What is a relay ? Internal architecture of a relay
Relays – Relays are switches that open and close circuits when actuates with an electrical signal.
A switch is a device that can open and close when actuated manually,typically through a physical action by a person or an object.
Relays are used in application where it is necessary to control one or more circuits by a power signals that may or may not be isolated from the circuits being controlled and when manual actuation is not possible or practical.
what is a relay ? working principle
Here is an electrical diagram of a switch.When switch is open the circuit is open or off.When switch is when is switch is closed the circuit is closed or on.
switch circuit in open condition
When a switch can be actuated with an electrical signal ,the device is then typically refereed to as a relay.
switch circuit in closed condition
The actuation of the relay will change the state of the contact from open to closed or vice versus,depending on the contact configuration.Each switch in a relay referred to as a pole.Relays may have one or more pole.The number of poles in a relay indicates the number of switches that are contained within the relay.Each pole may be configured as single or double throw,indicating the number of circuits that can be controlled per pole.
Single throw means that the pole has an open state and a closed state.The relay will alternate between states when actuated.
single throw relay
Double throw pole can control two circuits and alternate between one circuit being open while the other is closed and vise versus when actuated.
double throw relay
A break is the number of places or contacts that a switch uses to open or close a single electrical circuit.All contacts are either single break or double break.
A single break contact breaks an electrical circuit in one place,while a double break contact it in two places. Single break contacts are normally used when switching lower power devices such as indicating lights.Double break contacts are used when switching high power devices such as solenoids.
Related:
How to read electrical relay diagram ?
Control panel components
Control panel and MCC differences
Electrical components troubleshooting in MCC panel
