What are the various causes of electric motor failure?
The use of electrical motors in the industries is rapidly increasing day by day due to their higher flexibility, and reliability compared to other electrical machines. Electrical motors play a vital role in making the industry or plants run effectively and smoothly.
Due to the wide use of electrical motors, any fault in the motors in the industry affects the entire operation of the plants. A failure in the motors may lead to sudden unavailability, production stops financial losses and also lost money for the repairing.
Here we will discuss various reasons for the failure of electric motors
Various causes of electric motor failure and their remedies
  • Electrical Overload
  • Low Resistance
  • Over-Heating
  • Phase Unbalance
  • Contamination
  • Vibration
  • Surge Voltages
  • Over cycling
  • Loose Connections
pie chart of various motor failures chances
Pie-Chart of various motor failure causes
Electrical Overload
An excessive current flow within the motor windings causes electrical overload or over-current, which exceeds the design current that the motor can safely and efficiently carry. A low supply voltage can cause this, causing the motor to draw additional current in an attempt to maintain torque. Short circuited conductors or an excessive voltage source might also cause it.
Remedy for Electrical Overload: Installation of effective over-current protection, which detects overcurrent and interrupts power
Low Resistance
Low resistance is the most prevalent cause of motor failure, and possibly the most difficult to overcome. The insulation of the windings degrades owing to situations such as overheating, corrosion, or physical damage, resulting in low resistance. This results in a lack of isolation between the conductors or motor windings, which can lead to leaks and short circuits, as well as motor failure.
Remedy for Low Resistance: Insulation should be evaluated for symptoms of deterioration on a regular basis and replaced before low resistance causes failure.
Over-Heating
Excessive heat is a leading cause of electric motor failure as well as a symptom of other motor issues. Motor insulation deteriorates as a result of heat. The windings are shorted as the motor insulation deteriorates, and the electric motor ceases to work.
When the temperature of an electric motor exceeds the insulation’s temperature rating, the insulation’s life is diminished. The insulation will fail faster as the temperature rises. The insulation class refers to the temperature grade of electric motor insulation.
Factors to increase the overheat of the motors are:
  • The motor is the wrong size or kind for the job.
  • Inadequate cooling, mainly due to dirt accumulation
  • Excessive load is frequently a result of poor usage
  • The friction is excessive, mainly due to misalignment or vibration.
  • voltage unbalance, phase loss or surge voltages are common electrical issues.
Remedy for Over-Heating: The motor must be kept as cool as possible, and keeping the operating environment as cool as feasible can assist avoid problems.
Phase Unbalance
The unbalance that develops when electricity lines are out of phase is known as phase unbalance. When one load is applied to a three-phase system, phase unbalance occurs, causing one or both lines to carry more or less of the load.
Winding of a motor where Phase Unbalance issue occurs
Phase Unbalance
During installation, the electricians balance loads of three power systems. However, as more than 1 load is introduced to the system, the system becomes unbalanced. As a result of the imbalance, the three lines have moved out of phase and are no longer 120 degrees apart electrically.
Windings of a Single-Phased Motor
Single-Phased Windings
Three-phase electric motors run at temperatures higher than their indicated ratings due to phase imbalance. The temperature rises in direct proportion to the phase mismatch. These high temperatures cause the insulation to break down, as well as other issues.
Remedy for Phase Unbalance: A three-phase monitor relay, also known as a phase failure relay, is a low-cost and simple-to-install solution for preventing costly damage to your motors and equipment caused by phase unbalance.
Contamination
One of the most common reasons for motor failure is contamination from dust, grime, and chemicals. Foreign objects that get inside the motor can dent the bearing raceways and balls, causing excessive vibration and wear. It may also disable the cooling fan, reducing the motor’s ability to regulate temperature and raising the risk of overheating.
How to reduce contamination rate in a motor ?
Contamination
Remedy for Contamination: Contamination is relatively simple to avoid. To assist prevent the likelihood of contamination entering the motor, keep work locations, equipment, and fixtures as clean as possible. Also, when setting up your workstation, keep motors away from grinding machines that produce a lot of pollutants.
Vibration
Vibration can cause a variety of problems with the motor, and it can even cause it to fail prematurely. When the motor is placed on an uneven or unstable surface, vibration occurs. Vibration, on the other hand, might be caused by an underlying problem with the motor, such as loose bearings, misalignment, or corrosion.
Remedy for Vibration: Ensure that the motor is mounted on a level, sturdy surface to reduce vibration. Check for indicators of wear, as well as loose bearings or misalignment, if vibration persists. If you can’t figure out what’s causing the vibrations, consult a professional.
