This calculator allows you to easily convert pressure values from Millimeter of Water Column (mmWC) to Millibar (mbar), widely used in industrial, meteorological, and engineering applications.
Definition: Millimeter of Water Column (mmWC)
The Millimeter of Water Column (mmWC) is a pressure unit that reflects the pressure exerted by a 1-millimeter column of water. This unit is often employed in applications like HVAC systems, water treatment, and low-pressure systems where precise measurements are crucial.
Definition: Millibar (mbar)
The Millibar (mbar) is a metric unit of pressure equal to 100 Pascals (Pa). It is commonly used in meteorology for atmospheric pressure, as well as in industrial processes. At sea level, the average atmospheric pressure is about 1013.25 mbar.
Formula for mmWC to Millibar Conversion:
Pressure in mbar=Pressure in mmWC×0.09807
How to Convert mmWC to Millibar: Example Calculation
Suppose you have a pressure of 1000 mmWC.
To convert it to mbar:
1000×0.09807=98.07?mbar
So, 1000 mmWC is equal to 98.07 mbar.
Technical Notes
- The conversion factor assumes standard water density at 4°C (1000 kg/m³) and standard gravity (9.80665 m/s²).
- Temperature variations can cause minor deviations in actual pressure values.
- Suitable for pressures typically below 1000 mbar or 10,200 mmWC.
Quick Reference Conversion Table for mmWC to Millibar
Millimeter of Water Column (mmWC) | Millibar (mbar) |
100 mmWC | 9.807 mbar |
200 mmWC | 19.61 mbar |
500 mmWC | 49.04 mbar |
1000 mmWC | 98.07 mbar |
2000 mmWC | 196.14 mbar |
Common Pressure Conversion Tools
- Millimeter of Water Column (mmWC) to Millimeter of Mercury (mmHg) Pressure Unit Conversion Calculator
- Millimeter of Mercury (mmHg) to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
- Kilopascal (kPa) to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
- Millimeter of Water Column (mmWC) to Kilopascal (kPa) Pressure Unit Conversion Calculator
- Millimeter of Water Column (mmWC) to Millibar Pressure Unit Conversion Calculator
- Millibar to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
- Kg/cm² to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
- Millimeter of Water Column (mmWC) to Kg/cm² Pressure Unit Conversion Calculator
- Psi to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
- Millimeter of Water Column (mmWC) to Psi Pressure Unit Conversion Calculator
- Millimeter of Water Column (mmWC) to Bar Pressure Unit Conversion Calculator
- Bar to Millimeter of Water Column (mmWC) Pressure Unit Conversion Calculator
Uses of mmWC to Millibar Conversion Calculator:
- HVAC and Ventilation Systems: Converts mmWC readings to mbar for accurate system monitoring and pressure control.
- Water Distribution and Treatment: Useful for converting low-pressure measurements in water column systems to the more widely used millibar unit.
- Industrial Applications: Convenient for converting pressure values in low-pressure control environments and precise instrumentation systems.
This mmWC to mbar conversion calculator is an indispensable tool for professionals who need quick and accurate pressure conversions for industrial, environmental, and engineering purposes.
Refer the below link for the more Pressure Unit Conversion Calculators
Is mmWC Equal to mbar?
No, despite their frequent use in low-pressure applications, mmWC (millimeter of water column) and mbar (millibar) are distinct pressure units.
1 mmWC = 0.0980665 mbar
Conversely, one mbar equals 10.197 mmWC.
Thus, even if both are used to gauge low pressures that is, in HVAC, fluid systems, etc. they are not equal and call for appropriate conversion.
Is 1 mmWC Equal to a Bar?
No, 1 mmWC is rather less than a bar.
1 mmWC = 9.80665 × 10?? bar
consequently: One bar represents 10,197.162 mmWC.
To equal one bar of pressure, thus, it would take over 10,000 mmWC.
Is 1 kg/cm² Equal to mmWC?
Yes, through conversion:
1 kg/cm² = 10,000 mmWC (at 4°C water density and standard gravity)
Particularly in Asian engineering systems, this is a regularly utilized conversion in water column and hydraulic applications.
What Does mmWC Pressure Mean?
Derived from the hydrostatic pressure experienced by a 1 mm high column of water at 4°C, the low-pressure unit known as millimeter of water column (mmWC)
1 mmWC = 9.80665 Pascal (Pa)
It’s often used in HVAC, gas flow measurements, and fluid level detection where extremely small pressure differences are relevant.
