Table of Contents
- Piping and Instrumentation Diagrams (P&IDs) are pivotal documents in the design and operation of industrial processes.
- They provide a graphical representation of the process, encompassing equipment, instrumentation, and piping systems. As an instrumentation design engineer, ensuring the accuracy and completeness of P&IDs is paramount for the safety, efficiency, and functionality of the process.
- The following comprehensive checklist serves as a guide for reviewing P&IDs, covering various aspects from tagging and symbology to equipment specifications and operability considerations.
Project P&ID Design and Verification Procedure
Tagging
- Verify tagging against the project tagging philosophy.
- Ensure consistency with project standards or vendor standard symbols.
- Verify that all equipment is properly tagged and that the title above each piece of equipment is accurate, with correct spelling.
Symbology
- Cross-reference symbols with project standards or vendor guidelines.
- Ensure clarity and consistency in symbol representation.
Inlet and Outlet Design Parameters
- Verify design pressure/temperature for inlet and outlet streams.
- Confirm operating conditions align with equipment and process requirements.
- Collaborate with process engineers to ensure accuracy. Document verification process, addressing discrepancies as needed.
- Ensure compliance with codes and standards. Update documentation accordingly for clarity and accuracy.
Key Equipment Design Parameters:
- Verify key equipment design parameters including pressure, temperature, material, and dimensions.
- Confirm operating conditions align with specifications. Assess corrosion allowance to ensure equipment integrity.
- Verify design parameters for vessels, heat exchangers, heaters, boilers, tanks, pumps, turbines, compressors, including size, temperature, pressure, duty, and relevant controls.
- Coordinate with process and mechanical engineers for accuracy. Document findings and update specifications accordingly for compliance and safety.
Drawing Layout and Organization:
- Ensure that the drawing layout is clear and organized, with equipment logically arranged and lines routed in a systematic manner to avoid confusion.
Legends and Abbreviations:
- Check that all legends and abbreviations used in the drawing are consistent and clearly defined in the legend or accompanying documentation.
Click here to know about P&ID legends
Line Types and Weights:
- Verify that line types and weights are used consistently throughout the drawing to distinguish between different types of lines (e.g., process lines, utility lines, instrument lines).
Annotation and Annotations:
- Review all annotations and annotations on the drawing for accuracy and relevance, ensuring that they provide necessary information without cluttering the drawing unnecessarily.
Alignment with Standards:
- Ensure that the P&ID drawing adheres to relevant industry standards, codes, and best practices, including those related to symbols, abbreviations, and drawing conventions.
Material Selection:
- Refer to the project material selection report for key components.
Line Sizing:
- Refer to piping class for material and ratings.
Valve Sizes:
- Ensure appropriate sizing of valves based on process requirements.
Valve Positions and Functions:
- Verify valve positions (normally open or closed) and functions, including block/bypass valves, reducers, and alignment with the latest specifications from the controls department.
Instrumentation:
- Assess suitability of instrumentation for selected parameters.
- Confirm ranges, alarm set points, and trip set points.
- Check for compatibility with control systems and interfaces.
Control Panel Interfaces:
- Review signals to/from main control room and field instruments.
- Check for hardwired signals and serial linked signals.
- Ensure clarity in signal pathways and communication protocols.
Pressure Relief Valves:
- Verify sizes and set pressures of pressure relief valves.
- Confirm proper installation and connection to relief systems.
- Ensure that pressure relief valves are correctly sized, with set pressure, inlet/discharge size, and proper installation according to design requirements.
Control Loops:
- Ensure proper integration of control loops between instruments and equipment.
- Verify functionality and feedback mechanisms for control systems.
Termination Points:
- Check for accuracy of termination points for instrumentation and piping.
- Ensure clear identification and labeling of termination points.
Notes:
- Review project requirements, exceptions, or operational points noted on the P&ID.
- Verify clarity and completeness of notes regarding design considerations.