Surge Voltages
The voltage unbalances that happen when the voltages at the electric motor terminals are not equal are known as voltage unbalance. This voltage imbalance might range from a few millivolts to a complete loss of voltage on one power line.
One winding will overheat if the voltage is not balanced, causing thermal degradation of the winding insulation. A current unbalance is caused by a voltage imbalance.
Winding damage due to surge voltage
Surge Voltage Issue
Voltage unbalance should be verified on a regular basis and during all service calls. Complete the following steps if you discover a voltage imbalance of more than 2%:
  • Inform the power source provider
  • Look for high loads tied to a single line in the surrounding power supply.
  • Adjust the load or motor rating if the voltage unbalances cannot be addressed by reducing the load on the motor or oversizing the motor.
Over cycling
The process of frequently turning an electric motor on and off is known as over cycling. The starting current of an electric motor is normally five to six times the motor’s full-load running current. The majority of motors aren’t built to start more than ten times each hour.
When an electric motor reaches operating temperature and continues to cycle on and off, this is known as over cycling. The temperature of the motor will rise even higher, damaging the motor insulation.
Remedy for Over cycling: Check motor manufacturer user guidelines to find the number of on and off allowed within a specified period and follow the guidelines while starting and stopping the motor to avoid over cycling issues. Even starting and stopping beyond a number of counts within a specified period can be restricted through some logic using PLC/DCS.
Loose Connections
As they rotate, all-electric motors produce vibration. Mechanical and electrical connections can be loosened as a result of the vibration. Noise is usually caused by loose mechanical connections, which can be easily discovered.
Electrical connections that are loose do not generate noise, but they do cause a voltage drop in the motor and excessive heat. When diagnosing a motor, always check the mechanical and electrical connections.
Remedy for Loose Connections: Make a regular checking on instruments, various cables, etc. and take necessary action before a loose connection occurs
How do troubleshoot various motor failure issues?
1) Motors fail to start after installation
  • The motor is wrongly wired.
Make sure the motor is properly wired by checking the wiring diagram
  • Either the motor is damaged or the rotor is striking the stator.
Feel for rubbing as you rotate the motor shaft.
  • Issues with the power supply or the line
Examine overload, power supply, fuses, circuit breaker, and controls
2) The motor has been running for some time, but now it’s not working.
  • Check whether the circuit breaker is tripped or the fuse is burned.
Reset the breaker or replace the fuse.
  • The stator of the motor is either shortened or grounded ( Normally motor makes a humming noise and either the circuit breaker is tripped or the fuse is burned)
Examine the coils for any leakage. Replace the motor or repair if any leaks are found.
  • Overloaded or jammed motor
Check if the load is empty and check the motor’s amp rate on the motor’s nameplate
  • There is a chance of a capacitor (on a single-phase motor) has failed.
The capacitor should be checked.
3) The motor continues to run but eventually shuts off.
  • Drop-in voltage
If the voltage is less than 90% of the motor’s rated voltage, call your utility company or double-check that another piece of equipment isn’t stealing power from the motor.
  • The load has been raised.
Check to see whether the load has changed or if the equipment has tightened. Make sure the airflow hasn’t stopped if you are using the fan for cooling.
4) The Motor Is Turning the Wrong Way
  • Wiring that is incorrect
Replace the motor’s wiring according to the schematic that came with it.
5) Thermal Protector Continuously Trips/Motor Overloaded
  • The load is too heavy.
Make sure the load isn’t stuck. Remove the load from the motor and check the amp draw of the motor when it is not in use. It should be less than the nameplate’s maximum load rating.
  • The room temperature may be higher than the operating temperature.
Check to see if the motor is getting enough air to cool properly. The majority of motors are designed to operate at temperatures of 40°C or less.
6) Failure of Bearings
  • The load on the motor may be too great or imbalanced.
Check the motor load and make sure the drive belt tension isn’t excessively tight. The bearings will also break if the load is uneven.
  • Ambient temps are really hot.
A different type of bearing grease may be necessary if the motor is utilized in an environment with high ambient temperatures. It’s possible that you’ll need to speak with the factory.
  • High temperatures in the motor
Examine and compare the actual motor loads to the rated load capacity of the motor.
7) Capacitor Failure
  • Due to High Ambient Temperature
Check that the ambient temperature does not exceed the temperature rating of the motor (found on the nameplate)
  • The motor may be subjected to a power surge (caused by a lightning strike or other high transient voltage)
Install a surge protector if this is a common problem.
