Cubic Feet per Minute (CFM) to Liters per Second (L/s) Flow Unit Conversion Calculator
Users benefit from this tool which transforms measurements between Cubic Feet per Minute (CFM) and the standard Liters per Second (L/s). The conversion process enhances both accuracy and operational efficiency among industries such as HVAC as well as engineering and water management and manufacturing.
The United States uses Cubic Feet per Minute (CFM) as its main standard to measure airflow volumes during one minute. This measurement appears regularly throughout ventilation setups along with air conditioning systems and industrial applications.
  • The fundamental uses of Cubic Feet per Minute (CFM) occur in multiple applications such as HVAC operations and industrial gas flow monitoring.
  • Healthcare professionals employ this measurement to evaluate airflow within Heating Ventilation and Air Conditioning HVAC systems as well as Air Conditioning units.
  • Air ventilation rates in indoor areas require this unit for proper calculation.
  • Using pneumatic systems allows the monitoring of gas flow through their operations.
  • Essential in dust collection and air purification systems.
  • This unit serves industrial purposes for drying equipment and cooling systems.
The measurement system Liters per Second (L/s) serves the international community for determining fluid and gas flow rates. This measurement method enables engineers to determine accurate and standardized flow values during industrial and engineering operations.
  • Used in international HVAC system planning and assessment.
  • Applied in laboratory, pharmaceutical, and clean room airflow measurements.
  • Commonly utilized in water supply, treatment, and irrigation systems.
  • Important for environmental monitoring and industrial ventilation.
The transformation of CFM to L/s requires the following calculation:
The conversion from CFM to L/s requires multiplying CFM by 0.471947 because 1 CFM has an approximate equal value of 0.471947 Liters per Second.
If your current flow rate is 100 CFM, convert it to L/s:
100 CFM × 0.471947 = 47.19 L/s
So, a flow rate of 100 CFM is equivalent to 47.19 L/s.
Cubic Feet per Minute (CFM)Liters per Second (L/s)
1 CFM0.4719 L/s
10 CFM4.719 L/s
50 CFM23.60 L/s
100 CFM47.19 L/s
500 CFM235.97 L/s
1,000 CFM471.95 L/s
5,000 CFM2,359.73 L/s
  • The conversion of CFM to L/s serves as an essential tool which helps engineers and technicians calculate correct airflow measurements.
  • Helps design HVAC systems according to international standards.
  • Useful for validating air quality control systems in commercial buildings.
  • Assists industrial manufacturers in regulating cooling or drying processes.
  • Aids in laboratory and cleanroom system design to maintain compliance.
  • Crucial for benchmarking performance in environmental systems and testing.
This tool provides professionals with confidence to transform CFM measurements into L/s units which helps improve planning and design functions and control within fluid and air flow systems across industries.