Consistency:
- Ensure consistency between P&IDs and related documents such as instrument index, control philosophy, and line list.
- Cross-check information across different documents to ensure alignment and accuracy.
Title Block:
- Confirm completeness of title block information including signatures, dates, and revisions.
- Ensure inclusion of all necessary company logos and client signoff blocks.
Equipment Details:
- Check equipment details such as size, design parameters, and utilities.
- Verify compliance with specifications and standards.
Instrument Types:
- Review instrument types and configurations for suitability and accuracy.
- Confirm proper placement and labeling of instruments.
- Assess whether instrumentation types are appropriate for the application, including local/transmitted, control type, and block/bypass valves.
Valve Installation:
- Ensure proper installation of valves including position, orientation, and functionality.
- Verify inclusion of block/bypass valves and reducers as necessary.
Safety Devices:
- Confirm presence and accuracy of safety devices such as relief valves and pressure gauges.
- Verify proper sizing and installation according to design requirements.
Line Routing:
- Check for clear and logical routing of process lines.
- Ensure avoidance of congested areas and interference with other equipment or structures.
Insulation:
- Verify insulation requirements for piping, equipment, and instruments.
- Ensure proper indication of insulation materials and thickness.
Operability:
- Ensure clear identification of the drawing, including company document/drawing number, client document number, and licensor/vendor document number, if applicable.
- Consider operational factors such as start-up, shutdown, and normal operation procedures, ensuring that the drawing accurately reflects the sequence of operations and necessary controls.
- Assess operability for start-up, shutdown, and normal operation scenarios.
- Identify any potential operability issues and propose solutions.
- Compliance:
- Ensure compliance with industry standards, codes, and regulatory requirements.
- Verify adherence to company policies and procedures.
Stream Flags and Conventions:
- Ensure that stream flags follow plant conventions, indicating the fluid, drawing number, and the equipment the stream is from/going to.
- Verify that stream connections between drawings are correct, with all inlet streams matching outlet streams or providing an adequate explanation for deviations.
Connection Accuracy
- Ensure that lines connect according to the project’s branch table, including tie points at all old/new line interfaces.
Battery Limits:
- Mark battery limits clearly on the drawing to delineate the boundary of the process unit.
Line Arrows:
- Check that line arrows are present on each turn of a line and indicate the correct flow direction.
Drawing Clarity
- Confirm that the drawing is not overcrowded, maintaining an appropriate number of equipment pieces per drawing for clarity.
Documentation:
- Review completeness and accuracy of documentation, including revision history and numbering.
- Confirm inclusion of all necessary drawings and specifications.
- Establish effective documentation control procedures for managing P&IDs.
- Maintain a centralized repository for storing and accessing P&ID documents.
- Ensure version control and traceability of P&IDs throughout the project.
- Review revision triangles, clouds, and other markings to ensure that revisions are properly documented and any changes are accounted for in the drawing.
Expansion Provisions:
- Verify provision for future expansion and scalability of the system.
- Ensure inclusion of tie-in points and flexibility in design.
Redundancy:
- Assess redundancy measures for critical systems and components.
- Verify backup systems and fail-safe mechanisms.
Emergency Procedures:
- Verify that emergency response procedures and equipment (e.g., emergency shutdown systems, fire protection equipment) are appropriately depicted and labeled on the drawing.
- Ensure clarity and accessibility of emergency information.
Interface Compatibility:
- Check compatibility of interfaces between different systems and components.
- Verify proper integration and communication between control systems.
Accessibility:
- Ensure accessibility of equipment for maintenance and inspection activities.
- Identify any accessibility issues and propose solutions.
Environmental Considerations:
- Assess environmental impact of the process and equipment.
- Verify compliance with environmental regulations and guidelines.
Training Requirements:
- Identify training requirements for operators and maintenance personnel.
- Ensure inclusion of training materials and documentation.
