An Instrumentation Technician requires tools to perform the assigned duties efficiently, this content lists all the necessary tools required in day to day basis.
Hand Tools
- Vernier calipers
- Desoldering tool
- Diagonal cutters
- Drill bits
- Screw extractors
- Feeler gauges
- Flaring tools
- Flashlight
- Fuse puller
- Gasket cutter
- Gauge pointer puller
- Grease gun
- Hammers (assorted)
- Hand files (assorted)
- Hex keys (Imperial/Metric)
- I/C integrated-circuit extractor
- Knives
- Knock-out punches
- Sprit Level gauge
- Magnet
- Measuring tape
- Mirrors
- Nut drivers
- O-ring picks
- Packing puller
- Pipe threader
- Pliers (assorted)
- Pry bar
- Punches (assorted)
- Ratchets
- Reamers
- Rubber mallet hammer
- Saws frame (assorted)
- Screwdrivers (assorted)
- Screw starters
- Sockets (Imperial/Metric)
- Steel rule
- Strap wrenches
- Tap and die set
- Torque wrenches
- Tube benders
- Tube cutters
- Tweezers
- Wire brushes
- Wire crimpers
- Wire cutters
- Wire strippers
- Wrenches (assorted)
Power Tools
- Air compressor
- Band saw
- Cut-off saw
- Drill press
- Grinders
- Hammer drill
- Heat gun
- Hydraulic press
- Hydraulic knock-out punch
- Impact wrench
- Jig saw
- Pipe threader
- Pneumatic tools
- Portable electric drill
- Soldering iron
- Wire labeler
Electronic Tools and Test Equipment
- Current clamp meter
- Analogue/ digital multimeter
- Computer
- Current tracer
- Dead weight tester
- Decade resistance box
- Dry block calibrator
- Frequency generator
- Grounding mats
- Hydrometer
- Infrared thermal cameras
- Infrared thermometers
- Loop calibrator/simulator
- Manometer and standards
- Millivoltmeter calibrator
- Mobile phones/two?way radio
- Oscilloscope
- Universal communicator
- pH simulator/buffers
- Pneumatic test stand
- Pressure hand pump
- Power supply
- Pressure calibrator
- Radiation meter
- Regulators
- RPM tester/tachometer
- Signal generators
- Stroboscope
- Temperature bath
- Temperature calibrator
- Reference test gauges
- Thermometer
- HART
