Gas Flow Unit Conversion Calculator: Standard Cubic Feet per Hour (SCFH) to Standard Cubic Feet per Minute (SCFM)
This SCFH to SCFM Conversion Calculator is a quick and easy way to change gas flow rates from Standard Cubic Feet per Hour (SCFH) to Standard Cubic Feet per Minute (SCFM). This is especially significant in gas flow measurement, instrument calibration, and system design in fields like HVAC, oil and gas, environmental controls, and industrial automation, where unit consistency is very crucial for safety and operational accuracy.
SCFH is a common unit of measurement in the U.S. that tells you how many cubic feet of gas flow through a system in one hour under normal conditions (typically 14.7 psia, 68–70°F, and 0% humidity). It is extensively used to set lower gas flow rates in systems for measuring and delivering fuel.
  • Measuring the flow of low-pressure gas in pilot and burner systems.
  • Flow measurement in HVAC, cleanroom, and industrial ventilation.
  • Keeping an eye on the flow of nitrogen or argon in lab or semiconductor equipment.
  • Totalizing and controlling flow in systems that monitor the environment.
SCFM is a common unit for measuring gas flow at higher volumes under normal conditions. It works well for air compressors, process control valves, and industrial pneumatic systems. It shows the volume of flow per minute and is one of the main design metrics in gas system specifications.
  • specify the flow capacity of blowers, dryers, and compressors.
  • Checking how much air pneumatic tools and actuators use.
  • Making air handling systems for factories and HVAC systems.
  • Controlling the flow of gas in industrial pipelines.
To change SCFH to SCFM, use this easy formula:
You may find the flow rate per minute by dividing the hourly flow by 60, since there are 60 minutes in an hour.
If a gas meter reads 3,600 SCFH, to convert to SCFM:
3,600?SCFH÷60=60?SCFM
So, a flow rate of 3,600 SCFH is equal to 60 SCFM.
Standard Cubic Feet per Hour (SCFH)Standard Cubic Feet per Minute (SCFM)
60 SCFH1 SCFM
600 SCFH10 SCFM
1,200 SCFH20 SCFM
3,600 SCFH60 SCFM
6,000 SCFH100 SCFM
12,000 SCFH200 SCFM
30,000 SCFH500 SCFM
  • Real-time Monitoring: This helps turn hourly flow readings into per-minute information for PLC/SCADA dashboards.
  • System Design: Lets you size equipment correctly based on changing process circumstances.
  • Instrument Configuration: Uses the same units to match flow meter ranges and gas regulator settings.
  • International Engineering Workflows: Makes it easier for teams that use different flow rate reporting standards to work together.
  • Optimizing Processes: Makes sure that the control loop tuning and alarm threshold settings are correct.
This conversion calculator helps engineers, maintenance workers, and system integrators make judgments they can trust and make sure that data formats are the same across the board in process industries.
