Your Instrumentation Tools Resource
Welcome to your one-stop resource for essential instrumentation tools. This toolkit simplifies your instrumentation tasks, whether you’re calibrating transmitters, simulating PID loops, or converting signals and units. Discover free PID loop simulation tools, calculate split ranges with ease, and ensure compatibility in your projects. With an instrumentation tool  on-the-go conversions, your instrumentation tasks just got simpler. Explore our range of tools for efficiency and precision in one convenient place.
Your Instrumentation Tools Resource 1
The following are some of those most often used instrumentation tools:
  1. Excel Tool for DP Type Level and Density Transmitter Calibration Range Calculation
  2. Excel Based PID Loop Simulator
  3. Reynolds Number Calculator: A Practical Excel Tool
  4. Free PID Loop Simulation Tools
  5. Split Range Calculator – Control System
  6. Pressure Safety Relief Valve Basic Sizing Tool – Liquid Applications
  7. Pressure Safety Valve Sizing Excel Tool for Gas Applications
  8. Orifice Plate Flow and Pressure Drop Calculation Excel Tool
  9. Control Valve Cv Calculation Excel Tool for Liquid, Gas, and Steam Services
  10. Control Valve Sizing Excel tool Without Iteration: Liquid Application
  11. Free Excel Tool for Liquid Pressure Drop Calculation: Piping Systems and Field Instrumentation
  12. Unit Conversion Tool for Instrumentation Engineer
  13. Tool for Converting Instrumentation Standard Signals and Process Variables
  14. Android Application to Convert Instrumentation Standard Signals and Process Variables
  15. Control Valve P1 and P2 vs. Flow Excel Designing Tool (Downloadable)
  16. Fluid Velocity Excel Calculator for Instrumentation Design Engineers
Click here for 200+ Online Instrumentation Calculators Collections
Electrical Engineering Excel Tools
Electrical Excel tools are a number of spreadsheets that are meant to assist electrical engineers & technicians in performing their works. These spreadsheets may be found in Excel. These tools have the capability to automate complicated computations, provide reports, and make drawings.
Electrical Excel outcomes may automate complicated calculations and procedures, which frees up time needed to focus on other essential tasks. This results in increased productivity.
Your Instrumentation Tools Resource 2
The following are some of those most often used Electrical Excel tools:
  1. Grounding Conductor Calculator
  2. Voltage Drop Calculator
  3. Electricity Consumption Calculator
  4. Transformer Short Circuit Current Calculation
  5. Optimizing Power Systems for Large Motor Startup: Transformer Sizing and Voltage Drop Analysis
  6. Transformer Protection with IDMT Relays (Over Current / Earth Fault / Differential)
  7. Electrical Load Analysis Tool: Transformer, Fuse, and Circuit Breaker Sizing
  8. Insulation Resistance in Excel: Simplifying Calculations for Safer System
  9. Electrical Equation Solver: Ohm’s Law Excel Toolkit
  10. Reactive Power Calculator
  11. Neutral Grounding Transformer (NGT) Calculator
  12. Transformer Stability Test Calculator
  13. Electrical Power Load Calculation Worksheet
  14. Electrical Wire Gauge and Size Calculator: From AWG to Metric and British Standards
  15. Fault Current Calculator
  16. Voltage Drop in Cables: Online Excel Tool
  17. Parallel Transformer Fault Analysis: Excel Calculator
  18. Knee Point Voltage Calculation for HT Motor
  19. Inverse Defined Minimum Time (IDMT) Calculator
Click here for more Electrical Calculators
