Why Restriction Orifice is Some Distance from Blowdown Valve?
In many industrial systems, particularly in the oil and gas industry, the arrangement of blowdown valves (BDVs) and restriction orifices (ROs) is critical for guaranteeing both safety and operating efficiency. The placement of a restriction orifice at a distance from a blowdown valve is not only excellent engineering practice, but it is also heavily influenced by safety and performance considerations.
To understand this, let’s look at how these components work, what role they play in systems, and why their separation is critical.
  • A restriction orifice (RO) is a device used in piping systems to control the flow rate and drop pressure by introducing a fixed restriction in the pipe.
  • The orifice plate forces the fluid or gas to pass through a smaller cross-sectional area, resulting in a controlled flow rate and predictable pressure drop.
  • Unlike flow measurement orifices, a restriction orifice is designed specifically to handle high-pressure drops or to limit flow.
  • Blowdown valves are critical components used to depressurize equipment or pipelines in an emergency or during maintenance shutdowns.
  • They safely transfer high-pressure fluids into lower-pressure systems, such as flare headers, preventing catastrophic failures and equipment damage.
  • A restriction orifice, on the other hand, is intended to limit the flow of fluid, ensuring that the flow rate is controlled and the pressure drop distributed over a set distance.
  • The restriction orifice downstream of the blowdown valve controls the pace at which pressure is released and prevents the flow from overloading downstream equipment.
  • The combination of a blowdown valve and a restriction orifice is commonly used in process systems to safely depressurize pipelines, vessels, and other pressurized components.
  • However, the separation of these two components is more than just convenient; it addresses a number of critical technological and safety issues.
The 600 mm spool piece or space commonly seen between a blowdown valve and a restriction aperture is not arbitrary. It is useful for specialized thermal, mechanical, and flow dynamics applications.
  • The Joule-Thompson (JT) effect, which describes the temperature move that occurs when a gas expands without performing external work, is the most important reason for keeping a space between the blowdown valve and the restriction orifice.
  • When high-pressure fluids, particularly gases, travel through the restriction orifice, their pressure drops significantly, resulting in a considerable decrease in temperature.
  • When the temperature downstream of the restriction orifice falls below subzero due to this action, the cold fluid might transfer its “coldness” back upstream toward the blowdown valve.
  • This increases the chance of freezing, particularly if moisture is present in the atmosphere. The blowdown valve body can freeze, leading components like the stem to become trapped.
  • This makes it difficult or impossible to seal the valve following the blowdown operation, potentially resulting in hazardous backflow or system failure.
  • Engineers can reduce the risk of freezing and malfunction by placing a 600 mm (or more) spool piece between the blowdown valve and the restriction orifice.
  • This allows for some thermal dissipation while avoiding direct thermal conduction between the orifice and the valve body.
  • Another reason to place a restriction orifice some distance from the blowdown valve is to avoid flashing.
  • Flashing happens when a high-pressure liquid suddenly vaporizes when it comes into contact with a lower pressure zone, causing excessive noise, vibration, and cavitation within the pipeline.
  • These effects can cause damage to both the blowdown valve and the surrounding pipes.
  • A spool piece provides a smoother pressure transition between the blowdown valve and the restriction orifice.
  • This decreases the risk of flashing and severe vibrations, protecting the valve and piping.
  • The principal pressure drop in a blowdown system happens across the restriction orifice rather than the blowdown valve.
  • The spool piece helps fluid to flow more smoothly from the valve to the orifice, ensuring that the pressure drop is controlled and predictable.
  • Without adequate spacing, turbulent flow downstream of the valve may cause secondary choking or uneven flow distribution over the orifice, resulting in inefficient blowdown or damage to downstream equipment.
  • By positioning the restriction orifice away from the blowdown valve, the system can create a more uniform and laminar flow, ensuring a consistent pressure drop and reducing the possibility of localized high-velocity zones that could erode the orifice plate or valve components.
Click here for Orifice Plate Flow Rate Calculator
Role of Restriction Orifices in System Safety and Efficiency
For the purpose of controlling pressure, flow rate, and system safety, restriction orifices are essential. The distance between a blowdown valve and a restriction orifice is crucial in the following particular applications and circumstances:
In blowdown systems, safe depressurization of equipment without excessive mechanical or thermal strain on the pipes is essential, particularly in petrochemical and refinery plants. By ensuring that the pressure decreases gradually over time, the restriction orifice helps to avoid unexpected depressurization, which could result in hazardous conditions.
A quick reduction in pressure at the valve could overload the system if the spacing is incorrect, resulting in high flow rates, vibration, or even equipment failure.
Click here for Orifice Plate Commissioning Checklist
Erosion is a possibility when high-velocity fluids pass through the restriction orifice, especially if there is a large pressure drop. In order to prevent cavitation and erosion of the orifice plate and the surrounding piping, a progressive reduction in velocity is made possible by the gap between the blowdown valve and the restriction orifice.
