Troubleshooting PLC Digital Output Signals – Advanced Industrial Quiz for Automation Engineers
In process industries, where solenoids, motor starters, interposing relays, and field valves all depend on reliable command execution, troubleshooting PLC digital output (DO) signals is an important ability. Failures happen a lot because of things like DO card channel degradation, blown fuses, wiring shorts, ground leakage, generated noise, or wrong sourcing-sinking combinations. Engineers need to look at real-time diagnostics including how the module LEDs behave, the history of output forcing, field voltage drops, relay chatter, and diode suppression health. It is important to know how PLC scan cycles affect the timing of output refreshes and how broken snubber circuits create back-EMF spikes. This quiz tests your ability to figure out complicated DO problems in real plants.
Prepare to put your troubleshooting skills to the test. This quiz puts you in tough situations with plants where digital outputs act strangely, stop working from time to time, or break field instruments. Every question makes you think like a senior controls engineer who is fixing a live problem. Jump in, do a detailed analysis, and make sure you know how to do PLC DO diagnostics.
Slow DO Degradation After Lightning Event
A lightning surge hit the plant. weeks later, 3 DO channels intermittently fail under load.
Incorrect Interlocking Behavior
DO-controlled motor starter fails to start because an interlock relay does not energize despite correct command.
DO Output Oscillates with Plant Earth Fault
A nearby MCC earth fault causes intermittent activation of DO equipment.
Valve Not Closing Fully
Valve remains slightly energized after OFF command. Voltage measured at coil is 4V.
Two DOs Interfering Electrically
Two outputs appear coupled; energizing one produces a weak activation of another.
Module LED Flashing Fast
A fast-blinking DO LED typically indicates:
DO Not Switching Due to Wrong Load Type
A new field device does not energize though voltage is present.
DO Response Delayed by 50 -70 ms
Field device activates noticeably later than PLC commanding ON.
Interposing Relay Coil Burnout
Relay coil burns frequently although DO voltage is stable at 24V.
False Activation of Solenoid
Solenoid occasionally energizes without DO logic ON.
DO Card Not Powering Up
Module remains offline though PLC backplane is powered.
DO Acting Like PWM Output
An ON command produces rapid pulsing (oscillation) seen on a relay.
Isolated Channel Failure
Only one DO channel fails; others work perfectly. Module diagnostics show “channel shorted.”
Device Not Responding After Panel Shutdown
After a maintenance shutdown, several DOs fail to energize devices though PLC logic is fine.
DO Module Overheating
A DO module overheats, particularly around one channel. Current is within permissible limits.
Intermittent Trip of an ON–OFF Valve
Valve loses power randomly though DO remains ON. Field measurement shows sudden voltage drops to 10–12V.
DO Channel Bleeds Voltage
A de-energized DO shows 3–5V at the field terminals. Why?
Solenoid Extremely Slow to Act
A solenoid driven by a PLC DO responds slowly though DO switching is correct. Coil voltage is 22V instead of 24V.
DO LED ON but No Field Voltage
The DO module LED turns ON, but multimeter shows zero volts at the terminal.
DO Works Only During Day Shift
Intermittent DO failure only occurs during day shift when large motors operate. DO voltage dips to 12–14V intermittently.
Blown Fuse Pattern
Every time a specific DO energizes a solenoid, the 24V supply fuse blows instantly. What is the most likely issue?
Output Remains ON After Forcing Removed
An engineer forced ON a DO for testing. After releasing the force, the field output remains energized. PLC logic shows output false. Why?
Solenoid Coil Heating Excessively
A solenoid controlled by a DO is overheating and eventually failing. Current measured at 1.3× rated value.
Interposing Relay Not Picking Up
A DO energizes an interposing relay, but the relay flickers continuously. Module LED stays ON steadily. Most likely cause?
DO Channel Failing Under Load
A PLC DO channel energizes a solenoid only when disconnected from the field. Once connected, the output drops to 5V instead of 24V. What is the most likely cause?
The average score is 47%
