Displacer-based Leveltrol devices are very important for keeping stable interface levels in complex process units, especially in oil-water separators and three-phase containers. When something goes wrong, such forming an emulsion, swinging SG, flashing, building up within, or drifting the torque tube, the results might be very bad. This advanced exam about breakdowns puts you in real-life situations that are typical in refineries, upstream separation trains, and condensate-handling systems. Each question puts you in a real failure situation and has you look at symptoms, how instruments work, and mechanical problems. If you work with interface measurements, this quiz will help you get better at diagnosing problems and becoming ready for real-world process problems.
25 Advanced MCQs on Leveltrol Interface Troubleshooting