Using a multi-stage restriction orifice may be important in systems where cavitation is a concern in order to distribute the pressure drop over multiple stages and minimize damage possibilities.
Another factor that contributes to preserving the system’s overall integrity is the distance between the restriction orifice and the blowdown valve. Through the implementation of a uniform flow distribution and a progressive pressure drop, engineers can prevent localized stresses within the piping system that may otherwise result in catastrophic failure, leaks, or cracking.
Depending on the kind of fluid, the Joule-Thompson effect can vary considerably. distinct fluids, such as gases, liquids, and steam, have distinct flow characteristics. For instance, temperature drops due to gas expansion are typically considerably greater than those caused by liquid expansion.
Systems running at higher pressures will encounter quicker pressure dips at the restriction orifice, increasing the possibility of freezing and causing larger temperature swings.
The usable distance between the blowdown valve and the restriction orifice may occasionally be limited by spatial restrictions. Alternative techniques, including insulation or heating components, may be applied in these situations to keep things from freezing and guarantee correct operation.
Vibration and noise can be greatly increased by high-velocity fluids traveling through restriction orifices. Multi-hole or multi-stage restriction orifices are frequently employed to reduce these effects since they lower the fluid’s overall velocity and distribute the pressure drop over a number of stages.
To ensure operational safety and efficiency, a restriction orifice must be positioned at a certain distance from a blowdown valve. This is a basic feature of system design. This distance lessens the impact of the Joule-Thompson effect, keeps the valve body from freezing, stops vibrations and flashes, and guarantees a steady and gentle pressure reduction. The location of restriction orifices should follow best practices so that engineers may create systems that function safely and dependably, even in the most extreme circumstances.
Several types of restriction orifice plates are used, depending on the application, pressure drop requirements, and flow characteristics. Here’s an overview of the main types:
Single-stage Restriction Orifice
The single-stage restriction orifice consists of a single plate with one or multiple holes, designed to create a significant pressure drop in a single step. This type is commonly used where a single pressure drop is sufficient, and the fluid can handle the associated temperature change without flashing or cavitation.
  • Simple design.
  • Single pressure reduction.
  • Suitable for moderate pressure drops.
  • Depressurization systems.
  • Fluid throttling where minor pressure drop suffices.
  • Process isolation for pipelines.
Single-stage Multi-hole Restriction Orifice
The single-stage multi-hole restriction orifice is similar to a single-stage orifice but features multiple smaller holes instead of a single large one. The smaller holes reduce fluid velocity and distribute the pressure drop more evenly, which helps minimize noise, vibration, and potential cavitation.
  • Multiple holes to distribute flow.
  • Reduces noise and vibrations.
  • Prevents cavitation by reducing velocity gradients.
  • Situations where noise and vibration control is crucial.
  • Systems with gas or steam where cavitation needs to be minimized.
  • High-pressure drop applications in fluid systems.
Multi-stage Restriction Orifice Plate Assembly
In applications requiring high-pressure drops, a multi-stage restriction orifice plate assembly is often used. This design consists of multiple orifice plates installed in series within a single housing. Each plate drops the pressure incrementally, reducing the risk of cavitation, flashing, and equipment damage.
  • Staged pressure reduction to avoid damage.
  • Smooth flow transition between stages.
  • Effective at handling large pressure drops.
  • Gas pipelines in high-pressure environments.
  • Blowdown systems in refineries.
  • Process systems that require gradual pressure reduction.
Conical-shaped Restriction Orifice Plate
The conical-shaped restriction orifice plate has a specially shaped conical bore to smooth out the flow and reduce turbulence. This shape helps to minimize energy loss, control flow more precisely, and avoid rapid changes in velocity and pressure.
  • Conical bore for smooth flow.
  • Reduces turbulence and energy loss.
  • Precise flow control.
  • High-velocity gas flows.
  • Systems requiring precise flow control.
  • Pipelines in high-speed applications.
Click here for Classification of Orifice Plates & Pressure Tappings in Orifice Plate
Restriction orifice plates are used in a wide variety of industrial applications where precise control over flow rates and pressure drops is critical. Here are some common applications:
Restriction orifice plates are widely used to reduce pressure in pipelines. For example, they are used in natural gas distribution systems to step down high-pressure gas to manageable levels before entering low-pressure zones.
In industries such as oil and gas and petrochemical plants, blowdown systems use restriction orifices to safely depressurize equipment by gradually reducing the pressure in a controlled manner, preventing damage from sudden pressure drops.
Many systems, such as pumping stations and cooling water systems, require flow limitation to avoid over-pressurizing sensitive equipment downstream. Restriction orifices ensure that flow rates remain within the desired limits.
In steam systems, restriction orifices are often used to control noise and vibration generated by high-velocity flow or sudden pressure reductions. The use of multi-stage or multi-hole orifices helps to distribute the pressure drop and reduce acoustic emissions.
In high-pressure liquid systems, particularly in refineries and chemical plants, cavitation is a significant concern. Restriction orifices help to reduce the pressure gradually, preventing the liquid from flashing into vapor and causing cavitation that could damage pipes and equipment.
