- What is the Marshalling Cabinet?
- What is the function of the marshalling cabinet?
- Major Components of a Marshalling Cabinet
- Types of Marshalling Cabinets
- Design of Marshalling Panel
- What are the benefits of marshalling panels?
- What is cross-wiring in marshalling cabinet?
- Why we are using Marshalling Panel?
- Key Applications of a Marshalling Cabinet
- Main Purpose of a Marshalling Cabinet
- Working Principle of a Marshalling Cabinet
- Common Marshalling Techniques
- Disadvantages of Marshalling Cabinets
- What is a DCS Marshalling Cabinet?
- Difference Between System Cabinet and Marshalling Cabinet
- Design Considerations for Dedicated Marshalling Cabinets
- Wiring Practices and Standards on Marshalling Cabinets
- Marshalling Panel Vs Junction Box – What’s the difference:
A marshalling cabinet is a type of electrical enclosure that is used to organize and terminate field wiring in an industrial control system. It typically contains a series of terminal blocks or connectors that are used to connect field wiring to the control system.
Here is a diagram of a typical marshalling cabinet:
The marshalling cabinet is an interface between the system cabinet (DCS/PLC control panel) and the field junction boxes. The primary cables are laid between the field junction boxes and the marshalling cabinet. Additionally, the prefabricated cables from the system cabinet IO cards terminate in the marshalling cabinet. It also separates the control system panel from the field control panel. A typical architecture for an instrumentation and automation system has a marshalling cabinet between the junction box and the system cabinet.
Marshalling cabinets are used to organize and protect the field wiring in a control system, making it easier to maintain and troubleshoot the system. They are commonly used in industrial control systems, building automation systems, and other applications where field wiring needs to be organized and protected.
The main functions of the marshalling cabinet are listed below.
- Signal conditioning for analogue signals
- cable termination
- signal isolation
- cold junction compensation of thermocouple signals
- power supplies for field devices
Salient features of a marshalling cabinet:
- Marshalling panel is used for grouping I/Os.
- A marshalling panel is placed between the DCS system panel and the field junction box where the field devices are connected.
- I/Os like analog input, analog output, digital input, digital output, and pulse I/O are grouped together in the marshalling panel.
- Isolation and signal conditioners send I/O signals from the marshalling panel to the CPU or controllers of the system.
- Marshalling panels facilitate cross-wiring between field instruments and control systems.
- With this type of interface, problems with inputs and outputs can be found quickly, and maintenance workers can do routine tasks in the field without putting the core of the control system at risk.
The industrial control system depends on marshalling cabinets because they collect field instrumentation signals at a central location for both protection and connection to the control system. A marshalling cabinet contains different components that maintain operation safety. Below is an explanation of essential components that usually appear inside marshalling cabinets:
- Terminal Blocks: Terminal Blocks serve as the essential foundation of marshalling cabinets because they create protected and efficient connections between field instrumentation cables and the control system. Users can connect wires easily through screw terminals that sometimes contain internal jumpers for simplified cross-wiring functionality.
- Wiring Ducts: Protective wiring ducts function as a safety system for securing electrical wires between control system components and field instrumentation through a routing system. Each duct contains protective covers specifically designed to secure and protect cable wiring from harm and unwanted physical interactions.
- Relays and Contactors: Relays and Contactors control high-voltage or high-current signals between the control system components which operate inside the cabinet. The control system uses low-voltage commands to control these components while maintaining safe and efficient system operations.
- Fuses and Circuit Breakers:The control system together with field instruments depend on fuses and circuit breakers as safety mechanisms which defend them against electrical damages because of overcurrents. These components function as the initial protection mechanism against various system hazards..
- Signal Isolators and Conditioners: Signal Isolators together with Conditioners function as essential components that handle signals. The signal isolators divide different cabinet sections while signal conditioners turn weak sensor signals into stronger output signals which control systems understand.
- Power Supplies: The cabinet contains power supplies which convert electrical input into needed field instrument and control system operating voltages and currents.
