Control Valve Hunting Troubleshooting – Advanced MCQ Quiz
Control valve hunting is a common and expensive problem in process control systems that lowers the quality, safety, and profitability of products. This advanced quiz focuses on real-world troubleshooting in a variety of fields, including oil and gas, chemicals, power, utilities, pharmaceuticals, and refineries. It helps engineers spot patterns that indicate problems, figure out what is causing them, and choose the best course of action. Some of the topics are tuning, stiction, sizing issues, I/P and air supply problems, positioner feedback, process dead time, and strategy flaws. Each question based on a scenario is like what happens in the field during commissioning, start-up, and operations. This helps teams improve their diagnostics, reduce oscillations, and speed up repairs, which makes the plant more reliable.
What Is Control Valve Hunting?
This sophisticated control valve searching quiz will put your diagnostic skills to the test. It is made for engineers who work with instrumentation, control, and automation. It simulates real-life situations in oil and gas, chemicals, power, utilities, pharmaceuticals, and refineries. Focus on swiftly finding the fundamental causes and using practical troubleshooting methods that cut down on downtime and make control more stable under pressure.
A flow control valve exhibits large amplitude oscillations; a log analysis shows controller output and valve position move in opposite phase (controller commanding open while valve closes). What is the likely cause?
Operators report that when local maintenance actuates the valve using the manual handwheel, oscillation stops until valve is returned to control. Why?
After installing a flow meter upstream, valve hunting began. The meter uses a long insertion probe and added upstream disturbance. Which factor is likely responsible?
A control valve’s actuator travel is sluggish and hunting. Diagnostics show the supply air filter regulator has high differential pressure across it. Most likely root cause?
Field logs show oscillation amplitude diminishes when the controller is switched to manual mode and trivial operator adjustments stop. Interpretation?
A DCS change altered controller algorithm from PID to a modified predictive algorithm. Immediately several valves began to hunt. Which is most plausible?
A control valve displays oscillations that correlate with the on/off cycles of a nearby pump. What should you investigate first?
During cold weather, multiple valves begin hunting and show sluggish response. After replacing faulty regulators, performance returns. What was likely problem?
A process has two interacting controllers (level and flow). The control valve on the flow loop starts hunting after level controller tuning changes. Best diagnosis?
Positioner feedback indicates rapid, small oscillations of ±0.5% while controller output remains steady. What does this suggest?
An engineered change increased controller gain to improve setpoint following. After the change, several valves began to hunt intermittently. What is the root problem?
A large control valve in a power plant shows hunting only when the controller output moves slowly over a long period. During rapid sweeps there is no hunting. Likely cause?
A control valve’s I/P converter is showing correct milliamp input, but output pressure lags and oscillates. Visual inspection reveals particulate at the I/P nozzle. What happened?
Bench testing shows the positioner deadband is within spec, but in-situ the loop hunts until you slightly tighten the valve packing. Interpretation?
A flow control loop that uses a split-range valve and bypass shows hunting when both valves operate in overlapping ranges. Root cause?
A temperature control valve hunts only when valve travel is below 10% and above 90%. Which mechanical issue is most consistent?
Oscillations coincide with compressor start cycles supplying instrument air. What is the likely cause?
A control valve repeatedly hunts after a maintenance activity where the actuator air supply line was re-routed. What fault should you check first?
After replacing a positioner, oscillations started immediately. Bench test of the new positioner is normal. What is the most likely installation issue?
Field data shows valve travel command and positioner feedback match, but process variable oscillates while controller output remains relatively flat. Which is the primary suspect?
A solvent dosing control valve hunts with long-period oscillations after adding a long pipeline with large volume upstream. Best immediate suspect?
Question: A solvent dosing control valve hunts with long-period oscillations after adding a long pipeline with large volume upstream. Best immediate suspect?
Question: In a refinery heater fuel valve, oscillation frequency increases when process flow increases; oscillation subsides if controller reset is reduced. Which issue is indicated?
During start-up of a crude distillation unit, the main feed valve oscillates with increasing amplitude when the cascade controller is engaged. The pressure controller output also shows oscillatory behavior. Most likely cause?
A control valve in a pharmaceutical reactor oscillates only when the plant is operating under batch transitions; the oscillation frequency changes with batch stage. Most likely root cause?
The average score is 76%
Access 1000+ MCQs tailored for instrumentation engineers: Instrumentation and Process Control Quiz Hub – 1000+ MCQs for Engineers
#ControlValve #ValveHunting #InstrumentationEngineering #ProcessControl #AutomationEngineers #PIDTuning #ControlValveTroubleshooting #EPCProjects #OilAndGasEngineering #RefineryOperationsn#PowerPlantEngineering #IndustrialAutomation #MCQQuiz #EngineeringQuiz
