PSI to Bar Unit Conversion Calculator
This calculator allows you to convert pressure values from pounds per square inch (psi) to Bar.
A pound-force per square inch (symbol: psi) is a unit of pressure used in both the imperial and US customary systems. It represents the pressure resulting from a force of one pound-force applied over an area of one square inch. One psi is equivalent to approximately 6,895 pascals (N/m²).
The metric unit of pressure known as a bar (symbol: bar) is equivalent to precisely 100,000 pascals (Pa). This unit is commonly used to express atmospheric pressure, with one bar being equal to 0.987 atmospheres (101,325 Pa), which is often used as a reference for standard pressure.
Pressure in bar = Pressure in psi × 0.0689476
  • Suppose you have a pressure of 150 psi.
  • To convert it to bar: 150 × 0.0689476 =10.34214 bar
So, 150 psi is equal to 10.34214 bar.
The  below table provides quick conversions for common psi values to bar, which is particularly useful in fields such as instrumentation, automotive, and industrial automation.
Psi [psi]Bar
0.01 psi0.0006894757 bar
0.1 psi0.0068947573 bar
1 psi0.0689475729 bar
2 psi0.1378951459 bar
3 psi0.2068427188 bar
5 psi0.3447378647 bar
10 psi0.6894757293 bar
20 psi1.3789514586 bar
50 psi3.4473786466 bar
100 psi6.8947572932 bar
1000 psi68.9475729318 bar
  • Engineering Applications: Convert pressures used in pneumatic and hydraulic systems.
  • Instrumentation: Gauge readings that need to be converted between units.