- PLC or DCS I/O Modules: PLC or DCS I/O Modules function as communication points that connect field instruments with control system systems. The components include wiring connectors for external system integration and they possess intrinsic signal filtering elements with built-in isolation capabilities. The modules can be placed in their own system cabinet for certain installation setups.
- Seismic and Vibration Isolation Mounts: The seismic and vibration isolation mounts safeguard both the cabinet and its contents against seismic and vibration forces in earthquake zones to provide safety during these events.
- Enclosures: The enclosure surrounding the cabinet employs durable construction to defend its internal parts against environmental elements such as moisture and dust for extended reliability.
Marshalling cabinets exist in several varieties which match distinct operational conditions and specifications. There exists a basic set of marshalling cabinets which service different environments.
- General Purpose Marshalling Cabinets: General Purpose Marshalling Cabinets serve as the most flexible cabinet design among the available types since they provide versatility for different installation needs. Terminal blocks and wiring ducts as well as other basic components serve to order field instrumentation signals and facilitate signal connection.
- Intrinsically Safe Marshalling Cabinets: These hazardous-area marshalling cabinets incorporate intrinsic safety barriers which restrict electrical power to stop ignition in environments that contain explosive gases and dust or fibers.
- Seismic Marshalling Cabinets: Seismic Marshalling Cabinets receive protection through their reinforced structures which incorporate seismic isolation mounts to shield internal components from natural disasters including earthquakes.
- Ex-Proof Marshalling Cabinets: Ex-Proof Marshalling Cabinets use explosion-resistant enclosures together with components that stop internal explosions within oil and gas environments.
- Compact Marshalling Cabinets:The compact marshalling cabinets offer essential functionality to small spaces since they remain easy to install and lightweight for use on offshore platforms and mobile equipment.
- Modular Marshalling Cabinets: The modular design of marshalling cabinets provides flexibility when process requirements change through easy expansion along with customization options. The cabinets contain interchangeable modular building blocks that users can install or remove through terminal blocks along with wiring ducts.
- Remote Marshalling Cabinets: These remote marshalling cabinets serve locations that are remote by integrating monitoring capabilities through remote control functions with harsh environment protection features.
- Intelligent Marshalling Cabinets: Intelligent Marshalling Cabinets utilize advanced electronics and connection interfaces PLC, DCS, or Ethernet for enhanced control capabilities and monitoring functions along with diagnostic features suitable for intricate manufacturing procedures.
The marshalling cabinet functions to provide organization and communication connections for field instrumentation signals that connect process sensors with actuators to control systems.
The successful design of marshalling cabinets requires attention to several essential skills along with these considerations:
- Familiarity with the types of field instrumentation and the corresponding signal types, such as 4-20mA, 0-10V, etc.
- Understanding of both control system architecture and what I/O (Input/Output) modules meet the need to connect field instrumentation.
- An understanding of electrical and electronic principles for signal transmission that includes protective concepts like grounding and shielding.
- Designing and constructing marshalling cabinets requires knowledge of relevant industry standards IEC 60664 as well as NEMA 250 and UL 508.
- Technical drawings of cabinet layout and wiring must be created and edited using AutoCAD or similar CAD software because of required experience in this domain.
- Knowledge of the physical requirements of the marshalling cabinet, such as size, weight, and environmental conditions.
- The necessary skills include both analytical abilities and problem-solving competencies because of potential design and implementation difficulties.
- The professional requires strong collaborative abilities to connect with engineers, technicians along with stakeholders so the marshalling cabinet design satisfies all project requirements and technical specifications.
The precise location of the marshalling cabinets will reduce cable costs and make it simple for maintenance personnel to trace wire routing and easy troubleshooting.
In a marshalling panel, inputs and outputs can be easily identified, and faults can be diagnosed with minimal effort.
A large number of analogue and digital sensors and actuators may be terminated into each field junction box. Following that, 16 pair or 24-pair multi core cables are used to connect these devices to the central control panel. Therefore, the cable connecting the field junction box to the central control system may contain both digital and analogue signals, as well as input and output signals. This causes an issue within the control panel.
