What is a control panel?. What are the components in a control panel?
CONTROL PANEL
Control panel is a cabinet which contains electrical components to control the motors and equipments.
electrical control panel
plc/dcs panel
mcc(motor control center) panel
CABLES
Cables are used for the interconnection. Two types of cables are used. Power cable and control cable.
1. Power cables (which is used to connect the motor to panel component and panel to main supply)
2. Control cables (which is used to connect the control circuits)
BUS BAR
signal cable
power cable
BUS BAR
Incoming supply is connected to bus bar and distributed from bus bar. It is normally made by Aluminum.
bus bar incoming supply is coming to bus bar
MCB (Miniature Circuit Breakers)
MCB is a protecting device. It is used before the feeder. This should be selected according to the capacity of the feeder
mcb miniature circuit breaker
MCCB (Mould Case Circuit Breaker)
In most of the cases the MCCB used as an incomer for higher capacity feeders for better protection
ELCB (Earth Leakage Circuit Breaker)
The ELCB is also known as RCCB. The device used for the protection against the earth leakage current and residual current. It should be fixed before the incomer
INCOMER
The basic supply will connected to this incomer. It also called as SFU(Switch Fuse Unit). It contains one handle with fuse unit. Once it is turned ON the supply will pass to the next stage through fuse if any major fault occurs in side panel board, it will trip and it isolate supply.
INCOMER
SELECTOR SWITCH
Selector is switch is used for ON/OFF purpose and for selecting the mode of operation like auto/manual.
SELECTOR SWITCH
Starters are used for starting the motors safely. Mainly two types of starters are there. DOL starters and Start to delta. Dol starter is enough for the motors with power less than 10 hp.
STARTERS
dol starter/ star to delta
OVER LOAD RELAY
Over load relay is for the protection of motor from the over load. It senses the load current and trips if it exceeds the limit. Current limit has to be set manually. It should be 80% of the full load current.
OVER LOAD RELAY
TIMER
Operation of timer is similar to relay. But a delay is there for actuation. We can set the time delay manually according to our requirement. It is very much essential for start to delta conversion.
TIMER
CONTACTOR
Contactor is an essential component in the control panel. It actuates when the signal from the controller (PLC, Relay logic) comes. It is similar to relay. It is costlier than relay. It is used for a higher load.
Contactor