Risk Assessment:
- Make a risk assessment to find possible hazards and risks.
- Propose mitigation measures to minimize risks and ensure safety.
Communication:
- Maintain open communication with other engineering disciplines and stakeholders.
- Address any concerns or discrepancies through effective communication channels.
Collaboration:
- Promote cooperation and teamwork among project team members.
- Encourage participation and input from all stakeholders.
Quality Assurance:
- Implement quality assurance measures to ensure accuracy and reliability of P&IDs.
- Conduct regular reviews and audits to identify and address any quality issues.
- Check for adherence to project specifications, codes, and industry standards.
- Ensure adherence to company policies and procedures.
Continual Improvement:
- It is important to aim for continuous improvement in the procedures and practices of P&ID design.
- Learn from past experiences and incorporate feedback for future projects.
Adaptability:
- Remain flexible and adaptable to changes in project requirements and constraints.
- Be proactive in addressing any changes or challenges that arise during the design process.
Innovation:
- Explore innovative solutions and technologies to enhance P&ID design efficiency and effectiveness.
- Embrace new tools and methodologies to improve workflow and productivity.
Documentation Management:
- Establish effective documentation management processes to ensure version control and traceability.
- Implement a centralized repository for storing and accessing project documentation.
Revision Management:
- Ensure proper management of revisions throughout the project lifecycle.
- Document revision history and update P&IDs accordingly.
- Coordinate with project stakeholders to communicate revisions effectively.
Accuracy Verification:
- Conduct regular reviews and audits to verify the accuracy of P&IDs.
- Cross-check information with other project documents to ensure consistency.
- Address any discrepancies or inconsistencies promptly.
Training and Development:
- Invest in training and development programs for engineering staff.
- Provide them the chance to develop their skills and advance their careers.
- Encourage an environment of cooperation and knowledge exchange inside the company.
- Promote the exchange of technological know-how, best practices, and lessons discovered.
Stakeholder Engagement:
- Engage with stakeholders throughout the project lifecycle to ensure alignment of expectations and requirements.
- To improve decision-making processes, get opinions and suggestions from appropriate stakeholders.
Risk Management:
- Determine project hazards and use proactive risk management techniques to reduce them.
- Develop contingency plans to address potential issues and minimize project disruptions.
Project Coordination:
- Coordinate closely with other project teams and disciplines to ensure seamless integration of design elements.
- Communicate effectively to resolve conflicts and maintain project schedule and budget.
Client Satisfaction:
- Prioritize client satisfaction by delivering high-quality deliverables that meet or exceed expectations.
- Ask for input from customers to determine their level of satisfaction and pinpoint areas that need work.
Regulatory Compliance:
- Verify adherence to relevant norms and regulatory requirements.
- Stay informed about updates and changes to regulations that may impact project design and execution.
Environmental Sustainability:
- Incorporate principles of environmental sustainability into design decisions and practices.
- Seek opportunities to minimize environmental impact and promote resource conservation.
Health and Safety:
- Prioritize health and safety considerations throughout the design process.
- Implement measures to protect the health and safety of workers and the surrounding community.
- Conduct a mini-HAZOP to identify potential safety and operability issues, ensuring that deviations in temperature, pressure, flow, or utility failures are appropriately addressed and documented for operators.
Project Closure:
- Conduct thorough project closure activities to ensure all deliverables are complete and stakeholders are satisfied.
- Keep a record of your best practices and lessons learned for future reference and ongoing development.
Downloadable P&ID Checklist for Instrumentation Design Engineer
Please follow the link below to access the downloadable P&ID Checklist for Instrumentation Design Engineers.
Click here to learn more about Piping and Instrumentation Diagrams (P&IDs)
Click here to Step-by-Step Guide: Reading and Interpreting Piping and Instrumentation Diagrams (P&ID)
Click here to know about Common P&ID symbols used in Developing Instrumentation Diagrams