How does an engineer redistribute these signals so that all signals of a particular type are routed to the appropriate digital or analog I/O module of the controller?
To answer this question, a marshalling cabinet or marshalling control panel is used. The field wires are switched to the right I/O module and channel on the controller using either one or two banks of terminal blocks. This method is called cross-marshalling.
The main purpose of using Marshalling cabinet is to do signal segregation properly from field junction box to the control system by doing cross wiring and also to do necessary signal conditioning.
For example, let’s say we have a 20-field analog signal coming in on a 24-pair incoming field cable. At least two 16-channel analogue I/O cards will be made from this field signal. The first 16 I/O will be on the first 16-channel I/O card, and the next 16-channel I/O card will have the other four. From an operation and maintenance point of view, it is not a good idea to have this split wiring (cross wiring) in the system cabinet. So, we need the marshalling cabinet.
Mixed I/O signals coming from the field are another cause of cross-wiring. There can be a mix of AI (analog input) and AO (analog output) signals in the incoming multi-pair cable. This mixed signal will be separated in the marshalling cabinet so that the AI signal will end at the AI termination board and the AO signal will end at the AO termination board.
In a normal scenario, the cables go through the marshalling cabinet in the following way:
1. The multi pair field cables go into the cabinet through the bottom.
2. Then, each wire of the incoming multi pair field cable is connected to the surge protection device or surge arrester. If there is no need for these surge protection devices, each wire is connected to the terminal block.
3. In a non-intrinsically safe application, the surge protection devices will have cross-wiring that matches the field signal and the I/O address assignment in the termination board. If the system is IS, each wire connection must first go to the IS barrier before it can be used for cross-wiring.
4. The dedicated system cable with a “plug and play” connection is then routed from the termination board to the I/O card in the system cabinet.
5. Some termination boards may need a dedicated DC power supply that can be taken from the DC power supply in the marshalling cabinet.
Automation systems with a lot of I/O signals often need marshalling cabinets. Some such uses are:
- Programmable Logic Controllers (PLC) systems
- Distributed Control Systems (DCS)
- Industrial Automation Systems
- Building Management and Automation Systems
The main goal of a marshalling cabinet is to bring together and arrange field signals so that control systems can communicate with them easily and quickly. Some of the main goals are:
- Grouping large volumes of I/O signals into logical sections such as:
- Analog Inputs (AI)
- Analog Outputs (AO)
- Digital Inputs (DI)
- Digital Outputs (DO)
- Pulse I/O
- Acting as a middleman between field instruments and control system panels (DCS/PLC)
- Making signal conditioning easier, which makes it easier to find and diagnose problems
- Organizing all field wiring in an organized way makes it easier to maintain and fix things.
There are a number of stages that happen in order for a marshalling cabinet to work:
- Field Signal Collection: All of the field instruments are wired into junction boxes. These are then grouped together into multi-core cable groups based on the sorts of signals they send (analog, digital, etc.).
- Signal Routing to Cabinet: The marshalling cabinet terminals are where the cables from the junction boxes end.
- Signal Conditioning and Distribution: Signals are either sent straight to the control system or conditioned first (for example, with barriers or isolators).
- Control Panel Connections: The conditioned output is wired from the marshalling cabinet to the I/O cards or system cabinets of the DCS/PLC..
- Cross-Wiring: Signals are sent around inside the system to group them logically.
- Fan-Out: Signals are sent to more than one I/O card or channel.
The goal is to create a signal interface design that is cheap, well-organized, and easy to keep up.
Marshall cabinets are quite handy, although they do have certain problems:
- High Cost: Cabinets that are big or have a lot of I/O points might be pricey.
- Big and Heavy: Their size can be a problem in small control rooms or when you’re adding them to an existing project.
- Voltage Transients: If the design is bad, it might create transients that can harm sensitive parts.
- Interference from EMI and RFI: Cabinets can create electromagnetic or radio frequency interference that affects devices nearby.
