and critical infrastructure.
ISA 18 / IEC 62682 – Alarm Management
Establishes procedures for alarm rationalization, prioritization, and suppression, ensuring effective operator response and reducing alarm floods.
A structured alarm philosophy based on this standard improves operator efficiency and plant safety, especially during startup and shutdown scenarios.
EEMUA 191 – Alarm System Design Guide
Highly respected guide used globally, complementary to ISA 18. Focuses on human factors, design, performance monitoring, and training.
ISA 101 – HMI Design Standards
Defines human-centered display design for control systems, boosting clarity, uniformity, and operator situational awareness.
Modern HMIs built to ISA 101 help operators find problems faster and cut down on misunderstandings during process upsets.
ISA 108 – Intelligent Device Management
This standard explains automated diagnostics and smart device integration, which helps engineers switch from reactive to proactive maintenance plans.
ISA 108 makes it possible for HART, Foundation Fieldbus, and WirelessHART devices to work together in smart maintenance systems.
IEC 60228 – Conductors in Insulated Cables
Sets the standards for copper and aluminum conductors, making sure that control and power cables are the right size and have good electrical continuity.
IEC 60331 – Circuit Integrity Under Fire
Tests if cables still work when exposed to fire, which is important for safety systems in dangerous places.
IEC 60332 – Flame Retardant Cable Testing
Checks how wires spread flames, which helps keep fires from getting worse in small control rooms and industrial panels.
ISA 60 – Control Center Facility Standards
Includes ergonomics, layout, lighting, HVAC, and other environmental aspects that are needed for a control room to work well and reliably.
Following the rules makes sure that operators are comfortable over the long term, that operations run smoothly, and that human factors engineering concepts are followed.
IEC 60079 – Explosive Atmospheres
A very important series for making instrumentation and control systems in dangerous places (Zones 0, 1, and 2). Includes temperature classes, explosion-proof equipment, and intrinsically safe circuits.
ISA-TR20 – Instrumentation Specification
Technical reports that give you templates and instructions for designing loops, picking instruments, making datasheets, and writing system documentation.
ISO 50001 – Energy Management Systems
ISO 50001 makes ensuring that there are defined ways to monitor and improve energy performance when energy efficiency is built into automation.
It helps with ongoing improvement and is in line with environmental compliance and sustainability goals.
NIST SP 800-82 – ICS Cybersecurity Guidelines
NIST SP 800-82 is mostly used in the United States, but it is also used all around the world to protect PLCs, DCSs, RTUs, and SCADA from cyber attacks. It adds to the work done by ISA/IEC 62443 and ISO 27001.
Codes and Standards You Need to Know for Control Valve Selection: Codes and Standards for Control Valve Selection in Industrial Applications
Putting these standards into your control system projects has real-world benefits:
- Better interoperability between systems from different providers
- Consistent procedures for design, engineering, and commissioning
- Better safety for operators and dependability for the plant
- Cybersecurity and functional safety built in
- Easier audits, inspections, and getting permission from the government
- Easier to adapt to new technologies like IIoT, Digital Twin, and AI
Aligning your design, operations, and cybersecurity strategy with these worldwide standards is a smart move for long-term success, whether you’re starting a new automation project from scratch or modernizing old systems.
You Must Understand NAMUR Sensors in Hazardous Areas: Why NAMUR Sensors are Essential in Explosive and Hazardous Areas ?
The international standard IEC 61439 tells you what you need to do to design, put together, and test low-voltage switchgear and control gear assemblies. In 2014, it took the place of the earlier IEC 60439 standard to keep up with new safety standards and technological progress. This standard makes ensuring that electrical panels used for power distribution, motor control, and automation systems are safe to operate, reliable, and consistent.
ISA/IEC 62443 is a full set of standards that deals with cybersecurity for Industrial Automation and Control Systems (IACS). It gives organized rules for planning, building, and keeping secure systems at different points in their lifecycle. The standard talks about the duties of asset owners, system integrators, and product vendors. It also helps figure out how mature and risk-resistant the cybersecurity is in industrial settings.
IEC 60839-11-1:2013 sets the lowest standards for how electronic access control systems must work, how well they must perform, and how they must be tested when they are used to regulate who can enter and leave buildings and secure areas. This standard makes guarantee that access control parts like readers, controllers, locks, and credential-verification devices work the same way every time.
IEC 61439 gives extensive instructions for low-voltage electrical assemblies, including what manufacturers and verifiers are responsible for. The standard has:
- Temperature rise limits
- Dielectric properties
- Short-circuit withstand capacity
- Mechanical strength
- Internal separation
It is commonly used to build and certify distribution boards, motor control centers (MCCs), and other control panels in factories and businesses.
The National Fire Protection Association (NFPA) set NFPA 79 as the Electrical Standard for Industrial Machinery. It sets the rules for the electrical wiring, grounding, and safety systems for industrial machines in the US. In the U.S., machines must follow NFPA 79 in order to be lawfully connected to power sources. It makes sure that electrical systems are safe, lowers the risk of fires, and is in line with international regulations for industrial equipment.
