This calculator allows you to easily convert pressure values from Psi (Pounds per Square Inch) to Megapascal (MPa) for accurate measurements in engineering, scientific, and industrial applications.
Definition: Psi (Pounds per Square Inch)
Psi is a unit of pressure in the Imperial system, commonly used in the United States. It represents the force exerted per square inch of surface area and is widely used in applications such as tire pressure, hydraulics, and industrial systems.
Definition: Megapascal (MPa)
A Megapascal (MPa) is a metric unit of pressure, equal to 1 million Pascals (Pa). It is commonly used in high-pressure applications in engineering, material science, and industrial systems.
Formula for Psi to Megapascal (MPa) Conversion:
Pressure in MPa=Pressure in Psi×0.00689476
How to Convert Psi to Megapascal: Example Calculation
If you have a pressure of 100 Psi and want to convert it to MPa:
100×0.00689476=0.689476?MPa
So, 100 Psi is approximately equal to 0.689476 MPa.
Quick Reference Conversion Table for Psi to MPa
Psi | MPa |
10 Psi | 0.0689476 MPa |
50 Psi | 0.344738 MPa |
100 Psi | 0.689476 MPa |
200 Psi | 1.37895 MPa |
500 Psi | 3.44738 MPa |
1,000 Psi | 6.89476 MPa |
2,000 Psi | 13.7895 MPa |
Use of Psi to Megapascal Conversion Calculator:
- Hydraulics and Pneumatics: Convert Psi to MPa for hydraulic system pressure measurements in industrial machinery.
- Engineering Applications: Ideal for converting pressure readings in structural, mechanical, and civil engineering.
- Material Testing: Useful in high-pressure material testing applications requiring precise conversions.
This Psi to MPa conversion calculator is a valuable tool for engineers, scientists, and technicians in fields requiring accurate pressure unit conversions.