- Cooling Needs: When heat builds up from several parts, it typically needs cooling fans or air conditioning equipment.
A DCS marshalling cabinet is a part of a Distributed Control System that makes it easy to connect DCS I/O cards to field instruments in a clear and organized way. It uses marshalling techniques to organize I/O signals, which makes the system easier to manage and helps identify signals.
- The Marshalling Cabinet: It connects the control system to field signals. It has the intermediate wire, devices for signal conditioning, and terminal blocks inside.
- System Cabinet (Control Panel): The System Cabinet (Control Panel) has the DCS/PLC system hardware, including as controllers, power supply, and I/O cards.
From field junction boxes to marshalling cabinets, primary cables run. From the marshalling cabinet to the system cabinet, pre-terminated cables connect.
Things to think about when designing dedicated marshalling cabinets
- Planning for Termination: The marshalling cabinet must be the end of all field multi-core wires. Changes in the kind of cable (for example, from 16-pair to 24-pair) modify the number of terminals.
- I/O Assignment: Changes to how junction boxes are grouped have little effect on cross-wiring, but they shouldn’t change I/O assignment.
- Logic for redundancy and safety: I/O for parallel equipment, such 2oo3 voting systems, must be assigned to different I/O cards using cross-wiring logic.
- Managing Cables: Check how many main cables are connected to each cabinet to make sure they can be maintained.
- Controller Segregation: The control system’s segregation philosophy should guide how I/O is allocated (for example, by process area, kind of equipment, or function).
- Cabinet Build Details: Review specifications such as:
- Dimensions and color
- Type of door/access
- Internal wireway layout
- Cable entry locations
- Spare components and space
- Ingress Protection (IP) rating
- EMC shielding
- Smoke detection and ventilation requirements
Follow the finest wiring procedures and industry standards for a strong and code-compliant installation of a marshalling cabinet:
Recommended Practices:
- Sizing and coloring wires: For safety and clarity, use the right wire gauges and standard color codes.
- How to Use Ferrules: Put ferrules on the ends of all the wires to keep them from fraying and make sure the terminal connections are strong.
- Loop Numbering and Tagging: Use standard loop numbers and terminal labels to give each loop and wire a unique tag.
Applicable Standards:
- ISA Standards (e.g., ISA-5.1 for instrumentation symbols)
- IEC Standards (e.g., IEC 60204 for electrical equipment)
Compliance with these standards ensures uniformity, traceability, and long-term maintainability of the control system.
S. No | JUNCTION BOX | MARSHALLING CABINET |
1 | Instrument Junction Boxes, often known as JBs, are a crucial component of every installation for controls and instrumentation. An instrument junction box is an enclosure containing terminals that permits connections between field devices (i.e., instruments, switches, etc.) in the process/production zones and control or monitoring equipment, which is normally located in the control room. | The marshalling cabinet is an interface between the system cabinet (DCS/PLC control panel) and the field junction boxes. The primary cables are laid between the field junction boxes and the marshalling cabinet. Additionally, the prefabricated cables from the system cabinet IO cards terminate in the marshalling cabinet. It also separates the control system panel from the field control panel. |
2 | They keep the weather out of electrical connections, keep operators and technicians from getting electric shocks by accident, and make it easy to get into a circuit for maintenance and troubleshooting. | Marshalling Panels allow field instruments and the control system to be wired together in different ways. With this type of interface, problems with inputs and outputs can be found quickly, and maintenance workers can do routine tasks in the field without putting the heart of the control system at risk. |
3 | Most of the time, a junction box is used to connect multiple field devices from the same system in the same area. Instrument junction boxes should be made to fit the conditions of the places where they will be used. It needs to be certified to show that it has the right ingress protection (IP) and hazardous area protection. | The marshalling cabinet’s key duties are signal conditioning for analogue signals, cable termination, signal isolation, and cold junction correction for thermocouple signals. It also gives power to devices in the field. The majority of the marshalling cabinets were installed in safe locations (controlled environment) along with the MCC, electronics room, and control room. |
