What is a plug valve? What are plug valves used for
What is a plug valve and what are plug valves used for
Plug valves are widely used in the process industry, these valves operate by rotation motion and are used to stop and start the fluid flow. Plug valves are basically on-off valves, based on a plug with a rectangular hole through which the fluid flows. The plug could be tapered or cylindrical and they are in the valve body, a quarter-turn rotation is done to make the pipe and hole in the same line and this would be the open state and in the closed state, it would be across the pipe. Plug valves are easy to adapt and they are suitable for multiport use, so that valve can be used to divert the flow. In parallel plugs, the shape of the port is rectangular and triangular for taper plugs. Because of this shape, a slimmer valve can be constructed with less weight. Mostly plug valves are used for starting and stopping the flow, it can also be used for flow diversion. Plug valves are capable to handle fluids with solids in suspension because the seating moves against each other with a wiping motion and in the fully open position.
By using a lubricated plug the valve can be engineered, which uses lubricant to do proper operation over a wide range of pressures.
There is unlubricated design too, that includes seals in the plug and requires plastic bearing systems.
What are the components of the plug valve
How plug valves are constructed
Tapered plug and the body are the main parts of the plug valve, maximum flow efficiency can be created by the proper design of the internal contours of the valve. Mostly in the tapered plug, the port is rectangle-shaped and has round ports. Full flow is obtained when the opening in the tapered plug is aligned in the direction of flow and when the plug is rotated a quarter turn flow is terminated.
How does a plug valve work
With the help of a cylindrical or tapered plug, the plug valve does the quarter-turn operation from fully open to fully closed state. The plug provides a hole through one axis, which can connect the inlet and outlet of the valve, so in an open position, there would be a straight-through flow, the flow would be properly blocked when it is rotated 90 degrees to the closed position.
What are the types of plug valve
Lubricated plug valve
In a lubricated plug valve, the plug is provided with a cavity in the middle along its axis. This cavity is closed at the bottom and fitted with sealant injection fitting at the top. The cavity is injected with sealant and the sealant is prevented from flowing in the reverse direction by the check valve below the injection fitting. Lubricated plug valves are safe from fire and have a better life. These valves are used in power plants because of their small size. These valves are able to handle gas and fuel. There won’t be any danger due to leak because they are properly sealed.
Non-lubricated plug valve
In the body cavity of the non-lubricated plug valves, a sleeve or an elastomeric body liner is installed. The tapered and polished plug would act as a wedge and presses the sleeve against the body. So the friction between the body and the plug is reduced by the help of a non-metallic sleeve
What is an eccentric plug valve
These valves are provided with plugs that are mounted off-center. These plug valves are used in corrosive and abrasive service for on-off action. These plug valves move into and away from seat eliminating abrasive wear.
What is the difference between the plug valve and ball valve
The major difference is how they operate, in a ball valve it uses a ball like a gate is used to close the flow, while in case of plug valve it uses a plug to close the flow.
What are the advantages of plug valves
  • Flow regulation
  • Size of this valve is small so that it only uses less space
  • It provides tight shutoff, quick opening and low-pressure drop
  • Fire safety
  • Plug and body seating surfaces are not exposed to the line fluid, which would reduce the corrosion and erosion loses
  • It can be used with large flow rates
What are the disadvantages of plug valves
  • Plug valves could be subjected to galling
  • Because of high friction, greater force is needed to actuate
  • Not suitable for throttling applications
  • Reduced port due to tapered plug
  • The plug could be damaged because of the friction between plug and body
What are the applications of plug valves
  • Remote maintenance is possible
  • Stopping and starting flow
  • Gases liquids and non-abrasive slurries
  • It can be used for fuel gas piping system
  • These valves are widely used in refineries
  • It is used in chemical industries
  • Fly ash applications
  • Vacuum to high-pressure applications
  • It can be used for blocking
To get more information about control valves, check the following link