Click here for How Cavitation happens in a Control Valve?
In many fluid power systems, such as in the automotive or aerospace industry, excess energy needs to be dissipated to maintain system stability. Restriction orifices provide controlled energy dissipation through pressure drops, preventing instability in hydraulic or pneumatic systems.
In centrifugal pump systems, a restriction orifice is often placed in the pump’s recirculation line to maintain a constant flow. This recirculation flow helps prevent cavitation or starvation of the pump, ensuring reliable operation. In this case, the exact flow rate isn’t as critical, and the RO serves the primary purpose of keeping some fluid moving through the pump at all times.
ROs are placed downstream of blowdown valves to regulate flow during depressurization. When the valve opens, the RO limits the flow rate, preventing overloads in downstream systems like flare headers. Pressure drops across the RO can be significant, often between 80-100 bar. The RO design must account for the temperature drop caused by the Joule-Thomson effect.
ROs control gas flow from high-pressure separators to low-pressure separators, especially in the event of valve failure. By restricting gas blow-by, they prevent downstream systems from becoming overloaded, offering protection to both liquid and gas handling processes.
During plant start-up, ROs are used to gradually pressurize sections of the system. This prevents damage from rapid pressurization by limiting flow rates. For gasses, choked flow conditions are typically targeted to maintain control over flow rates.
A Restriction Orifice works based on Bernoulli’s principle, which explains how fluid velocity and pressure change when it flows through a restricted passage.
  • When fluid passes through the smaller cross-sectional area of the restriction orifice, the velocity of the fluid increases.
  • According to Bernoulli’s equation, as the velocity increases, the pressure decreases. This leads to a pressure drop across the orifice.
  • The pressure difference between the upstream (before the orifice) and downstream (after the orifice) sections is created due to this velocity change. This pressure drop is proportional to the flow rate.
  • By measuring the pressure drop, the flow rate of the fluid can be determined.
Restriction orifices are primarily used to control flow rates or reduce pressure in piping systems.
While no specific international codes exist solely for restriction orifice (RO) plates, several standards provide guidelines relevant to their design, installation, and performance.
These references ensure that RO plates are designed and operated in accordance with best practices. Some important standards include:
  1. ISO 5167 Part 1: Measurement of fluid flow by means of pressure differential devices inserted in circular cross-section conduits running full – General principles and requirements.
    This standard provides general guidelines for using devices like orifice plates to measure fluid flow in pipes.
  2. ISO 5167 Part 2: Measurement of fluid flow by means of pressure differential devices inserted in circular cross-section conduits running full – Orifice plates.
    This part focuses specifically on orifice plates, which are similar in design principles to restriction orifices.
  3. IEC 60534-8-3: Industrial-process control valves – Noise considerations – Control valve aerodynamic noise prediction method.
    This standard provides methods to predict and mitigate aerodynamic noise in control systems, which can also apply to systems using restriction orifices to manage flow and pressure.
Click here for Orifice Plate Flow Measurement Quiz: Test Your Knowledge of Fluid Dynamics
Restriction orifice (RO) plates and standard orifice plates serve different functions in process systems. Below is a summary of their key differences:
FeatureRestriction OrificeOrifice Plate
PurposeUsed to reduce pressure or control flow rate (pressure-reducing).Used for measuring flow rate.
Hole ProfileThe hole has a straight profile.The hole starts straight but is beveled with a 45° slope.
Pressure DropCauses a high-pressure drop.Causes a relatively lower pressure drop.
Fluid VelocityOperates at sonic velocity to ensure choked flow.Fluid passes through at subsonic velocity.
Acoustic Induced VibrationHighly susceptible to acoustic-induced vibration (AIV) and noise.Not generally susceptible to AIV.
When sizing a restriction orifice, several factors need to be considered to ensure optimal performance and to avoid operational issues.
The pressure drop is a key factor when selecting the RO. The thickness of the orifice plate depends on the required pressure drop across the device.
The orifice must be sized for a normal flow rate. For critical ROs, it’s important to also consider the downstream flow rate, especially if significant pressure drops are expected.
Choked or sonic flow occurs when the gas velocity reaches the speed of sound as it passes through the restriction. This can generate high noise and vibrations that may lead to mechanical failure. To prevent this, the pressure drop across a single-stage RO must be limited to the critical pressure drop.
In liquid systems with large pressure drops, cavitation can occur when vapor bubbles collapse after passing through the orifice, potentially causing damage. To prevent cavitation, the restriction orifice should be sized so that the cavitation index remains below the incipient cavitation threshold, based on the beta ratio of the orifice.
Noise levels in ROs can be predicted by calculating the sound power generated by pressure reduction. To reduce noise, options such as multi-stage ROs or noise-reduction features should be considered during sizing.
Click here for Orifice Sizing Guidelines & Rules Associated With Selection
Click here for Different types of orifice plates
