Millibar (mBar) to Psi Pressure Unit Conversion Calculator
This calculator allows you to convert pressure values from millibars (mbar) to pounds per square inch (psi).
A millibar (symbol: mbar) is a unit of pressure commonly used in meteorology to describe atmospheric pressure. It is equal to one-thousandth of a bar, which is a metric unit of pressure.
Pressure in psi = Pressure in mbar × 0.0145038
Suppose you have a pressure of 1000 mbar.
To convert it to psi:
1000×0.0145038=14.5038?psi
So, 1000 mbar is equal to 14.5038 psi.
Millibar (mbar)Psi (pound-force per square inch)
1 mbar0.0145038 psi
10 mbar0.145038 psi
50 mbar0.72519 psi
100 mbar1.45038 psi
500 mbar7.2519 psi
1000 mbar14.5038 psi
2000 mbar29.0076 psi
5000 mbar72.519 psi
10000 mbar145.038 psi
  • Engineering Applications: Convert pressures in weather-related applications, HVAC systems, and other fields requiring atmospheric pressure measurements.
  • Instrumentation: For converting gauge readings from metric units to imperial units.
This calculator is useful for professionals and engineers who need to convert between these two pressure units, ensuring accuracy in calculations and measurements.
