Millibar (mbar) to Millimeter of Mercury (mmHg) Pressure Unit Conversion Calculator
This calculator enables you to convert pressure values from Millibar (mbar) to Millimeter of Mercury (mmHg), commonly used in meteorology, scientific research, and various engineering applications requiring standardized pressure measurements.
The Millibar (mbar) is a unit of pressure equivalent to one-thousandth of a bar or 100 Pascals. It is widely utilized in meteorology to measure atmospheric pressure and is also used in other scientific and engineering contexts.
The Millimeter of Mercury (mmHg) is a unit of pressure that represents the force exerted by a 1-millimeter column of mercury at 0°C under standard gravity. It is frequently used in barometry, medical applications, and vacuum systems.
Suppose you have a pressure of 1013.25 mbar.
To convert it to mmHg:
1013.25×0.75006=760?mmHg1013.25
So, 1013.25 mbar is equal to approximately 760 mmHg.
Millibar (mbar)Millimeter of Mercury (mmHg)
1 mbar0.75006 mmHg
10 mbar7.5006 mmHg
100 mbar75.006 mmHg
500 mbar375.03 mmHg
1013.25 mbar760 mmHg
2000 mbar1500.12 mmHg
  • Meteorology: Ideal for converting barometric pressure readings from mbar to mmHg.
  • Scientific Research: Useful in laboratory settings that require both mbar and mmHg units.
  • Medical Applications: Frequently used to translate pressure measurements for medical devices.
  • Industrial Calibration: Applicable for calibration tasks where both mbar and mmHg pressure units are necessary.
This mbar to mmHg conversion calculator is a valuable tool for professionals in scientific, medical, and industrial fields requiring accurate pressure conversions.
