Cubic Feet per Hour (ft³/h) to Gallons per Minute (GPM) Flow Unit Conversion Calculator
This tool enables smooth integration of volumetric flow measurements across U.S. customary units by converting Cubic Feet per Hour (ft³/h) to Gallons per Minute (GPM). Perfect for industrial uses, water distribution, and HVAC fluid handling.
A U.S. conventional unit, cubic feet per hour (ft\u00b3/h) gauges the volume of fluid flowing through a system over one hour represented in cubic feet. Common applications include bulk fluid movement systems, gas transmission, and HVAC airflows.
  • HVAC systems’ duct sizing and ventilation.
  • Flow measurement in compressed gas pipe systems.
  • Water distribution systems based on volumetric control.
  • Bulk fluid transfer in industrial and utility facilities.
A U.S. conventional unit for measuring fluid flow on a per-minute basis, Gallons per Minute (GPM) is often used for pumps, flowmeters, irrigation, and general fluid transport operations.
  • Pump performance monitoring and selection.
  • Sprinkler systems and irrigation.
  • Sizing filters and controlling process flow.
  • Systems of emergency water supply and fire defense.
The formula below will help you to convert Cubic Feet per Hour (ft³/h) to Gallons per Minute (GPM):
Explanation: 1 cubic foot = 7.48052 U.S. gallons, and 1 hour = 60 minutes,
so:
ft³/h × 7.48052 ÷ 60 = ft³/h × 0.124031
Convert 500 ft³/h to GPM:
500×0.124031=62.0155 GPM
Thus, roughly 62.02 Gallons per Minute results from a flow rate of 500 Cubic Feet per Hour.
Cubic Feet per Hour (ft³/h)Gallons per Minute (GPM)
1 ft³/h0.1240 GPM
10 ft³/h1.2403 GPM
50 ft³/h6.2016 GPM
100 ft³/h12.4031 GPM
500 ft³/h62.0155 GPM
1,000 ft³/h124.031 GPM
  • In fluid systems, easily toggle between flow-based and volumetric units.
  • Promote real-time monitoring, calibration, and pump selection.
  • Consistent flow measurements help to study gas and liquid transfer.
  • Include ft³/h-based measurements into GPM-centric controls.
  • Assist operational optimization, safety checks, and process design.
Engineers, technicians, and system designers wishing to combine hourly volumetric data with per-minute flow rates for improved fluid control and system integration will find this conversion tool to be a useful tool.
